[Geoserver-devel] Request to upgrade guava dependency version
As geogit approaches to a stable version, at Boundless we’re working on the integration story with geoserver, for which we have a DataStore implementation that can serve data through geoserver out of a geogit repository.
I managed to retrofit a bunch of dependency versions to match older versions used by geoserver, but the problematic one is google’s guava, because geogit requires version 14.0.1 at the minimum for its implementation of node hashing, which is two versions ahead of the one currently used by geoserver/gwc.
There’s also another open source project, a geoservices rest api implementation prototype, that uses json-schema-validator, which in turn requires guava 13.0.1 at the minimum, due to a known bug that’s being fixed in a newer version <https://github.com/fge/json-schema-validator/issues/39>
So in order to homogenize and be nice to these downstream projects I’m asking for permission to upgrade our current guava dependency, both in geoserver and geowebcache.
We would also need this upgrade to be backported to geoserver 2.5.x and 2.4.x, since our client has a testing infrastructure that requires geoserver 2.4-SNAPSHOT.
The current dependency is at version 11.0.1 (from 2012) to 14.0.1 (from 2013), or to the latest stable version instead.
The latest guava version is 16.0.1 (from 2014-01-17, my birthday btw).
Upgrading to the latest would require a couple minimal extra changes due to the fact that Closeables.closeQuitely(Closeable) was deprecated in 14.0.1 and removed in 15.0.1. For instance: <https://github.com/groldan/geoserver/commit/211a12d306becc3b950b8506f19743e7cd4d36e3>
If interested in checking what the changes would look like, here are the relevant branches to both projects:
<https://github.com/groldan/geoserver/tree/upgrade_guava_14.0.1>
<https://github.com/groldan/geoserver/commits/upgrade_guava_16.0.1>
<https://github.com/groldan/geowebcache/tree/upgrade_guava_14.0.1>
<https://github.com/groldan/geowebcache/tree/upgrade_guava_16.0.1>
Looking forward to your comments and advise on how to proceed.
Gabriel
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com
@gabrielroldan
On Fri, Mar 21, 2014 at 4:01 PM, Gabriel Roldan <groldan@anonymised.com>wrote:
<https://github.com/groldan/geoserver/tree/upgrade_guava_14.0.1&gt;
<https://github.com/groldan/geoserver/commits/upgrade_guava_16.0.1&gt;
<https://github.com/groldan/geowebcache/tree/upgrade_guava_14.0.1&gt;
<https://github.com/groldan/geowebcache/tree/upgrade_guava_16.0.1&gt;
Hi, +1 on both changes on master, they seem pretty small. Actually, if you
want to upgrade other libraries as well,
I for one would be happy to see that too.
Then we have the stable series, 2.5.x. Not so sure about changing the
library version there, I would at least
wait a month before doing a backport there.
And then there is the maintenance one, 2.4.x. Even less thrilled to see it
there, but maybe we could
wait and have a 2.5.x with the library upgrade released and see how that
goes before porting back
to the maintenance series?
I'm probably just being overcautious, but I have no experience with guava
upgrades (and how good
at backwards compat behavior they are).
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the quick reply.
On Fri, Mar 21, 2014 at 12:22 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
okay
not for the time being.
You probably are, but that’s a good thing.
I’ve to say imho its as serious as it gets in managing api and compatibility.
I did an assessment of which guava features are used in the code base, and they are pretty minimal and have been frozen for years. For instance:
  • Function and Predicate, just interfaces and totally frozen since I started using guava at version 9
  • Preconditions, Throwables, Files, ByteStreams, Strings, and Stopwatch utility classes: no changes
  • Cache/CacheBuilder: unchanged since 11.0.1.
  • Collections: by far the most stable part of the library, plus guava guarantees full compliance to the java.util collections contracts in all its collections implementations, as opposed to commons-collections that have a lot for ill-behaved ones.
I have built successfully all the modules that use guava at all, which are main, extensions/wps, community/jdbcconfig, community/script, and gwc
All that said, I’m fine with a wait and see period too. In the mean time I can manage to manually replace the jar and so.
Gabriel
Gabriel Roldán
@gabrielroldan
On Fri, Mar 21, 2014 at 4:01 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Actually, if you want to upgrade other libraries as well,
Then we have the stable series, 2.5.x. Not so sure about changing the library version there, I would at least
And then there is the maintenance one, 2.4.x. Even less thrilled to see it there, but maybe we could
wait and have a 2.5.x with the library upgrade released and see how that goes before porting back
I’m probably just being overcautious, but I have no experience with guava upgrades (and how good
Ing. Andrea Aime
@geowolf
Technical Lead
Hey all, reviving this thread.
Is it ok to move forward with this change? We'd prefer to see it on
both master and 2.5.x if everyone is comfortable with that. Or, we can
wait with the backport for a month as Andrea mentioned on 2.5.x and
only apply this to master.
On Fri, Mar 21, 2014 at 12:15 PM, Gabriel Roldan
okay
You probably are, but that's a good thing.
I've to say imho its as serious as it gets in managing api and
compatibility.
- Function and Predicate, just interfaces and totally frozen since I started
- Preconditions, Throwables, Files, ByteStreams, Strings, and Stopwatch
- Cache/CacheBuilder: unchanged since 11.0.1.
- Collections: by far the most stable part of the library, plus guava
All that said, I'm fine with a wait and see period too. In the mean time I
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@gabrielroldan
Learn Graph Databases - Download FREE O'Reilly Book
"Graph Databases" is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/13534_NeoTech
Geoserver-devel mailing list
Robert Marianski
Software Engineer | Boundless
rmarianski@anonymised.com
@boundlessgeo
If you want to throw together a pull request for master Rob that would be great, I don’t see any reason not to merge it right away.
Personally I would be fine with the upgrade on 2.5.x as well since it is a safe upgrade and nothing really core depends on it. But others may feel differently. Let’s see how the other devs feel and whether we need a waiting period for the 2.5.x backport.
On Mon, Jun 9, 2014 at 11:30 AM, Rob Marianski <rmarianski@anonymised.com> wrote:
Is it ok to move forward with this change? We’d prefer to see it on
okay
compatibility.
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@gabrielroldan
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
Robert Marianski
@boundlessgeo
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Any preference for guava version 14 vs 16? I'd be inclined to just
jump all the way to 16 if there aren't any objections.
Actually, version 17 of guava is out now. Would it be better to target
that? Glancing at the release notes, it doesn't look like we'd be
affected:
http://code.google.com/p/guava-libraries/wiki/Release17
On Mon, Jun 9, 2014 at 2:03 PM, Justin Deoliveira
great, I don't see any reason not to merge it right away.
differently. Let's see how the other devs feel and whether we need a waiting
>>> the
> okay
>> it
>> that
>> guava
> compatibility.
> and
> started
> its
> a
> are
> I
> Cheers,
> Gabriel
>> Cheers
>> Andrea
>> Ing. Andrea Aime
>> @geowolf
>> Technical Lead
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
> Gabriel Roldán
> @gabrielroldan
> their
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Robert Marianski
@boundlessgeo
Justin Deoliveira
@j_deolive
Robert Marianski
@boundlessgeo
Hi Rob,
thanks for resurrecting this thread. I have created a PR to upgrade master to guava 17.0 <https://github.com/geoserver/geoserver/pull/613>
@jdeolive it’s assigned to you in case you have a chance to take a look at it.
Gabriel
On Mon, Jun 9, 2014 at 3:57 PM, Rob Marianski <rmarianski@anonymised.com> wrote:
Any preference for guava version 14 vs 16? I’d be inclined to just
jump all the way to 16 if there aren’t any objections.
that? Glancing at the release notes, it doesn’t look like we’d be
affected:
<andrea.aime@anonymised.com1268…>
<groldan@anonymised.com…>
the
okay
it
that
guava
compatibility.
and
    started
    its
    a
are
I
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@gabrielroldan
their
Robert Marianski
@boundlessgeo
Justin Deoliveira
@j_deolive
Robert Marianski
@boundlessgeo
Gabriel Roldán
@gabrielroldan
It looks like Guava dropped its maven dependency on jrs305 in recent versions so anywhere @Nullable is being used without explicitly adding jsr305 breaks. Having fixed that, GWC master and 1.5.x seem to work with Guava 17.
affected:
the
okay
it
that
guava
compatibility.
and
    started
    its
    a
are
I
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@gabrielroldan
their
Robert Marianski
@boundlessgeo
Justin Deoliveira
@j_deolive
Robert Marianski
@boundlessgeo
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
That’s right, check the commit notes and the patch on the PR I just mentioned. Do you want me to create a PR for gwc or do you got it already?
Geowebcache-devel mailing list
Geowebcache-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geowebcache-devel
Gabriel Roldán
@gabrielroldan
affected:
the
okay
it
that
guava
compatibility.
and
    started
    its
    a
are
I
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@gabrielroldan
their
Robert Marianski
@boundlessgeo
Justin Deoliveira
jdeolive@anonymised.com839…
@j_deolive
Robert Marianski
rmarianski@anonymised.com39…
@boundlessgeo
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ok, here’s the GWC PR <https://github.com/GeoWebCache/geowebcache/pull/256> (got it already for 16.0.1 so it was easy)
On Mon, Jun 9, 2014 at 8:17 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Gabriel Roldán
@gabrielroldan
Gabriel Roldán
@gabrielroldan
affected:
the
okay
it
that
guava
compatibility.
and
    started
    its
    a
are
I
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@gabrielroldan
their
Robert Marianski
@boundlessgeo
Justin Deoliveira
@j_deolive
Robert Marianski
@boundlessgeo
Kevin Smith
+1-778-785-7459
@boundlessgeo
GeoServer PR merged. Didn’t have much of a choice since the GWC was already merged.
On Mon, Jun 9, 2014 at 5:23 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
Gabriel Roldán
@gabrielroldan
Gabriel Roldán
@gabrielroldan
affected:
the
okay
it
that
guava
compatibility.
and
    started
    its
    a
are
I
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@gabrielroldan
their
Robert Marianski
@boundlessgeo
Justin Deoliveira
@j_deolive
Robert Marianski
@boundlessgeo
Kevin Smith
+1-778-785-7459
@boundlessgeo
On Mon, Jun 9, 2014 at 9:06 PM, Justin Deoliveira <jdeolive@anonymised.com
wrote:
GeoServer PR merged. Didn't have much of a choice since the GWC was
already merged.
I actually had reverted the GWC PR to wait until geoserver upgraded. Sorry
wasn't clear about that on IRC.
wrote:
Ok, here's the GWC PR <
https://github.com/GeoWebCache/geowebcache/pull/256&gt; (got it already for
wrote:
That's right, check the commit notes and the patch on the PR I just
Guava 17.
affected:
would be
it is a
feel
waiting
can
here are
>> >>> the
>> > okay
changing the
to see
>> >> it
how
>> >> that
with
>> >> guava
>> > compatibility.
base,
>> > and
instance:
since I
>> > started
Stopwatch
guava
in all
>> > its
that have
>> > a
which
>> > are
gwc
mean time
>> > I
>> > Cheers,
>> > Gabriel
>> >> Cheers
>> >> Andrea
>> >> Ing. Andrea Aime
>> >> @geowolf
>> >> Technical Lead
>> >> GeoSolutions S.A.S.
>> >> Italy
>> > Gabriel Roldán
>> > @gabrielroldan
and
>> > their
today!
>> > _______________________________________________
>> Robert Marianski
>> @boundlessgeo
Solutions
> Justin Deoliveira
> @j_deolive
Robert Marianski
@boundlessgeo
Solutions
Kevin Smith
+1-778-785-7459
@boundlessgeo <https://twitter.com/boundlessgeo&gt;
Solutions
Gabriel Roldán
@gabrielroldan <https://twitter.com/gabrielroldan&gt;
Gabriel Roldán
*Justin Deoliveira*
@j_deolive <https://twitter.com/j_deolive&gt;
Gabriel Roldán
On Tue, Jun 10, 2014 at 2:58 AM, Gabriel Roldan <groldan@anonymised.com>
already merged.
+1 on upgrading on trunk btw.
Just a bit on the fence about the stable series, as said above not a guava
user, not sure how well
they handle their upgrades, but if heavy guava users are very confident
about it, why not.
Ing. Andrea Aime
@geowolf
Technical Lead
