I removed the doc exclusion for Git polling on the geoserver-master Jenkins job. Something appears to be horribly wrong with it. The symptoms are that polling *always* detects changes, so there is always a geoserver-master in the queue. Hopefully this will stop the flood of unnecessary builds.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
unnecessary builds.
Kind regards,
Director
New Zealand
I have removed the doc and geogig Git polling exclusions on geoserver-master Jenkins. As discussed last year (see below), Git polling exclusions are broken: they cause continual retriggering of the geoserver-master build, waste resources, and delay other builds. Please do not add Git polling exclusions on any Jenkins build.
Kind regards,
Director
New Zealand
Thanks for the info, I wasn’t aware of the issues.
It seems the exclusions are still in place for the other builds (2.11.x, 2.10.x and 2.9.x). I can remove them on those builds too, unless it is desired to keep them.
On Sun, Apr 9, 2017 at 7:56 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
I removed the doc exclusion for Git polling on the geoserver-master Jenkins job. Something appears to be horribly wrong with it. The symptoms are that polling always detects changes, so there is always a geoserver-master in the queue. Hopefully this will stop the flood of unnecessary builds.
Is this something fixed with newer versions of Jenkins?
thanks for pointing that out. I have removed the exclusions for 2.11.x and 2.10.x, even though they have not yet caused trouble. This gives us consistency between the builds.
Also, I see no reason to exclude docs and geogig as developers may be building them locally. Leaving them included will allow Jenkins to detect breakage.
Kind regards,
Ben.
On 11/04/17 03:38, Erik Merkle wrote:
Ben,
Thanks for the info, I wasn't aware of the issues.
unnecessary builds.
Kind regards,
Director
New Zealand
Director
New Zealand
Unknown. I have not found a bug report that matches our situation. As I mentioned in my previous email, I do not see why we are excluding commits to docs and geogig in the first place. Shall we just leave them in?
Kind regards,
Ben.
Jody Garnett
unnecessary builds.
Kind regards,
Director
New Zealand
Director
New Zealand
For docs at least, there was an effort to separate the doc build and the code build so if a doc change was made we would only build the docs, and if a code change was made we would only build the code. Consequently, the docs are excluded from the polling for the main builds.
See the *-live-docs builds for the doc portion of this.
