[Geoserver-devel] remove fr and en docs?
The en docs are just a placeholder with a single index.rst file
The fr were created 8 years ago and updated 4 years ago.
Near as I can tell nobody is building this content for release.
Jody Garnett
Eeek, why do you want to remove the en docs!!!
I think you meant the es docs :wink:
And yes, both es and fr have been stable for… ever… so +1 to remove them
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Ha ha, yes the es and fr docs - not even being built these days.
Jody Garnett
+1 (non PSC), if anyone which t recover them they will be in Git history.
Jody Garnett
PR is available https://github.com/geoserver/geoserver/pull/3694 for review.
Also updated CCbyA license to version 4.0 markdown.
Jody Garnett
