today I had a serious look at freemarker and the template
loading subsystem.
Overall it's very nice, but I found something that may cause
either performance or functionality issues.
At the moment we have a GeoserverTemplateLoader, that can be
configured with a class and a feature type name to alter they
way it'll look for a template file. The freemarker configuration
is handled as a static object in the KML writer, and its configured
with a different template loader instance each time.
Now, I don't know exactly how the freemarker internals do work,
but when we repeatedly call:
templateConfig.setTemplateLoader(templateLoader);
template = templateConfig.getTemplate("kmlDescription.ftl");
I gues we either:
* make the config throw away its template cache, which is bad from
a performance point of view. Template parsing is expensive, we don't want to do that for each call.
* if the templateconfig does not wipe out its internal cache, make the config return a cached version which may not be the one we're looking
for (maybe it has cached the generic template and now we need a feature type specific one).
I may be wrong, since I haven't checked the freemarker sources,
but in my opinion we should create a Configuration subclass that exposes a getTemplate(class, typeName, templatePath) method, and use that to locate the template and do "the right thing" when it comes to cache stuff. It would also allow to have a Geoserver global cache, which may
be useful if there are lots of templates (again, I don't know how this
works in the freemarker internal, but it may be that their cache is
made with hard references and based on a LRU, size limited, list).
Comments?
Hi Andrea,
The cache is stored with the Configuration, not with the TemplateLoader
so I think we are ok on that one. The issue about hitting the cached
"generic" version of the template when a featureType specific one has
been added is legitimate though, never thought about that case.
Lucky for us the caching implementations in freemarker are pluggable
with a hard, soft, and mru implementation to choose from, with the
default being mru.
I think we could solve this problem by writing a decorating cache that
wrap up another caching implementation but recognize the case above.
-Justin
Andrea Aime wrote:
loading subsystem.
I gues we either:
type specific one).
Comments?
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Justin Deoliveira ha scritto:
Hi Andrea,
default being mru.
Hmmm... Configuration does not know about the feature type, and the
cache is fed with keys that look like:
new TemplateKey(name, locale, encoding, parse);
I don't see how we can put the feature type in the mix... maybe we
could abuse the template name and encode it somehow, for example
by having a name looking like a http get request:
featureType=xxx&path=yyy
That could be hidden behind an utility class, to shield users from
this mess.
