I'm trying to render a raster stacked over several vector layers as a single
WMS layer.The raster renders perfectly fine when it is fetched as a separate
WMS layer but I'm having several issues including the raster appearing as a
black rectangle over the vector layers and disappearing as I zoom in . What
are the properties that need to be specifically set in the SLD (For ex
GammaValue, Histogram etc) so that the raster is rendered perfectly stacked
over vector layers.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rendering-rasters-stacked-over-vectors-as-WMS-tp5143871.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
This is the developer list. You’d probably be better served asking on the geoserver-users mailing list.
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 3 June 2014 23:46, srinaath27 <sravichandran@anonymised.com> wrote:
I’m trying to render a raster stacked over several vector layers as a single
WMS layer but I’m having several issues including the raster appearing as a
over vector layers.
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/NeoTech
Geoserver-devel mailing list
