Thanks for all the great work on Geoserver!
Geoserver 1.3.0-rc2 outputs the common SRS multiple times in the
getCapabilities request. It is output once in the output for common srs
and again in the full list for supported SRSs.
Tools such as Carbon Project's Gaia WMS browser choke on the
getCapabilities since the SRS is used as a key to a hash table for
supported projections. This started when reprojection support was added,
but I am just getting around to submitting a bug report (and fix :))
Since I can see no need for the SRS to be listed twice, would you accept
the following patch to WMSCapsTransformer.java?
I need this patch asap, and was hoping it would make it into the next
release candidate. (rc3)
Patch starts around line 474 as shown below
if (!(commonSRS.equals("")))
comment("common SRS:");
element("SRS", commonSRS);
//okay - we've sent out the commonSRS, if it exists.
comment("All supported EPSG projections:");
try {
Set s = CRS.getSupportedCodes("EPSG");
Iterator it = s.iterator();
while (it.hasNext())
// patch starts here
// do not output srs if it was output as common srs
// note, if commonSRS is "", this will not match
String currentSRS = it.next().toString();
if (!currentSRS.equals(commonSRS))
element("SRS", currentSRS );
.....geoserver-devel
