Hey Justin, would you mind applying the bellow patch to
RequestObjectLogger in order not to generate too many strings when not
needed? I tested it by switching between geosever_developer and
production logging while running a gwc seed task and it seems it does
its job. The performance penalty for this case is around 3%. Not that a
big deal, but still it'd be good to avoid unnecessary log calls?
Gabriel
--- a/ows/src/main/java/org/geoserver/ows/util/RequestObjectLogger.java
+++ b/ows/src/main/java/org/geoserver/ows/util/RequestObjectLogger.java
@@ -4,6 +4,7 @@
package org.geoserver.ows.util;
+import java.util.logging.Level;
import java.util.logging.Logger;
import org.aopalliance.intercept.MethodInterceptor;
@@ -27,7 +28,9 @@ public class RequestObjectLogger implements
MethodInterceptor {
public Object invoke(MethodInvocation invocation) throws Throwable
+ if (!logger.isLoggable(Level.INFO)) {
+ return invocation.proceed();
StringBuffer log = new StringBuffer();
log.append("\n" + "Request: " +
invocation.getMethod().getName());
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
Looks good. Apply as you like.
On Wed, Apr 6, 2011 at 3:29 PM, Gabriel Roldán <groldan@anonymised.com> wrote:
big deal, but still it’d be good to avoid unnecessary log calls?
Gabriel
— a/ows/src/main/java/org/geoserver/ows/util/RequestObjectLogger.java
@@ -4,6 +4,7 @@
MethodInterceptor {
- if (!logger.isLoggable(Level.INFO)) {
- return invocation.proceed();
log.append(“\n” + "Request: " +
Gabriel Roldan
Justin Deoliveira
OpenGeo - http://opengeo.org
