On Fri, May 22, 2015 at 9:14 PM, Torben Barsballe <
tbarsballe@anonymised.com> wrote:
I just stumbled into this:
https://osgeo-org.atlassian.net/browse/GEOS-7046 while using geoserver.
It turns out org.geoserver.catalog.impl.ResolvingProxy.handleOther()
overrides ProxyBase.handleOther() to always return null instead of excecute
the method. Does anyone have any idea why this is?
Hum.. nope, this goes back to the first implementation of ResolvingProxy.
Our current history does not go back as much, but in case you did not know,
there is a geoserver-history repo that has the
history from the first commit, up to the one where the new repo starts.
Here is a blame on that file in the history repo:
https://github.com/geoserver/geoserver-history/blame/master/src/main/src/main/java/org/geoserver/catalog/impl/ResolvingProxy.java
If I had to venture a guess, it's because ResolvingProxy is not meant to be
found anywhere past the catalog
loading, it should be always be replaced by a resolved version.
As far as I remember, it is being created as a placeholder allowing the
catalog to be loaded in whatever order
(even if we don't have the target object loaded yet), and then
ResolvingProxy.resolve should be called
onto all of them, which we do in the AbstractCatalogFacade.resolve family
of methods
Maybe we are missing some resolve calls in some code path?
Anyways... cc'ed Justin, he should know better than me
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
