It looks like connections to repo.boundless.com are timing out. I did not expect to see this artifact here, but the connection is timing out:
[ERROR] Failed to execute goal on project gs-geofence-server: Could not resolve dependencies for project org.geoserver.community:gs-geofence-server:jar:2.8-SNAPSHOT: Failed to collect dependencies at wicket-dnd:wicket-dnd:jar:0.4.2: Failed to read artifact descriptor for wicket-dnd:wicket-dnd:jar:0.4.2: Could not transfer artifact wicket-dnd:wicket-dnd:pom:0.4.2 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
It is working fine for me here. I am able to access the web frontend, as well as ssh onto the instance.
Could you please let me know if you are still having issues?
Chris
On Mon, Aug 1, 2016 at 9:59 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
[ERROR] Failed to execute goal on project gs-geofence-server: Could not resolve dependencies for project org.geoserver.community:gs-geofence-server:jar:2.8-SNAPSHOT: Failed to collect dependencies at wicket-dnd:wicket-dnd:jar:0.4.2: Failed to read artifact descriptor for wicket-dnd:wicket-dnd:jar:0.4.2: Could not transfer artifact wicket-dnd:wicket-dnd:pom:0.4.2 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out → [Help 1]
Thanks, Chris. I repeated a test build for a troublesome module and I can confirm that repo.boundless.com is now working perfectly! Just a temporary issue, perhaps?
Kind regards,
Ben.
On 02/08/16 14:16, Christian Del Pino wrote:
Hi Ben,
Chris
artifact wicket-dnd:wicket-dnd:pom:0.4.2 from/to boundless ( https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443
[Help 1]
Kind regards,
Director
New Zealand
Director
New Zealand
Thanks for the quick reply. Yes, hopefully just a minor hiccup somewhere.
Chris
On Mon, Aug 1, 2016 at 10:24 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Kind regards,
Ben.
Hi Ben,
Chris
[Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gwc-web: Failed to deploy artifacts: Could not transfer artifact org.geowebcache:gwc-web:jar:1.10-20160802.024042-75 from/to boundless (https://repo.boundlessgeo.com/snapshot/): TransferFailedException: ClientProtocolException: Cannot retry request with a non-repeatable request entity. The cause lists the reason the original request failed. Connection timed out -> [Help 1]
Kind regards,
Ben.
Chris
Kind regards,
Ben.
Hi Ben,
Chris
transfer
[Help 1]
Kind regards,
Director
New Zealand
Director
New Zealand
Director
New Zealand
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gwc-web: Failed to deploy artifacts: Could not transfer artifact org.geowebcache:gwc-web:jar:1.10-20160802.024042-75 from/to boundless (https://repo.boundlessgeo.com/snapshot/): TransferFailedException: ClientProtocolException: Cannot retry request with a non-repeatable request entity. The cause lists the reason the original request failed. Connection timed out → [Help 1]
Kind regards,
Ben.
Chris
Kind regards,
Ben.
Hi Ben,
Chris
transfer
[Help 1]
org.geowebcache:gwc-web:jar:1.10-20160802.024042-75 from/to boundless ( https://repo.boundlessgeo.com/snapshot/): TransferFailedException:
Kind regards,
Ben.
Chris
Kind regards,
Ben.
Hi Ben,
Chris
not
transfer
[Help 1]
Kind regards,
Director
New Zealand
Director
New Zealand
Director
New Zealand
Director
New Zealand
This seems to be a thing again... I'm getting time-outs now as well. Is this
something you can still look into? Seemed to start failing around May 12 of
this year (2019).
