repo DNS was changed yesterday, as per meeting - so far ares is building/deploying as expected!
If you deploy you will need to update your settings.xml file with a new “api key”, talk to Chris if you have not already been contacted (or if you need the ability to deploy new third party jars).
This is just a DNS change, no changes to maven pom.xml files are expected.
