[Geoserver-devel] request to turn off formatting
I just lost 2 hours some work doing to the formatting problem. For some
reason my maven profile to turn off formatting in my settings.xml did
not engage and formatting went forward. When i reverted i accidentally
reverted some actual new code.
Furthermore i have a bunch of changes that i need to backport from trunk
to 1.5.x that will now be a lot more work to do.
Can i ask that we stop formatting until we have a solution that works
for every platform.
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Justin Deoliveira ha scritto:
for every platform.
I feel your pain, so I'm not going to say no.
This means we'll be back to caos in a couple of months, too bad.
I don't see a cross platform, in build solution be available anywhere
soon.
The big bad format on release seems to be the best idea thought, one
person in the pool reformatting everything with Eclipse. Not ideal,
but probably better than what we have now.
Andrea, is there somewhere a sort of coding convention document we can adopt as strict rule for GeoServer coding, like tabs, tabs spaces and so on? If not we can create one … I know, this won’t solve our problem, but at least will be a sort of agreement for developers, and hopefully will help to maintain some order.
for every platform.
I feel your pain, so I’m not going to say no.
This means we’ll be back to caos in a couple of months, too bad.
I don’t see a cross platform, in build solution be available anywhere
soon.
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-devel mailing list
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 349 8227000
Alessio Fabiani ha scritto:
Andrea, is there somewhere a sort of coding convention document we can adopt as strict rule for GeoServer coding, like tabs, tabs spaces and so on? If not we can create one ... I know, this won't solve our problem, but at least will be a sort of agreement for developers, and hopefully will help to maintain some order.
Well, I guess we should convert the jalopy configuration file into an Eclipse one. I think it's really just a matter of taking the Geotools
one (already available in geotools's SVN) and changing the headers.
Yeah, we have a standard, see: http://docs.codehaus.org/display/GEOSDOC/1+Formatting It's basically Sun's coding standards, with a couple small tweaks like putting on our headers. Making an eclipse version of the jalopy config would probably go a long way.
C
!DSPAM:4005,466fa4e1126101137850744!
Chris Holmes
Justin,
I'm finding myself not buildilng these days because formatting would
invitably mix in with my (unrelated) changes... ouff... ok, can you
remove jalopy from the build, and then issue an Eclipse configuration file?
Justin,
I dont understand? This sounds like the same problem I am having?
Perhaps before taking this drastic measure I can corner saul and get him
to explain to me how he got it to work.
Saul, do i have it correct that once you set your locale to an
ISO-8859-1 one and then rechecked out the source code from scratch it
worked ok for you?
!DSPAM:4007,4671532c158988992556831!
Justin Deoliveira
jdeolive@anonymised.com
Justin,
Yes, I believe this was the fix, but in reality there were two different issues going on for me:
1) 'special' characters were getting changed (causing spurrious file changes)
2) unformatted files were getting formatted, causing what *looked* like spurrious file changes
The ISO-8859-1 change fixed #1, but until you run a big bulk format once, you'll still get the 'unformatted but in SVN' changes that come from #2.
I'll hop on IRC and we can try to work through it if you like. I think it'd be good for me to actually convince myself that it's really working, too. I could have fixed half of the problem and then just never discovered the other half of the problem.
--saul
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Thu 6/14/2007 11:28 AM
To: Andrea Aime
Cc: Saul Farber; geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] request to turn off formatting
Justin,
worked ok for you?
Justin Deoliveira
