Dear List,
I would like to ask permission for an improvement on GUI table filter functionality on Admin lists. A filtered admin list will retain its filter until user clears the filter or uses the left navigation menu. More detail can be found at https://osgeo-org.atlassian.net/browse/GEOS-9346
regards,
Imran
I.R
Hi Imran,
the PR was merged in October and I don’t see any backwards compatibility issue, so +1.
Bets regards,
On Mon, 2020-01-13 at 18:32 +0500, Imran Rajjad wrote:
Dear List,
regards,
Imran
Geoserver-devel mailing list
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
+1, but will hold it to after the 2.16.2 release. Please make the backport PR as soon as 2.16.2 is done
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
