[Geoserver-devel] Release volunteer needed for Nov 18th timeframe
The release schedule has been updated:
https://github.com/geoserver/geoserver/wiki/Release-Schedule
We are seeking a release volunteer for November 18th release. This 2.22.0 update should be a normal stable release, all the jobs are working with the possible exception of windows-installer (which needs updated credentials). The blog post is mostly cut and paste from the 2.22-RC (with the addition of thanking volunteers for testing).
The only special work should be adjusting 2.22.x to stable, and 2.21.x branch to maintenance.
Jody Garnett
Hi Jody,
me and Martha can work on it, if she’s given enough credentials. See the other thread “Introducing Martha Nagginda”
On Fri, Oct 28, 2022 at 4:47 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Geoserver-devel mailing list
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Thanks Andrea that is much appreciated.
I am turning up some bugs today in testing, and we still do not have a good answer on the linux logging issue; I expect we should make a jira ticket and have it as a “known” issue for the release in the hopes of learning more.
Jody
Jody Garnett
I created a ticket https://osgeo-org.atlassian.net/browse/GEOS-10744 but I am sort of a man-in-a-middle because I only have access to the Geoserver web UI on the problematic servers.
-Jukka-
Lähettäjä: Jody Garnett jody.garnett@anonymised.com
Lähetetty: keskiviikko 9. marraskuuta 2022 18.34
Vastaanottaja: Andrea Aime andrea.aime@anonymised.com
Kopio: GeoServer geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Release volunteer needed for Nov 18th timeframe
Jody
On Wed, Nov 9, 2022 at 8:25 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
On Fri, Oct 28, 2022 at 4:47 PM Jody Garnett <jody.garnett@anonymised.com3…> wrote:
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea:
Here is a fix https://github.com/geoserver/geoserver/pull/6333 for the bug encountered during testing. Same deal as with the recent “minimal” data directory issue - if the services are not named “WFS”, “WMS”, “WMTS” sections of the codebase fail to work. In this case it was DisabledServiceResourceFilter which was making the assumption about service naming. The fix is to add ServiceInfo.getType() so the codebase stops making assumptions about ServiceInfo.getName().
I plan to do one documentation update (screen snaps) prior to release; but I think we should be good to go.
Jody Garnett
