On Sat, Feb 21, 2015 at 9:22 PM, Ellis, Scott - Exelis <
Scott.Ellis@anonymised.com> wrote:
Hi, we are writing geoserver extensions and trying to hide the concept
of a namespace from client code.
The code that emits the coverage id in DescribeCoverage responses for WCS
1.0 and 2.0 was extensible, and we were able to implement the behavior we
need.
However, for WCS 1.1, the fact that a namespace is prepended to a coverage
id with a colon delimeter is hardcoded here:
project: org.geoserver.gs-wcs1_1
org.geoserver.wcs.response.DescribeCoverageTransformer.java
protected void handleCoverageDescription(CoverageInfo ci) throws
Exception {
start("wcs:CoverageDescription");
element("ows:Title", ci.getTitle());
element("ows:Abstract", ci.getDescription());
handleKeywords(ci.getKeywords());
* element("wcs:Identifier",
ci.getStore().getWorkspace().getName() + ":" + ci.getName());*
handleMetadataLinks(ci.getMetadataLinks(), "simple");
handleDomain(ci);
handleRange(ci);
handleSupportedCRSs(ci);
handleSupportedFormats(ci);
end("wcs:CoverageDescription");
Could this line be changed to delegate returning the prefixed coverage id
to the CoverageInfo object? i.e.
* element("wcs:Identifier", ci.prefixedName());*
That way I could implement the behavior I need in my own CoverageInfo
object.
I don't mind the change, but you'll have to make a pull request. And I
suggest you think hard about how to add tests to lock down
this behavior, because a vanilla GeoServer does not really need it.
With many people contributing pull requests to GeoServer you basically
have only two types of behaviors, those that have tests failing
when you change them, and those that get broken, it's just a matter of
time...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
