Jim you found a very old thready from 2016 to reply to, starting a new thread since we are on a new platform since then.
Checking our automated builds (and the developers who are awake) shows no problem. Do you have any more information? While our build infrastructure has been troubled since mid May I do not believe that has effected the repository in any way.
Jody Garnett
This seems to be a thing again… I’m getting time-outs now as well. Is this
something you can still look into? Seemed to start failing around May 12 of
this year (2019).
Thanks in advance,
–jim
Thanks for the quick response… Ya, I knew it was an old thread, but it was the most relevant search result. This is the error my server began experiencing a couple weeks ago while doing automated apt security updates. Other repos work fine; no firewall changes…:
The GeoServer community mailing lists do not provide support for commercial products - please contact Boundless for support relating to Boundless Suite.
I will say that that particular URL hasn’t been used in about 2 years, and you should remove it from your apt configuration.
Over 9,000 entries in my apt-security-updates log file since May 12.
Jim Hutchison
On Wed, Jun 5, 2019 at 1:10 PM Jody Garnett <[jody.garnett@anonymised.com](mailto:jody.garnett@...403...)> wrote:
> Jody Garnett
> > This seems to be a thing again... I'm getting time-outs now as well. Is this
> > this year (2019).
> > Thanks in advance,
> > --jim
Hi Jim,
as far as I know there is no replacement, the GeoServer community never provided APT packages, if Boundless (now Planet Federal)
says they dropped the commercial product associated to that repo, then you’re back getting releases like anyone else, from SourceForge packages
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
