[Geoserver-devel] REST community module sldService refactored
I have fully refactored the old sldService REST community module. It is now fully aligned with the rest and restconfig model and structure, and also cleaned from unusefull stuff.
Actually the service contains three operations:
  • LayerAttributes : allows to retrieve the list of the Attributes for a vectorial layer in HTML, XML and JSON formats
  • Classifier : allows to create a set of sld rules on the fly for vectorial layers applying a classification (quantile, equalInterval, uniqueInterval) and a colorRamp to the specified layer attribute values. Results are returned back in HTML, XML and JSON formats
  • Rasterizer : allows to rescale on the fly the ColorMap of the default RasterSymbolizer for a raster layer. The new SLD is returned back as SLD. The remapped style is not saved on the catalog anyway
New features will be added in the future.
I’m asking here to commit the module to the GeoServer 2.0 community space.
Concerns, feedbacks, questions? Should also someone review the code before/after commit?
Best regards,
Alessio.
Eng. Alessio Fabiani
Founder / CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584 980933
fax: +39 0584 983027
mob: +39 349 8227000
http://geo-solutions.blogspot.com
Cool stuff Alessio. I don't think anyone will object to you working on that module since it has more or less been abandoned afaik.
One thing to consider might be rolling this functionality into the existing restconfig api. Just a thought.
-Justin
Alessio Fabiani wrote:
- LayerAttributes : allows to retrieve the list of the Attributes for a vectorial layer in HTML, XML and JSON formats
- Classifier : allows to create a set of sld rules on the fly for vectorial layers applying a classification (quantile, equalInterval, uniqueInterval) and a colorRamp to the specified layer attribute values. Results are returned back in HTML, XML and JSON formats
- Rasterizer : allows to rescale on the fly the ColorMap of the default RasterSymbolizer for a raster layer. The new SLD is returned back as SLD. The remapped style is not saved on the catalog anyway
I'm asking here to commit the module to the GeoServer 2.0 community space.
Best regards,
                 Alessio.
Via Carignoni 51
55041 Camaiore (LU)
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Would make a lot of sense to me.
Andrea Aime
I also think that it would be the best solution … if you agree I can easily and quickly port those functionalities on restconfig module.
Via Carignoni 51
55041 Camaiore (LU)
On Thu, Nov 19, 2009 at 10:08 AM, Andrea Aime <aaime@anonymised.com01…> wrote:
Cool stuff Alessio. I don’t think anyone will object to you working on
Andrea Aime
what you do best, core application coding. Discover what’s new with
Well I would say if you are under deadlines then leave it in the current community module since it will take a bit of design discussion to determine to best integrate it into the api. And such processes can be slow at times.
I also think that it would be the best solution ... if you agree I can easily and quickly port those functionalities on restconfig module.
Via Carignoni 51
55041 Camaiore (LU)
On Thu, Nov 19, 2009 at 10:08 AM, Andrea Aime <aaime@anonymised.com <mailto:aaime@anonymised.com>> wrote:
     > Cool stuff Alessio. I don't think anyone will object to you
    working on
     > that module since it has more or less been abandoned afaik.
     > One thing to consider might be rolling this functionality into the
     > existing restconfig api. Just a thought.
    Andrea Aime
    30-Day
    focus on
    <mailto:Geoserver-devel@lists.sourceforge.net>
Justin Deoliveira
Well actually I have no very strict deadlines, so I would prefer to start a discussion on the integration with restconfig module.
I proposed to leave this stuff on a separate module since the functionalities I’m going to add are strictly related to the catalog configuration even if they still need the catalog support to interact with the data.
Actually I have aligned the code of the three functions above with rest and restoconfig, by extending the AbstractCatalogFinder and the AbstractCatalogResource base classes.
The only methods enables are the handleGet since those resources are read-only resources.
I also made an override of the createHTMLFormat, createXMLFormat and createJSONFormat methods, where applicable, by deserializing the objects through xstream.
The only special case is for the rasterizer where I also added a custom SLDFormat also using the GeoTools StyleBuilder to serialize the output for the “sld” extension type, similarly to the catalog Style resources.
Via Carignoni 51
55041 Camaiore (LU)
On Thu, Nov 19, 2009 at 4:07 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
slow at times.
Via Carignoni 51
55041 Camaiore (LU)
working on
Andrea Aime
30-Day
focus on
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comeforge.net)
Justin Deoliveira
Hi all guys,
a lot of time ago I presented a new refactored version of sldSerive rest module ready for GeoServer 2.x infrastructure, with a branch of new utilities useful for automatic styling.
We spoken about the possibility of merging it directly on restconfig module.
Since I have seen some users looking for sldService functionalities on GeoServer 2.x too, I guess is a good time to commit the stuff.
In order to accelerate times I can commit it as a separate community module, but if you think can be a good idea I can also manage to directly merge it on restconfig one.
Please let me know.
Alessio.
Ing. Alessio Fabiani
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584 983027
mobile:+39 349 8227000
http://www.linkedin.com/in/alessiofabiani
http://twitter.com/simogeo
On Thu, Nov 19, 2009 at 5:07 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
slow at times.
Via Carignoni 51
55041 Camaiore (LU)
working on
Andrea Aime
30-Day
focus on
Justin Deoliveira
Hi Alessio,
I would say for now if you plan to do some active development on it let’s keep it in community. But maybe having the restconfig extension be the final place for it, instead of promoting it to extension we promote to the existing restconfig extension.
There is any docs or an existing email thread about what the sldService does?
On Thu, Aug 26, 2010 at 2:18 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi all guys,
Please let me know.
Alessio.
Via Carignoni 51
55041 Camaiore (LU)
slow at times.
Via Carignoni 51
55041 Camaiore (LU)
working on
Andrea Aime
30-Day
focus on
Justin Deoliveira
Justin Deoliveira
Hello Justin,
so for now I will commit the module on community space.
We have an old thread started here which I report below:
"Hi all,
Best regards,
Alessio."
Via Carignoni 51
55041 Camaiore (LU)
On Thu, Aug 26, 2010 at 4:09 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Alessio,
Hi all guys,
Please let me know.
Alessio.
Via Carignoni 51
55041 Camaiore (LU)
slow at times.
Via Carignoni 51
55041 Camaiore (LU)
working on
Andrea Aime
30-Day
focus on
Justin Deoliveira
Justin Deoliveira
Sell apps to millions through the Intel(R) Atom™ Developer Program
Be part of this innovative community and reach millions of netbook users
worldwide. Take advantage of special opportunities to increase revenue and
speed time-to-market. Join now, and jumpstart your future.
http://p.sf.net/sfu/intel-atom-d2d
