[Geoserver-devel] Removed backup-restore from communityRelease profile
Alessio,
I removed backup-restore from the communityRelease profile because it does not compile.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
The backup-restore PR has been merged before all its dependencies have been merged.
In this specific case, the https://github.com/geoserver/geoserver/pull/1664 must be merged before backup-restore otherwise it won’t compile.
On Thu, Jul 28, 2016 at 5:04 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Alessio,
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
On Thu, Jul 28, 2016 at 9:31 AM, Alessio Fabiani <
been merged.
backup-restore otherwise it won't compile.
My fault, I thought I merged that one and instead merged the backport on
2.9.x (having both master pull and backport at the same time confused me).
I reverted the backport and merged the right one
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Thanks, Andrea. That fixed the compilation of backup-restore for me so I added it back to the communityRelease profile.
Kind regards,
Director
New Zealand
There is nothing in our Travis CI configuration to test whether a build with -DskipTests -PcommunityRelease succeeds. This means that we will not find out if a pull request targeting a community module breaks Jenkins on ares until it is merged.
Travis CI allows multiple script commands. At the cost of slower builds, would it be worthwhile to add coverage of communityRelease. The manual also documents the use of a "&&" short circuit to fail fast:
https://docs.travis-ci.com/user/customizing-the-build/
I think fail-fast is more appropriate as there is no point building with -PcommunityRelease as with two mvn commands there is not reactor to coordinate module dependencies.
I will make a pull request for your consideration.
Kind regards,
Director
New Zealand
Add Travis CI coverage of communityRelease profile
https://github.com/geoserver/geoserver/pull/1720
Kind regards,
Director
New Zealand
