On Thu, Jan 25, 2018 at 11:08 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
This has been an ongoing issue, and has a number of associated JIRA tickets:
The issue is that layers of the same name in different workspaces show up identically when listing layers using the rest API (not noted in most of these issues is that this also affects the layer list shown when viewing a layer group).
This also presents as a legitimate error for links to layers, as links also use the unprefixed name and therefore always go to the default / first layer with that name.
There has been a bunch of ongoing discussion, which ultimately boils down to we should probably use prefixed layer names. However, this is a little bit of an API change.
I have a PR with a (potential) fix (and further details) here: https://github.com/geoserver/geoserver/pull/2733
There’s enough of a change in behaviour that this probably shouldn’t get back-ported, but otherwise I don’t think it is too problematic - After my fix, prefixed names are only used in lists of layers, not in the layer details (this is consistent with how we currently handle stores or resources in the rest API). Examples can be seen in the PR description.
Any comments/discussion?
Torben
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
