Torben and I are going to start the release train on Friday (since the release falls on the weekend).
If you have any outstanding work to back port, or fixes that are waiting review, please speak up!
Jody Garnett
Jody Garnett
Looking at releasing today and the CITE tests have been failing … since Nov 14th:
https://build.geoserver.org/view/testing-cite/job/2.14-cite-wfs-1.0/
Jody Garnett
Hi Jody,looking at the stack trace I’m wondering if it’s something environmental, the tests just fail to setup their
validation routine due to a network failure:
[exec] Caused by: java.lang.IllegalArgumentException: Connection timed out (Connection timed out)
[exec] at com.galdosinc.glib.xml.jaxp.ValidatingDocumentBuilderFactory.setAttribute(ValidatingDocumentBuilderFactory.java:62)
[exec] at com.occamlab.te.parsers.GMLValidatingParser.<init>(GMLValidatingParser.java:79)
[exec] ... 216 more
CITE tests is something we have been in need to invest ontofor a while, to get a variety of developers up to speed with them, but all my attempts to get that going have been ignored.
It might sound blunt, but I believe the GeoServer community is getting what it deserves here.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Looking at the failures they start on the 14th with a single failure:
[exec] Test wfs:test1.0.0-basic-getcapabilities-get-1 (wfs-1.0.0/d1e825_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-get-5 (wfs-1.0.0/d1e845_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-get-6 (wfs-1.0.0/d1e851_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-get-7 (wfs-1.0.0/d1e856_1) Failed
And then today we have a lot more of the tests failing:
[exec] Test wfs:test1.0.0-basic-describefeaturetype-get-4 (wfs-1.0.0/d1e704_1) Failed
[exec] Test wfs:test1.0.0-basic-describefeaturetype-get-5 (wfs-1.0.0/d1e712_1) Failed
[exec] Test wfs:test1.0.0-basic-describefeaturetype-get-6 (wfs-1.0.0/d1e721_1) Failed
[exec] Test wfs:test1.0.0-basic-describefeaturetype-get-7 (wfs-1.0.0/d1e729_1) Failed
[exec] Test wfs:test1.0.0-basic-describefeaturetype-post-4 (wfs-1.0.0/d1e778_1) Failed
[exec] Test wfs:test1.0.0-basic-describefeaturetype-post-5 (wfs-1.0.0/d1e786_1) Failed
[exec] Test wfs:test1.0.0-basic-describefeaturetype-post-6 (wfs-1.0.0/d1e794_1) Failed
[exec] Test wfs:test1.0.0-basic-describefeaturetype-post-7 (wfs-1.0.0/d1e802_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-get-2 (wfs-1.0.0/d1e830_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-get-3 (wfs-1.0.0/d1e835_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-get-4 (wfs-1.0.0/d1e840_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-get-8 (wfs-1.0.0/d1e861_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-post-1 (wfs-1.0.0/d1e868_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-post-2 (wfs-1.0.0/d1e876_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-post-3 (wfs-1.0.0/d1e884_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-post-4 (wfs-1.0.0/d1e893_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-post-5 (wfs-1.0.0/d1e901_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-post-6 (wfs-1.0.0/d1e909_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-post-7 (wfs-1.0.0/d1e917_1) Failed
[exec] Test wfs:test1.0.0-basic-getcapabilities-post-8 (wfs-1.0.0/d1e925_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-1 (wfs-1.0.0/d1e1080_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-10 (wfs-1.0.0/d1e1089_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-11 (wfs-1.0.0/d1e1097_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-12 (wfs-1.0.0/d1e1105_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-13 (wfs-1.0.0/d1e1113_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-14 (wfs-1.0.0/d1e1121_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-15 (wfs-1.0.0/d1e1129_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-16 (wfs-1.0.0/d1e1138_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-17 (wfs-1.0.0/d1e1146_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-18 (wfs-1.0.0/d1e1154_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-19 (wfs-1.0.0/d1e1162_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-2 (wfs-1.0.0/d1e1170_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-20 (wfs-1.0.0/d1e1178_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-21 (wfs-1.0.0/d1e1187_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-22 (wfs-1.0.0/d1e1195_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-23 (wfs-1.0.0/d1e1203_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-24 (wfs-1.0.0/d1e1211_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-25 (wfs-1.0.0/d1e1219_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-3 (wfs-1.0.0/d1e1227_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-4 (wfs-1.0.0/d1e1236_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-5 (wfs-1.0.0/d1e1244_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-6 (wfs-1.0.0/d1e1252_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-7 (wfs-1.0.0/d1e1260_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-8 (wfs-1.0.0/d1e1268_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-9 (wfs-1.0.0/d1e1276_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-1 (wfs-1.0.0/d1e1285_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-10 (wfs-1.0.0/d1e1293_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-11 (wfs-1.0.0/d1e1301_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-12 (wfs-1.0.0/d1e1309_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-13 (wfs-1.0.0/d1e1317_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-14 (wfs-1.0.0/d1e1325_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-15 (wfs-1.0.0/d1e1334_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-16 (wfs-1.0.0/d1e1342_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-17 (wfs-1.0.0/d1e1350_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-18 (wfs-1.0.0/d1e1358_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-19 (wfs-1.0.0/d1e1366_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-2 (wfs-1.0.0/d1e1374_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-20 (wfs-1.0.0/d1e1383_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-21 (wfs-1.0.0/d1e1391_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-22 (wfs-1.0.0/d1e1399_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-23 (wfs-1.0.0/d1e1407_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-24 (wfs-1.0.0/d1e1415_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-25 (wfs-1.0.0/d1e1423_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-3 (wfs-1.0.0/d1e1432_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-4 (wfs-1.0.0/d1e1440_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-5 (wfs-1.0.0/d1e1448_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-6 (wfs-1.0.0/d1e1456_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-7 (wfs-1.0.0/d1e1464_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-8 (wfs-1.0.0/d1e1472_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-9 (wfs-1.0.0/d1e1481_1) Failed
[exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-1 (wfs-1.0.0/d1e1489_1) Failed
There are two kinds of env issues here:
Starting the release train with the following revisions:
version = 2.14-SNAPSHOT
git revision = 499990d642d60e6043f3d44deb26ac6172a4e885
git branch = origin/2.14.x
build date = 18-Nov-2018 20:23
geotools version = 20-SNAPSHOT
geotools revision = 88b6aa65a183ceb170350eab4be9509f18a0b678
geowebcache version = 1.14-SNAPSHOT
geowebcache revision = 614308f43dabe6c1a912c0936d67b7e3dd98602f/61430
Jody Garnett
Cite tests are now fixed, turned out to be some schemas pointing at a decomissioned server.
As for the still disabled WFS 1.1 tests, the issue was that the tests would complete successfully, but never exit, leading to the jenkins job hanging indefinitely: https://github.com/opengeospatial/ets-wfs11/issues/77 . I believe it initially came up during the migration off of ares.
Torben
On Sat, Nov 17, 2018 at 10:39 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Nov 17, 2018 at 7:32 PM Jody Garnett <jody.garnett@anonymised.com…> wrote:
The failures are in the GML parsers trying to parse a novelist, caused by:
[exec] Caused by: java.net.ConnectException: Connection refused (Connection refused)
[exec] at java.net.PlainSocketImpl.socketConnect(Native Method)So I agree it is an env issue
- An issue local to the server, due to some network changes happening Nov 14th… good, it might get fixed with some effort
- An issue with a remote schema that is no more there (OGC has recently changed something in their web sites and some WCSs got broken as a result)… if that’s the case, bye bye CITE test automation until we upgrade
Also worth noticing, all of the WFS 1.1 CITE test builds have been turned off over one year ago (don’t remember why, probably they bit rot too).Cheers
Geoserver-devel mailing list
Initial build artifacts are available for testing: https://build.geoserver.org/geoserver/release/2.14.1
Jody Garnett
PDF, HTML and Javadoc download / unzip OK and have the 2.14.1 version number.
.war doesn’t start on tomcat8 with Oracle JDK 11 or OpenJDK 11 on Ubuntu. Looks like the problem is missing jaxb dependencies.
After fixing that, it starts up a bit further, but gives a backtrace that starts with:
org.springframework.web.util.NestedServletException: Handler dispatch failed; nested exception is java.util.ServiceConfigurationError: org.geoserver.web.GeoServerNodeInfo: service type not accessible to unnamed module @2de2cc8a
It came up OK with openjdk8: Oracle Corporation: 1.8.0_181 (OpenJDK 64-Bit Server VM)
• GeoServer Version 2.14.1
• Git Revision 499990d642d60e6043f3d44deb26ac6172a4e885
• Build Date 20-Nov-2018 02:04
• GeoTools Version 20.1 (rev ef377c748a46efd4a84bfa0df939aac71ade0863)
• GeoWebCache Version 1.14.1 (rev 1.14.x/4bb10e75710629ad5571e69b75684cf49256ad67)
I logged in, tried a couple of layer previews, checked that at least some of the GetCapabilities looked OK.
Added the WPS and CSW plugins, checked those capabilities worked.
Seems OK based on initial smoke testing.
Well known, the first version that can run on jdk 11 will be 2.15.0, based on all the work with did in the code sprint (definitely
not backportable, too many changes, and many non backwards compatible for programmers using geotools or making
geoserver plugins)
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Yep. The ticket above however, I don’t see the point of having it, we have a custom environment based on a way outdated version of the WFS 1.1 tests, there is nothing OGC/lat-lon can do about it.
It’s like something coming to us and asking support for a customized GeoServer 2.2 version…
Yeah, it was created at the time, but isn’t likely to actually get fixed; its mostly just something convenient to point to that actually has details of the issue.
Torben
On Mon, Nov 19, 2018 at 11:07 PM Andrea Aime <andrea.aime@anonymised.com1268…> wrote:
On Tue, Nov 20, 2018 at 12:28 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
It’s like something coming to us and asking support for a customized GeoServer 2.2 version…Cheers
Andrea==
Thanks for testing!
This is still the 2.14 series, we will not have a java 11 compatible release for a while yet
Jody Garnett
