[Geoserver-devel] Request logging
Request logging is always on and I cannot switch it off. It ignores changes in web.xml.
System:
Geoserver 2.0.2
Windows Vista 64
Java 1.6.0_20
Tony
PS Forgeot to add – using Binary (OS independent) version of Geoserver.
Hi Tony,
What exactly are you changing? Afaik there are two forms of request logging that occur when running in the jetty container. One via a GeoServer filter (Which is turned off via web.xml) and one via jetty itself. If you go into the jetty/etc/jetty.xml file of the geoserver install and search for reqestLog, you should see it.
Hope that helps.
-Justin
changes in web.xml.
System:
Geoserver 2.0.2
Windows Vista 64
Java 1.6.0_20
Tony
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
