it seems we have builds failing due to some artifacts missings and/or repos missing.
Groovy community module is failing to build because or a vector tiles dependency?
[ERROR] Failed to execute goal on project gs-script-groovy: Could not resolve dependencies for project org.geoserver.script:gs-script-groovy:jar:2.8-SNAPSHOT: Failed to collect dependencies at org.geoscript:geoscript-groovy:jar:1.7-SNAPSHOT → no.ecc.vectortile:java-vector-tile:jar:1.0.9: Failed to read artifact descriptor for no.ecc.vectortile:java-vector-tile:jar:1.0.9: Could not transfer artifact no.ecc.vectortile:java-vector-tile:pom:1.0.9 from/to hibspat (http://www.hibernatespatial.org/repository): Connect to www.hibernatespatial.org:80 [www.hibernatespatial.org/62.213.201.148] failed: Connection timed out → [Help 1]
[ERROR]
Strangely as you can see it’s complaining about hibernatespatial.org, which is indeed down.
I checked and we are depending on a hibernate spatial version, in geofence, that’s quite
old (1.1) while maven central only has the latest (version 5).
Upgrading is not a short term option, we are going to try and deploy the jars in the
geosolutions maven repo, but not sure when it’s going to happen (like, not today…)
Anyone knows if hibernatespatial.org not being around is temporary, or if it’s just gone?
In the meantime if the build servers have the hibernatespatial jars in their local repos
(they should) we can just restore the build by commenting out the repo definition
for hibernatespatial in the main pom
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
