[Geoserver-devel] Request for early backport of GEOS-10222
+1
I added couple of comments into https://github.com/geoserver/geoserver/pull/5265 but I agree that this new control does not change anything when not used.
-Jukka Rahkonen-
Lähettäjä: Daniele Romagnoli <daniele.romagnoli@…6887…>
Lähetetty: keskiviikko 8. syyskuuta 2021 12.56
Vastaanottaja: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: [Geoserver-devel] Request for early backport of GEOS-10222
Hi list,
GEOS-10222 (WFS CSV OutputFormat delimiter) has been contributed to main.
It provides support for a new format_options “csvseparator”.
We would like to backport it to 2.19.x since it doesn’t introduce any big change to the code (and it doesn’t change any behavior when not used), although the 1 month interim period hasn’t elapsed yet.
Any objections?
Daniele Romagnoli
Visit http://bit.ly/gs-services-us for more information.
Daniele Romagnoli
Senior Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
