[Geoserver-devel] Release volunteer for July needed
A release volunteer for the July update is welcomed - do you have time to help? The release schedule is here https://github.com/geoserver/geoserver/wiki/Release-Schedule
I also note that foss4g is occurring right around when we make the RC; I am considering making a milestone release for a foss4g workshop (if that is okay with everyone).
We also made the idea of making the 2.22 release Java 11 and Java 17 only (dropping java 8) but this is waiting on a proposal…
Jody Garnett
I trust those in the norther hemisphere are enjoying summer.
I have capacity to make the 2.21.1 release this week and announce Monday the 18th (ie on schedule).
I would ask that https://github.com/geoserver/geoserver/pull/6057 be accepted and backported for this release (as there is an issue with request logging affecting my customers).
Jody
Jody Garnett
Dear Jody, all,
My apologies, I know that it is too late to request an early backport at this stage, but do you think there is a chance to have this GEOT-7173 accepted for early backport on gt 27.x before the release?
The improvement adds three connection parameters to an OracleNG DataStore to be able to set timeouts on login and on socket connections to the database. Doesn’t alter the behaviour of the store if those connection properties are unset. It should be then safe to backport it.
Marco Volpini
Visit http://bit.ly/gs-services-us for more information.
Marco Volpini
Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I am happy if you do an early backport +1
Presently waiting on PR #6057 review so you have time.
Jody Garnett
Tried a straight backport bot PR and it does not compile. Perhaps you can have a look (I do not have oracle presently available to test against).
Jody Garnett
Jody Garnett
Thanks Jody I was doing the backport right now let me check.
Marco Volpini
Marco Volpini
Software Engineer
GeoSolutions Group
Having build issues due to recent build structure change see https://osgeo-org.atlassian.net/browse/GEOS-10588 for details.
Jody Garnett
Jody Garnett
