with this mail I want to discuss the eventual removal of the ASCII grid
output format from the WCS codebase.
The output format produces the classic ESRI ASCII grid, a text based export format suitable only for single banded raster data.
I was discussing with Simone about it, and we are skeptical about its current usefulness:
Limited functionality, due to single band support
Inefficient format, and inefficient implementation (dumps to file first, streams out later, inviting timeouts)
Difficult to discover MIME, it’s reported as “application/x-gzip” along the output formats
Unaware of significant usage in the wild
The GML grid output format provides a better alternative, still human readable, but human readable and can be streamed
If you disagree, we’d like to hear why.
If you agree, what option should we follow? Two ideas: -
Simple code removal, not worth spending extra effort
Migration to community module, to provide soft landing for those that might have been using it
Thoughts?
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
