[Geoserver-devel] REST deleting data store causes hang up
I am actually developing a SW module which configures data & coverage stores using the REST interface of GeoServer.
Now I have experienced a problem when I want to delete data stores which I have originally created.
Sometimes - after sending the commands for deleting layers or the complete data store (I have used GsRest.java as template) - GeoServer is not responding any more. I have to kill the instance and restart it. The last Log entry is every time:
“DEBUG [org.geoserver] – thread XXXX releasing the lock in mode WRITE”
The code is:
public boolean deleteDatastore(final String wsName, final String dsName) throws IOException {
final List layerNames = getLayersUsingDataStore(wsName, dsName);
for (final String lName : layerNames) {
if (!deleteLayer(lName)) {
throw new RuntimeException(„Could not delete layer “ + wsName + „:” + dsName + „:” + lName);
reload();
final int erg = sentRESTint(METHOD_DELETE, „/workspaces/“ + wsName + „/datastores/” + dsName, null);
return erg == 200;
Do you know this behaviour? Anybody got a hint?
Thank you very much!
Tobias
Tobias Neumann, M.Sc.
Softwareingenieur Geoinformatik
Tel: +49 89 608090-276
Fax: +49 89 6098182
E-Mail: Tobias.Neumann@anonymised.com
Web: www.berner-mattner.com
Berner & Mattner Systemtechnik GmbH
Erwin-von-Kreibig-Str. 3
D-80807 München
Geschäftsführer: Dr. Klaus Eder, Dr. Jan-Oliver Wenzel
Registernummer: HR B 83252 beim Amtsgericht München
Sitz der Gesellschaft: München
On Thu, Oct 25, 2012 at 8:40 AM, Neumann, Tobias
<tobias.neumann@anonymised.com> wrote:
The developer list is meant for people actively contributing changes
to GeoServer.
If you want to just make questions or report issues the user list
please post there
(and have a look at the posting guidelines here:
http://geoserver.org/display/GEOS/GeoServer+user+list+posting+guidelines)
For your followup on the user list, I'd suggest you to also report what happens
to OGC requests, if they get locked as well or not, and a jstack dump showing
what the threads are doing after the lockup occurs
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
