Contributions are welcome
We have not worked much on it lately but we have clients relying on it.
Your mileage may vary depending on which portion of the REST API you
are hitting.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Thu, Feb 14, 2019 at 5:41 PM Gabriel Roldan <gabriel.roldan@anonymised.com> wrote:
Hello list,
I wonder if there's a REST config Java client around that'll work with recent versions of GeoServer (2.14+).
I found GeoSolution's geoserver-manager[1] but the last release (1.7.0) is from April 2016 and the README says it targets GeoServer 2.9.x.
If there's no current option I'd be willing to give it a try.
Gabriel
[1] https://github.com/geosolutions-it/geoserver-manager
Geoserver-devel mailing list
