[Geoserver-devel] Request to merge pull request #111
This pull request updates /corrects the REST API documentation. I know that we are in the middle of a release process, so I just wanted to ask (specifically Andrea) if it's okay if I go ahead and merge it in, or whether I should wait.
https://github.com/geoserver/geoserver/pull/111
Mike Pumphrey
OpenGeo - http://opengeo.org
I think you should be fine here Mike. I think jody is going to be trying a 2.3 release again tonight but this shouldn’t conflict.
On Tue, Jan 22, 2013 at 11:44 AM, Mike Pumphrey <mike@anonymised.com> wrote:
This pull request updates /corrects the REST API documentation. I know that we are in the middle of a release process, so I just wanted to ask (specifically Andrea) if it’s okay if I go ahead and merge it in, or whether I should wait.
Mike Pumphrey
Justin Deoliveira
Hi Mike,
I think we have missed (cutted off) some pieces of documentation during this “Improved / corrected REST documentation (see GEOS-5595)” refactoring (regarding the about/version about/manifest improvements):
please take a look to:
on branch 2.2.x - the commit “619156c0e2a0946b58ea0e3877dfda806417300d” “adding documentation”
on branch master - the commit ‘54eebfb03058538e34c47e05f08f2450d76a347e’ “adding documentation”
To marge missing part of the documentation.
Carlo
2013/1/23 Justin Deoliveira <jdeolive@anonymised.com>
Mike Pumphrey
Justin Deoliveira
Hello Carlo. My apologies, I'm sorry to have overwritten your work. That does explain the strange conflicts I found when I tried to merge.
I'm not excellent at figuring out diffs manually, but looking at that commit, I see that the primary difference is the "About" section. Did I miss something else? Please let me know, and I'll copy the section(s) back in.
Mike Pumphrey
On 1/24/2013 6:49 AM, carlo cancellieri wrote:
Hi Mike,
this "Improved / corrected REST documentation (see GEOS-5595)" refactoring
on branch 2.2.x - the commit "619156c0e2a0946b58ea0e3877dfda806417300d"
  "adding documentation"
on branch master - the commit '54eebfb03058538e34c47e05f08f2450d76a347e'
Carlo
2.3 release again tonight but this shouldn't conflict.
https://github.com/geoserver/**geoserver/pull/111&lt;https://github.com/geoserver/geoserver/pull/111&gt;
Mike Pumphrey
Justin Deoliveira
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only -- learn more at:
http://p.sf.net/sfu/learnnow-d2d
Geoserver-devel mailing list
Mike,
I’m not excellent at figuring out diffs manually, but looking at that commit, I see that the primary difference is the “About” section. Did I miss something else? Please let me know, and I’ll copy the section(s) back in.
We are lucky, I used a different commit only for docs.
Looking at the diffs you’ll note a new set of files here:
doc/en/user/source/restconfig/representations/*.txt
And some additions (regarding ‘about’) to the file:
doc/en/user/source/restconfig/rest-config-api.rst
That’s it.
Carlo
Mike Pumphrey
Hi Mike,
Carlo
https://github.com/geoserver/**geoserver/pull/111<https://github.com/geoserver/geoserver/pull/111>
Mike Pumphrey
Justin Deoliveira
MVPs and experts. ON SALE this month only – learn more at:
Geoserver-devel@anonymised.comsourceforge.net
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
mobile: +39 3371094494
Thanks. I will add back in the About content.
After some conversation a while back, I made the decision to remove the representation files from the docs as part of this update. Reasons being that they are an administrative hassle to keep correct (there were dozens of them, and many of them were wrong / out-of-date), and I felt like they were redundant when you could just execute the request and see. (Similar reasoning would be why we don't include copies of the capabilities documents in the docs.) So unless you strongly disagree, I'd like to leave the representation files out, and just port the About content. I'll let you know when I've done this.
Mike Pumphrey
On 1/25/2013 1:34 AM, carlo cancellieri wrote:
Mike,
in.
Looking at the diffs you'll note a new set of files here:
And some additions (regarding 'about') to the file:
That's it.
Carlo
Mike Pumphrey
Hi Mike,
on branch 2.2.x - the commit "**619156c0e2a0946b58ea0e3877dfda**
806417300d"
on branch master - the commit '**54eebfb03058538e34c47e05f08f24**
50d76a347e'
Carlo
a
https://github.com/geoserver/****geoserver/pull/111&lt;https://github.com/geoserver/**geoserver/pull/111&gt;
<https://**github.com/geoserver/**geoserver/pull/111<https://github.com/geoserver/geoserver/pull/111>
Mike Pumphrey
Justin Deoliveira
http://p.sf.net/sfu/learnnow-**d2d <http://p.sf.net/sfu/learnnow-d2d&gt;
______________________________**_________________
Geoserver-devel@anonymised.com**sourceforge.net<Geoserver-devel@lists.sourceforge.net>
https://lists.sourceforge.net/**lists/listinfo/geoserver-devel&lt;https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;
Also, what version does this about/manifest functionality work against? I've got 2.2.4 installed, and I don't seem to have that endpoint at all. Commands like this:
http://localhost:8080/geoserver/rest/about/manifest.xml?key=GeoServerModule&value=extension
don't respond with anything other than the generic rest interface. Is this a 2.3.x feature or did this happen after 2.2.4?
There's a good chance I just don't follow what's going on. But as long as I was (re-)adding documentation, I figured I'd test it out. Thanks.
Mike Pumphrey
Mike,
in.
That's it.
Carlo
Mike Pumphrey
Hi Mike,
806417300d"
50d76a347e'
Carlo
a
Mike Pumphrey
Justin Deoliveira
Mike,
I agree with you. Note that I also added some cURL examples.
Carlo
2013/1/25 Mike Pumphrey <mike@anonymised.com…1501…>
After some conversation a while back, I made the decision to remove the representation files from the docs as part of this update. Reasons being that they are an administrative hassle to keep correct (there were dozens of them, and many of them were wrong / out-of-date), and I felt like they were redundant when you could just execute the request and see. (Similar reasoning would be why we don’t include copies of the capabilities documents in the docs.) So unless you strongly disagree, I’d like to leave the representation files out, and just port the About content. I’ll let you know when I’ve done this.
Mike Pumphrey
Mike,
in.
That’s it.
Carlo
Mike Pumphrey
Hi Mike,
806417300d”
50d76a347e’
Carlo
a
https://github.com/geoserver/****geoserver/pull/111<https://github.com/geoserver/**geoserver/pull/111>
Mike Pumphrey
Justin Deoliveira
http://p.sf.net/sfu/learnnow-**d2d <http://p.sf.net/sfu/learnnow-d2d>
_____________**
https://lists.sourceforge.net/**lists/listinfo/geoserver-devel<https://lists.sourceforge.net/lists/listinfo/geoserver-devel>
@cancellieric
Software Engineer
Hi Mike,
see inline.
I have a few additional questions, but they may be answered when I actually try out the software, but I can’t seem to find where it is. Some questions that come to mind:
  • When entering rest/about/manifest.xml?.., what happens when the key value pair is omitted? The docs don’t say.
The default format is [.html] so when you point to rest/about/manifest you get the same result as per rest/about/manifest.html. You’ll get a list of all the manifest files (with properties) of all the jars loaded by the classloader.
  • Where is the manifest.properties file placed?
It is located into the main jar of the geoserver core. If you want to change (override) default settings you have to place a copy of that file (with your changes) into the GeoServer Data dir (root).
  • There are two different endpoints in this section, about/manifest, and about/version. How are they related? What would I call both of them together? “About” seems a bit non-specific.
When you ask to geoserver (via web gui) for the about page you simply get the versions of the main used components.
Something like:
  • 2.2-SNAPSHOT
  • 8d37359c56b8cb07d560d600fe1cd76db7236619
  • 25-Jan-2013 02:50
  • 8-SNAPSHOT (rev d64d6a20e83ed60dc6e5ffea564a0c38e88ed4d2)
This is more or less the same of what you get using about/version.
The about/manifest[.format] instead is a more detailed list of version (with all the loaded libraries) which can be used for reports or to check configuration programmatically (for example in Continuous Integration).
I added the filter capabilities to be able to filter by core, extensions, communities and customized jars (in the way I show you in the examples).
It might seem a little slow and laborious, but I’ve found that this kind of back-and-forth really helps to make clear, quality documentation. (I’m documentation lead at OpenGeo.) If you have any questions, please let me know. I appreciate your help!
I know, documentation really important for software, so no problem Mike, nice to meet you :slight_smile:
Also, what version does this about/manifest functionality work against? I’ve got 2.2.4 installed, and I don’t seem to have that endpoint at all. Commands like this:
don’t respond with anything other than the generic rest interface. Is this a 2.3.x feature or did this happen after 2.2.4?
It will be available since 2.2.5 and 2.3.0
Thank you,
Carlo
There’s a good chance I just don’t follow what’s going on. But as long as I was (re-)adding documentation, I figured I’d test it out. Thanks.
Mike Pumphrey
Mike,
in.
That’s it.
Carlo
Mike Pumphrey
Hi Mike,
806417300d”
50d76a347e’
Carlo
a
Mike Pumphrey
Justin Deoliveira
_____________**
@cancellieric
Software Engineer
Great, I think I have all my questions answered now. Please see https://github.com/geoserver/geoserver/pull/126. If no changes are necessary, please accept and port to master as well (or I can do that). Thanks!
Mike Pumphrey
On 1/29/2013 2:26 AM, carlo cancellieri wrote:
Hi Mike,
  see inline.
try out the software, but I can't seem to find where it is. Some questions
that come to mind:
* When entering rest/about/manifest.xml?..., what happens when the key
value pair is omitted? The docs don't say.
get the same result as per rest/about/manifest.html. You'll get a list of
classloader.
* Where is the manifest.properties file placed?
* There are two different endpoints in this section, about/manifest, and
together? "About" seems a bit non-specific.
Something like:
    - Version2.2-SNAPSHOT
    - Git Revision8d37359c56b8cb07d560d600fe1cd76db7236619
    - Build Date25-Jan-2013 02:50
    - GeoTools Version8-SNAPSHOT (rev
It might seem a little slow and laborious, but I've found that this kind
of back-and-forth really helps to make clear, quality documentation. (I'm
Commands like this:
http://localhost:8080/**geoserver/rest/about/manifest.**
xml?key=GeoServerModule&value=**extension<http://localhost:8080/geoserver/rest/about/manifest.xml?key=GeoServerModule&value=extension&gt;
Thank you,
Carlo
Mike Pumphrey
Mike,
back
in.
doc/en/user/source/restconfig/**representations/*.txt
doc/en/user/source/restconfig/**rest-config-api.rst
That's it.
Carlo
Mike Pumphrey
Hi Mike,
during
refactoring
on branch 2.2.x - the commit "****619156c0e2a0946b58ea0e3877dfda****
806417300d"
on branch master - the commit '****54eebfb03058538e34c47e05f08f24****
50d76a347e'
Carlo
trying
a
know
ask
https://github.com/geoserver/******geoserver/pull/111&lt;https://github.com/geoserver/****geoserver/pull/111&gt;
<https://**github.com/geoserver/****geoserver/pull/111<https://github.com/geoserver/**geoserver/pull/111>
<https://**github.com/**geoserver/**geoserver/pull/111<http://github.com/geoserver/**geoserver/pull/111&gt;
**<https://github.com/geoserver/**geoserver/pull/111&lt;https://github.com/geoserver/geoserver/pull/111&gt;
Mike Pumphrey
Justin Deoliveira
current
http://p.sf.net/sfu/learnnow-****d2d&lt;http://p.sf.net/sfu/learnnow-**d2d&gt;&lt;
______________________________****_________________
Geoserver-devel@anonymised.com**source**forge.net <http://sourceforge.net><
Geoserver-devel@**lists.sourceforge.net<Geoserver-devel@lists.sourceforge.net>
https://lists.sourceforge.net/****lists/listinfo/geoserver-**devel&lt;https://lists.sourceforge.net/**lists/listinfo/geoserver-devel&gt;
<https://lists.**sourceforge.net/lists/**listinfo/geoserver-devel<https://lists.sourceforge.net/lists/listinfo/geoserver-devel>
Mike,
Ok looks good, but still missing the curl examples, don’t know if you want to include them; if so, take a look here:/en/user/source/restconfig/rest-config-examples/rest-config-examples-curl.rst
https://github.com/ccancellieri/geoserver/commit/d437d1544d389030d2c375b47a837cc71095ef4d
Thank you,
Carlo
2013/1/29 Mike Pumphrey <mike@anonymised.com>
Mike Pumphrey
Hi Mike,
see inline.
that come to mind:
classloader.
Something like:
  • Version2.2-SNAPSHOT
  • Git Revision8d37359c56b8cb07d560d600fe1cd76db7236619
  • Build Date25-Jan-2013 02:50
  • GeoTools Version8-SNAPSHOT (rev
Commands like this:
xml?key=GeoServerModule&value=**extension<http://localhost:8080/geoserver/rest/about/manifest.xml?key=GeoServerModule&value=extension>
Thank you,
Carlo
Mike Pumphrey
Mike,
back
in.
That’s it.
Carlo
Mike Pumphrey
Hi Mike,
during
refactoring
806417300d”
50d76a347e’
Carlo
trying
a
know
ask
https://github.com/geoserver/******geoserver/pull/111<https://github.com/geoserver/****geoserver/pull/111>
<https://**github.com/**geoserver/**geoserver/pull/111<http://github.com/geoserver/**geoserver/pull/111>
**<https://github.com/geoserver/**geoserver/pull/111<https://github.com/geoserver/geoserver/pull/111>
Mike Pumphrey
Justin Deoliveira
current
http://p.sf.net/sfu/learnnow-****d2d<http://p.sf.net/sfu/learnnow-**d2d><
_____________****
Geoserver-devel@anonymised.comsourceforge.net <http://sourceforge.net><
Geoserver-devel@**lists.sourceforge.net<Geoserver-devel@anonymised.comrge.net>
https://lists.sourceforge.net/****lists/listinfo/geoserver-**devel<https://lists.sourceforge.net/**lists/listinfo/geoserver-devel>
@cancellieric
Software Engineer
Whoops, that's right, you did say that.
Okay, I took those examples, did some copyediting on them and fixed the Sphinx errors, and added them to the pull request. If it looks good to you, I'll commit on 2.2.x, master, and the newly-created 2.3.x.
Mike Pumphrey
On 1/30/2013 3:26 AM, carlo cancellieri wrote:
Mike,
Ok looks good, but still missing the curl examples, don't know if you want
Thank you,
Carlo
https://github.com/geoserver/**geoserver/pull/126&lt;https://github.com/geoserver/geoserver/pull/126&gt;\.
Mike Pumphrey
Hi Mike,
  see inline.
actually
questions
that come to mind:
classloader.
Something like:
    - Git Revision8d37359c56b8cb07d560d6**00fe1cd76db7236619
    d64d6a20e83ed60dc6e5ffea564a0c**38e88ed4d2)
Commands like this:
http://localhost:8080/****geoserver/rest/about/manifest.****&lt;http://localhost:8080/**geoserver/rest/about/manifest.**&gt;
xml?key=GeoServerModule&value=****extension<http://localhost:**
8080/geoserver/rest/about/**manifest.xml?key=**GeoServerModule&value=**
Thank you,
Carlo
as
Mike Pumphrey
Mike,
I
back
in.
doc/en/user/source/restconfig/****representations/*.txt
doc/en/user/source/restconfig/****rest-config-api.rst
That's it.
Carlo
Mike Pumphrey
Hi Mike,
during
refactoring
on branch 2.2.x - the commit "******619156c0e2a0946b58ea0e3877dfda**
806417300d"
on branch master - the commit '******54eebfb03058538e34c47e05f08f24*
50d76a347e'
Carlo
trying
a
know
ask
or
https://github.com/geoserver/********geoserver/pull/111&lt;https://github.com/geoserver/******geoserver/pull/111&gt;
<https:**//github.com/geoserver/******geoserver/pull/111<https://github.com/geoserver/****geoserver/pull/111&gt;
<https://**github.com/**geoserver/****geoserver/pull/**111<http://github.com/geoserver/****geoserver/pull/111&gt;
<https://github.com/**geoserver/**geoserver/pull/111&lt;https://github.com/geoserver/**geoserver/pull/111&gt;
<https://**github.com/****geoserver/**geoserver/pull/111<http://github.com/**geoserver/**geoserver/pull/111&gt;
**<http://github.com/geoserver/****geoserver/pull/111&lt;http://github.com/geoserver/**geoserver/pull/111&gt;
**<https://github.com/**geoserver/**geoserver/pull/111&lt;https://github.com/geoserver/**geoserver/pull/111&gt;
Mike Pumphrey
Justin Deoliveira
CSS,
current
http://p.sf.net/sfu/learnnow-******d2d&lt;http://p.sf.net/sfu/learnnow-****d2d&gt;
<http://p.sf.net/sfu/**learnnow-**d2d&lt;http://p.sf.net/sfu/learnnow-**d2d&gt;
http://p.sf.net/sfu/learnnow-**d2d&lt;http://p.sf.net/sfu/learnnow-d2d&gt;
______________________________******_________________
Geoserver-devel@anonymised.com****source**forge.net <http://sourceforge.net
Geoserver-devel@**lists.**sourceforge.net<http://lists.sourceforge.net>
<Geoserver-**devel@lists.sourceforge.net<Geoserver-devel@lists.sourceforge.net>
https://lists.sourceforge.net/******lists/listinfo/geoserver-***
*devel<https://lists.sourceforge.net/****lists/listinfo/geoserver-**devel&gt;
<https://lists.**sourceforge.net/**lists/**listinfo/geoserver-devel<https://lists.sourceforge.net/**lists/listinfo/geoserver-devel>
<https://lists.**sourceforge.**net/lists/**listinfo/**
geoserver-devel<http://sourceforge.net/lists/**listinfo/geoserver-devel&gt;
