following up this report:
https://jira.codehaus.org/browse/GEOS-6589
I did some checks, and it seems to me we don’t need digester
anymore, I just removed it from the pom, did a full build,
and it worked.
Objections/concerns about removing that dependency?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
None here. The more dependencies we can remove from core modules the better imo.
On Fri, Jul 25, 2014 at 4:10 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
and it worked.
Ing. Andrea Aime
@geowolf
Technical Lead
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
On Fri, Jul 25, 2014 at 4:29 PM, Justin Deoliveira <
better imo.
Removed it.
Then I had a look with mvn dependency:analyze, the plugin can apparenlty
find unused dependencies
(well, sort of, it cannot spot stuff that we depend on via spring).
The output is:
[WARNING] Unused declared dependencies found:
[WARNING] commons-fileupload:commons-fileupload:jar:1.2.1:compile
[WARNING] commons-httpclient:commons-httpclient:jar:3.1:compile
[WARNING] commons-validator:commons-validator:jar:1.1.4:compile
[WARNING] oro:oro:jar:2.0.8:compile
[WARNING] org.geotools:gt-validation:jar:12-SNAPSHOT:compile
[WARNING] org.geotools:gt-data:jar:12-SNAPSHOT:compile
[WARNING] org.geotools:gt-epsg-hsql:jar:12-SNAPSHOT:compile
[WARNING] org.springframework:spring-aop:jar:3.1.4.RELEASE:compile
[WARNING] cglib:cglib-nodep:jar:2.2:test
[WARNING] org.geotools:gt-arcgrid:jar:12-SNAPSHOT:test
[WARNING] org.geotools:gt-gtopo30:jar:12-SNAPSHOT:test
[WARNING] org.geotools:gt-image:jar:12-SNAPSHOT:test
[WARNING] org.geotools.jdbc:gt-jdbc-postgis:jar:12-SNAPSHOT:test
[WARNING]
org.springframework.security:spring-security-config:jar:3.1.0.RELEASE:compile
[INFO]
While there is some obvious stuff we depend on via spring, or that is there
because we have some test data using it in other modules, there is
also stuff that I believe could be dropped, such as:
- oro
- gt-validation
- commons-validation
Going to make some full builds and see if there is anything else we can drop
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Jul 26, 2014 at 12:04 PM, Andrea Aime <andrea.aime@anonymised.com>
- oro
- gt-validation
drop
All right, got a few more that seemed obvious candidates to drop, here is
a pull request:
https://github.com/geoserver/geoserver/pull/665
Ing. Andrea Aime
@geowolf
Technical Lead
Nice. One step in the right direction towards a leaner meaner GeoServer
+1
On Sat, Jul 26, 2014 at 11:00 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Justin Deoliveira
@boundlessgeo
On Sat, Jul 26, 2014 at 12:04 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
a pull request:
Ing. Andrea Aime
@geowolf
Technical Lead
- oro
- gt-validation
Having run into this issue myself on other projects, are there any dependencies that can be marked with scope test to prevent them in the final jar/war?
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
(attachments)
+1
oro
gt-validation
commons-validation
a pull request:
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
jdeolive@…3839…
@boundlessgeo
On Mon, Jul 28, 2014 at 3:54 PM, Chris Snider <chris.snider@anonymised.com>
wrote:
final jar/war?
I've removed a few others in this pull request:
https://github.com/geoserver/geoserver/pull/665/files
If you find others that you think could be removed because unused, please
let us know.
I also believe there might be other depedencies that could be removed by
reworking the small
bits of code using them, of course that is a lot riskier, but I believe
we're open to it if you
can show a dependency is causing troubles, and you have time to work on a
pull request
to rework the code
Ing. Andrea Aime
@geowolf
Technical Lead
