[Geoserver-devel] Request to backport to 2.16.x [GEOS-9360] Ability to log processing time per layer
Dear all,
I would like to ask the permission to backport to 2.16.x an improvement that allows the logging of layers’ and labels’ rendering times. More informations here https://osgeo-org.atlassian.net/browse/GEOS-9360.
Best regards,
Marco Volpini
Hi Marco,
if I’m not mistaken all this issue are related:
Anyway, looks a stable and well tested feature, +1
Best regards,
Nuno Oliveira
On Mon, 2020-01-13 at 13:48 +0100, Marco Volpini wrote:
Dear all,
Best regards,
Marco Volpini
Geoserver-devel mailing list
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
+1, but will hold it to after the 2.16.2 release. Please make the backport PR as soon as 2.16.2 is done
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
