[Geoserver-devel] REST Configuration Example fails with GeoServer 2.0.0
Hello everybody,
I am trying to repeat the steps in the REST Configuration Examples as outlined here:
http://docs.geoserver.org/2.0.0/user/extensions/rest/rest-config-examples-curl.html
I failed to accomplish “Upload a Shapefile” step - I can see the attached exception thrown in the GeoServer console.
It looks like GeoTools is trying to locate an shx file in the destination folder before it copied it there.
I am using GeoServer 2.0.0 running on Windows XP. Any ideas what is going on?
Andy
27 Dec 19:13:38 INFO [catalog.rest] - PUT file, mimetype: application/x-www-form
-urlencoded
27 Dec 19:13:38 INFO [catalog.rest] - Using existing datastore: fe_2007_010001_e
dges
27 Dec 19:13:38 WARN [shapefile.sh] - Could not open the .shx file, continuing a
ssuming the .shp file is not sparse
java.io.FileNotFoundException: C:\Program Files\GeoServer 2.0.0\data_dir\data\fe
_2007_010001_edges\fe_2007_010001_edges.shx
at org.geotools.data.shapefile.ShpFiles.getReadChannel(ShpFiles.java:821)
at org.geotools.data.shapefile.shp.IndexFile.(IndexFile.java:78)
at org.geotools.data.shapefile.shp.ShapefileReader.(ShapefileReader.java:215)
at org.geotools.data.shapefile.ShapefileDataStore.openShapeReader(ShapefileDataStore.java:453)
at org.geotools.data.shapefile.ShapefileDataStore.readAttributes(ShapefileDataStore.java:680)
at org.geotools.data.shapefile.ShapefileDataStore.getSchema(ShapefileDataStore.java:638)
at org.geotools.data.shapefile.ShapefileDataStore.getSchema(ShapefileDataStore.java:632)
at org.geotools.data.shapefile.ShapefileDataStore.getFeatureSource(ShapefileDataStore.java:964)
at org.geoserver.catalog.rest.DataStoreFileResource.handlePut(DataStoreFileResource.java:220)
at org.restlet.Finder.handle(Finder.java:298)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:521)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:730)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
27 Dec 19:13:38 ERROR [geoserver.rest] -
java.lang.RuntimeException: java.io.IOException: Wrong magic number, expected 9994, got 1347093252
at org.geoserver.catalog.rest.DataStoreFileResource.handlePut(DataStoreFileResource.java:253)
Caused by: java.io.IOException: Wrong magic number, expected 9994, got 1347093252
at org.geotools.data.shapefile.shp.ShapefileHeader.checkMagic(ShapefileHeader.java:53)
at org.geotools.data.shapefile.shp.ShapefileHeader.read(ShapefileHeader.java:75)
at org.geotools.data.shapefile.shp.ShapefileReader.readHeader(ShapefileReader.java:259)
at org.geotools.data.shapefile.shp.ShapefileReader.init(ShapefileReader.java:309)
at org.geotools.data.shapefile.shp.ShapefileReader.(ShapefileReader.java:221)
… 56 more
Hi Andy,
First I would try clearing out any directories under data_dir/data that were created by previous upload attempts. Then try again and capture the log of the first attempt. It would also be helpful to have the exact cURL request that you are making.
A common mistake is not setting the content-type properly to application/zip.
-Jusitn
Andy Burgard wrote:
Hello everybody,
I failed to accomplish "Upload a Shapefile" step - I can see the attached exception thrown in the GeoServer console.
Andy
-urlencoded
dges
        at org.geotools.data.shapefile.shp.IndexFile.<init>(IndexFile.java:78)
        at org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:215)
        at org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:221)
        ... 56 more
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin,
thanks for the help.Here are the cURL commands I am submitting:
curl -u admin:geoserver -v -XPOST -H “Content-type: text/xml” -d “roads” http://localhost:8080/geoserver/rest/workspaces
curl -XGET http://localhost:8080/geoserver/rest/workspaces/roads.xml
I get the following at this point:
roads
<atom:link xmlns:atom=“http://www.w3.org/2005/Atom” rel=“alternate” href=“ht
tp://localhost:8080/geoserver/rest/workspaces/roads/datastores.xml” type=“applic
ation/xml”/>
tp://localhost:8080/geoserver/rest/workspaces/roads/coveragestores.xml” type=“ap
plication/xml”/>
Next I do:
curl -v -u admin:geoserver -XPUT --header ‘Content-type: application/zip’ --data-binary @fe_2007_01001_edges.zip http://localhost:8080/geoserver/rest/workspaces/roads/datastores/fe_2007_01001_edges/file.shp
That’s when I get the exception I posted in my original email. Here fe_2007_01001_edges.zip is a zip file that contains a fe_2007_01001_edges shapefile. The file is taken from TIGER/Line dataset.
Andy
On Tue, Dec 29, 2009 at 11:34 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Andy,
-Jusitn
Andy Burgard wrote:
Hello everybody,
Andy
-urlencoded
dges
… 56 more
Take advantage of Verizon’s best-in-class app development support
Justin Deoliveira
Hmmm... strange the requests look fine to me. Can you show me the contents of the data_dir/data directory before and after the upload, a recursive listing if possible.
Andy Burgard wrote:
Justin,
curl -u admin:geoserver -v -XPOST -H "Content-type: text/xml" -d "<workspace><name>roads</name></workspace>" http://localhost:8080/geoserver/rest/workspaces
<workspace>
  <name>roads</name>
  <dataStores>
    <atom:link xmlns:atom="http://www.w3.org/2005/Atom&quot; rel="alternate" href="ht
tp://localhost:8080/geoserver/rest/workspaces/roads/datastores.xml" type="applic
ation/xml"/>
  </dataStores>
  <coverageStores>
tp://localhost:8080/geoserver/rest/workspaces/roads/coveragestores.xml" type="ap
plication/xml"/>
  </coverageStores>
</workspace>
Next I do:
curl -v -u admin:geoserver -XPUT --header 'Content-type: application/zip' --data-binary @fe_2007_01001_edges.zip http://localhost:8080/geoserver/rest/workspaces/roads/datastores/fe_2007_01001_edges/file.shp
That's when I get the exception I posted in my original email. Here fe_2007_01001_edges.zip is a zip file that contains a fe_2007_01001_edges shapefile. The file is taken from TIGER/Line dataset.
Andy
On Tue, Dec 29, 2009 at 11:34 AM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    Hi Andy,
    application/zip.
    -Jusitn
    Andy Burgard wrote:
        Hello everybody,
        is going on?
        Andy
        -urlencoded
        fe_2007_010001_e
        dges
        file, continuing a
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               at
               ... 56 more
        fast and easy
        <mailto:Geoserver-devel@lists.sourceforge.net>
    -- Justin Deoliveira
Justin Deoliveira
Justin,
here is the listing of the data_dir/data directory before the excution of
command:
C:\Program Files\GeoServer 2.0.0\data_dir\data>dir /s/w/o/p
Volume in drive C is OSDisk
Volume Serial Number is 907C-9CD2
Directory of C:\Program Files\GeoServer 2.0.0\data_dir\data
0 File(s) 0 bytes
Total Files Listed:
0 File(s) 0 bytes
2 Dir(s) 31,512,698,880 bytes free
After executing the command I get the following:
[.] […] [fe_2007_01001_edges]
0 File(s) 0 bytes
Directory of C:\Program Files\GeoServer 2.0.0\data_dir\data\fe_2007_01001_edges
[.] […] fe_2007_01001_edges.shp
1 File(s) 3,361,720 bytes
Total Files Listed:
5 Dir(s) 31,509,241,856 bytes free
Also I tried another zip file and I get the same results. Also I tried Geoserver 1.7.6 (with the corresponding version of REST jar) and got exactly the same exception.
BTW, how am I supposed to install REST jar - I just copied the restconfig-?.?.?.jar to the webapps\geoserver\WEB-INF\lib folder ?
Andy
On Tue, Dec 29, 2009 at 6:33 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hmmm… strange the requests look fine to me. Can you show me the contents of the data_dir/data directory before and after the upload, a recursive listing if possible.
Andy Burgard wrote:
Justin,
roads
ation/xml”/>
plication/xml”/>
Next I do:
Andy
On Tue, Dec 29, 2009 at 11:34 AM, Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:
Hi Andy,
application/zip.
-Jusitn
Andy Burgard wrote:
Hello everybody,
is going on?
Andy
-urlencoded
fe_2007_010001_e
dges
file, continuing a
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 56 more
fast and easy
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comrge.net)
– Justin Deoliveira
Justin Deoliveira
Hmmm... i am stumped on this one. Any chance you can post the zip file you are trying to POST? (privately if you wish) With it I can try to replicate the problem.
-Justin
Andy Burgard wrote:
Justin,
command:
               0 File(s) 0 bytes
     Total Files Listed:
               0 File(s) 0 bytes
[.] [..] [fe_2007_01001_edges]
               0 File(s) 0 bytes
[.] [..] fe_2007_01001_edges.shp
     Total Files Listed:
Andy
On Tue, Dec 29, 2009 at 6:33 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    Andy Burgard wrote:
        Justin,
        <workspace>
         <name>roads</name>
         <dataStores>
        type="applic
        ation/xml"/>
         </dataStores>
         <coverageStores>
        type="ap
        plication/xml"/>
         </coverageStores>
        </workspace>
        Next I do:
        TIGER/Line dataset.
        Andy
           Hi Andy,
        data_dir/data
           application/zip.
           -Jusitn
           Andy Burgard wrote:
               Hello everybody,
        see the
        ideas what
               is going on?
               Andy
               -urlencoded
        datastore:
               fe_2007_010001_e
               dges
               file, continuing a
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      at
                      ... 56 more
        support
        distribution
               fast and easy
        customers
        <mailto:Geoserver-devel@lists.sourceforge.net>>
        fast and easy
Justin Deoliveira
Justin,
this file is coming from TIGER/Line dataset. I attached it but it can also be found here:
ftp://ftp2.census.gov/geo/tiger/TIGER2007FE/01_ALABAMA/01001_Autauga/fe_2007_01001_edges.zip
I don’t think that the problem I am experiencing has to do with this particular file. I tried a different file and I still see the same problem. So either my GeoServer is installed incorrectly or it is just a bug.
BTW, I am using java version “1.6.0_07”.
Thanks for the help,
On Thu, Dec 31, 2009 at 10:06 AM, Justin Deoliveira <jdeolive@anonymised.com501…> wrote:
Hmmm… i am stumped on this one. Any chance you can post the zip file you are trying to POST? (privately if you wish) With it I can try to replicate the problem.
-Justin
Andy Burgard wrote:
Justin,
command:
0 File(s) 0 bytes
Total Files Listed:
0 File(s) 0 bytes
0 File(s) 0 bytes
Total Files Listed:
Andy
On Tue, Dec 29, 2009 at 6:33 PM, Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:
Andy Burgard wrote:
Justin,
“roads”
roads
type=“applic
ation/xml”/>
type=“ap
plication/xml”/>
Next I do:
TIGER/Line dataset.
Andy
<mailto:jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com501...)>> wrote:
Hi Andy,
data_dir/data
application/zip.
-Jusitn
Andy Burgard wrote:
Hello everybody,
see the
ideas what
is going on?
Andy
-urlencoded
datastore:
fe_2007_010001_e
dges
file, continuing a
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 56 more
support
distribution
fast and easy
customers
<mailto:Geoserver-devel@anonymised.comet
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comrge.net)>
– Justin Deoliveira
fast and easy
– Justin Deoliveira
Justin Deoliveira
(attachments)
fe_2007_01001_edges.zip (3.21 MB)
I am sorry to be a pest but I still need an answer to this question. I would really appreciate if somebody could confirm if there is a problem with REST api. I really need this functionality for the project I want to do.
Andy
On Thu, Jan 7, 2010 at 4:34 PM, Andy Burgard <andy.burgard@anonymised.com…> wrote:
Justin,
On Thu, Dec 31, 2009 at 10:06 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
Andy Burgard wrote:
Justin,
command:
0 File(s) 0 bytes
Total Files Listed:
0 File(s) 0 bytes
0 File(s) 0 bytes
Total Files Listed:
Andy
Andy Burgard wrote:
Justin,
“roads”
roads
type=“applic
ation/xml”/>
type=“ap
plication/xml”/>
Next I do:
TIGER/Line dataset.
Andy
Hi Andy,
data_dir/data
application/zip.
-Jusitn
Andy Burgard wrote:
Hello everybody,
see the
ideas what
is going on?
Andy
-urlencoded
datastore:
fe_2007_010001_e
dges
file, continuing a
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 56 more
support
distribution
fast and easy
customers
– Justin Deoliveira
fast and easy
– Justin Deoliveira
Justin Deoliveira
Hi Andy,
Just to let you know this email list is not commercial support, it is users helping users in their spare time. So if you don't get a response it means people are probably busy. If you do need more reliable support there are certainly companies willing to offer it.
That said, apologies for dragging my heels on this one it has been a busy week. Unfortunately I am not able to reproduce the problem. This operation is quite a common one so it must be something specific to your setup that is causing the error. I am sort of out of ideas here... the only thing I can ask is that you post your data directory for me and i can try to run with it to see if i can reproduce.
Past that the only thing I can suggest is that you break out a java debugger and walk through the code...
-Justin
Andy
On Thu, Jan 7, 2010 at 4:34 PM, Andy Burgard <andy.burgard@anonymised.com <mailto:andy.burgard@anonymised.com>> wrote:
    Justin,
    I don't think that the problem I am experiencing has to do with this
    just a bug.
    BTW, I am using java version "1.6.0_07".
        -Justin
        Andy Burgard wrote:
            Justin,
            the excution of
            command:
                          0 File(s) 0 bytes
                Total Files Listed:
                          0 File(s) 0 bytes
                          0 File(s) 0 bytes
                Total Files Listed:
            Andy
            show me the
            the upload,
               Andy Burgard wrote:
                   Justin,
            submitting:
            text/xml" -d
                   curl -XGET
                   <workspace>
                    <name>roads</name>
                    <dataStores>
                   type="applic
                   ation/xml"/>
                    </dataStores>
                    <coverageStores>
                   type="ap
                   plication/xml"/>
                    </coverageStores>
                   </workspace>
                   Next I do:
            original email.
            contains a
                   TIGER/Line dataset.
                   Andy
            <mailto:jdeolive@anonymised.com> <mailto:jdeolive@anonymised.com
            <mailto:jdeolive@anonymised.com>>>> wrote:
                      Hi Andy,
                   data_dir/data
            Then try again and
            also be helpful to
            properly to
                      application/zip.
                      -Jusitn
                      Andy Burgard wrote:
                          Hello everybody,
            Configuration
            step - I can
                   see the
            console.
            shx file in the
            XP. Any
                   ideas what
                          is going on?
                          Andy
            file, mimetype:
                          -urlencoded
            existing
                   datastore:
                          fe_2007_010001_e
                          dges
            not open the .shx
                          file, continuing a
            Files\GeoServer
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
            number, expected
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 at
                                 ... 56 more
            Developer
            development
                   support
                   distribution
                          fast and easy
            of Verizon
                   customers
            <mailto:Geoserver-devel@lists.sourceforge.net>>>
            Developer Community
            development support
            distribution
                   fast and easy
            Verizon customers
            support
            customers
Justin Deoliveira
