[Geoserver-devel] REST Extensible and customizable versions report
to complete the integration of GeoServer (and all of the installed plugin) into our continuous integration environment I need to provide a rest service to expose (at least):
… release (version)
… revision (svn tag or git hash)
… build date (optional)
for GeoServer and all of the installed extensions (f.e.):
… monitoring
… control flow
plus other custom plugins.
So I need to create an extensible mechanisms to provide those info. There are various possible approaches.
Here is my proposal based on java Manifest + maven and its plugins.
  1. Each project or extension may register it’s Manifest bean into the spring context
  2. For each GET request on the /rest/about[.format] path, a file in the ‘.format’ format will be returned listing all of the registered Manifest beans with all of the stored entries.
  3. The output format can be produced using FreeMarker
Note also that this is an extensible and customisable approach:
  1. Example on how to extend/customize:
I’ll setup for my custom plugin manifest entries adding hudson environment and build information using maven variables with:
org.apache.maven.plugins maven-jar-plugin true true ${project.build.finalname} ${project.version} ${iteration} ${maven.build.timestamp} ${BUILD_NUMBER} ${BUILD_ID} ${JOB_NAME} ${BUILD_TAG} ${EXECUTOR_NUMBER} ${JAVA_HOME} ${WORKSPACE} ${HUDSON_URL} ${SVN_REVISION} ${SVN_TAG}
The result will be a file with some more information (coming from my extension build) into the custom plugin section.
  1. A simple example for geoserver with monitoring plugin installed into the lib dir:
doing a get on http://GEOSERVER/rest/about.xml (with username and password)
will result in something like:
..--SNAPSHOT ....--rc<</ daabbfaafbbfddbbbeffabbbb674bbbb1361ddd< --SNAPSHOT ....--rc<</ fff8aaaf435477737fff915bbbc3862cccb145<< ..--SNAPSHOT ....--rc<</ fff8aaaf435477737fff915bbbc3862cccb146<<
  1. A simple example for geoserver with monitoring and my custom plugin installed into the lib dir:
get http://GEOSERVER/rest/about.xml
..--SNAPSHOT ....--rc<</ daabbfaafbbfddbbbeffabbbb674bbbb1361ddd< --SNAPSHOT ....--rc<</ fff8aaaf435477737fff915bbbc3862cccb145<< ..--SNAPSHOT ....--rc<</ fff8aaaf435477737fff915bbbc3862cccb146<< 1.0.--SNAPSHOT ....--rc<</ MyCustom ..--SNAPSHOT ... 9<< < GEO_TS_GEOSERVER_MyCustom_BUILD 2<< < .. ... http://.... r093<< REL_79<<
Note also that non maven project can still use this using their custom (ant?) mechanisms to update their /META-INF/MANIFEST.MF file.
What do you think about this? May I have to produce a proposal page? is it possible to have this on the 2.2.x branch (in the future)?
Ref.:
http://maven.apache.org/shared/maven-archiver/examples/manifest.html
http://docs.oracle.com/javase/....//docs/api/java/util/jar/Manifest.html
https://github.com/kevinsawicki/github-maven-example/blob/master/example/pom.xml
Carlo Cancellieri - GeoSolutions SAS
Hi Carlo,
Very interesting idea and is something that I have wanted to see in GeoServer for quite some time, the start of an extension management framework.
One question I have is how will the manifest lookup occur? Will it be a simple lookup of all manifests on the classpath? Will there be some marker attribute used to define a jar as a geoserver plugin?
The REST api looks good.
Can’t comment on whether 2.2.x is appropriate without looking at any code but in general this all sounds like mostly build work and additive code which shouldn’t be a problem.
$0.02
-Justin
On Thu, Nov 29, 2012 at 7:12 AM, Carlo Cancellieri <ccancellieri@anonymised.com> wrote:
… release (version)
… monitoring
… control flow
Ref.:
http://docs.oracle.com/javase/…//docs/api/java/util/jar/Manifest.html
Keep yourself connected to Go Parallel:
VERIFY Test and improve your parallel project with help from experts
and peers. http://goparallel.sourceforge.net
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Thu, Nov 29, 2012 at 3:55 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Carlo,
Wondering if the manifests can be generated automatically during the build, reading info from the pom files?
Maybe a custom maven build tool that is setup to run in the extension and community modules that would
generate these files?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea,
We only need to configure the maven jar (or war) plugin into the pom as in the shown into the examples:
I report it again:
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Nov 29, 2012 at 5:31 PM, Carlo Cancellieri <ccancellieri@anonymised.com…> wrote:
I report it again:
Ah ok, I missed it from the first mail.
I agree with Justin, we should add an extra element in the manifest to recognize
the GeoServer specific manifests, as other GeoServer unrelated jars will have a manifest
too.
Something like:
... GeoServerExtensions ...
Instead of adding a custom section in each and every module pom file we should try
to just put it in the extensions/community parent poms and check if they are inherited
from the child pom: this way we should avoid duplication and maintenance
Ing. Andrea Aime
@geowolf
Technical Lead
Yeah, I was thinking that this for the most part could be handled by the root pom, the root extension pom, and the root community module pom. I was thinking something like:
[core|extension|community]
On Thu, Nov 29, 2012 at 10:37 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Nov 29, 2012 at 5:31 PM, Carlo Cancellieri <ccancellieri@anonymised.com> wrote:
I report it again:
too.
Something like:
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
On Thu, Nov 29, 2012 at 5:43 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Ah, so we’d also list the core modules somewhere… could be useful, in case someone created
a GeoFrankenServer by putting togheter jars from different builds
Ing. Andrea Aime
@geowolf
Technical Lead
Yeah, I was thinking it couldn’t hurt.
I think implementing this should be pretty easy. In the root pom basically we add the manifest entry that looks like this:
${module.type}
(Changing the name to match I think what are standard manifest key naming conventions).
In the root prom we declare the property:
<module.type>core</module.type>
Then it is just a matter of overriding the property name in extension/pom.xml and community/pom.xml sub poms.
On Thu, Nov 29, 2012 at 10:44 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
Justin,
my intention is to keep things as simple and modular as possible to easily backport this improvement to the 2.2.x.
so: (inline)
I don’t like to force users to add a specific package dependency only to use a marker interface. So:
  • I chose the Manifest class as type to use for the lookup (but I don’t really like this, I’m still looking for a way to collect all the manifests files from the loaded jars… it should be possible from the spring context).
  • loading the manifest file for the core (GeoServer, GeoTools) can be delegated to a new bean (no hands on core classes, just xml spring and one new class).
Then, to make extensions ready for this improvement we only have to update their pom.
ok
Also agree for the core|community|… type marker into the parents pom modules.
To limit the depth of the sealing I can try to see if sealing is supported by the maven jar plugin
http://docs.oracle.com/javase/1.4.2/docs/guide/extensions/spec.html#sealing
Introducing this we will also be able to check the jars sign and much more.
-Justin
… release (version)
… monitoring
… control flow
Ref.:
Justin Deoliveira
Hy,
I’ll start a new branch soon introducing the pom changes and the core manifest bean loader to start looking into other options.Regards,
To: jdeolive@anonymised.com
CC: geoserver-devel@anonymised.comge.net
Subject: RE: [Geoserver-devel] REST Extensible and customizable versions report
Date: Thu, 29 Nov 2012 17:23:23 +0000
Justin,
so: (inline)
ok
-Justin
… release (version)
… monitoring
… control flow
Ref.:
Justin Deoliveira
I decided to make a simple lookup of jars using the classloader.
We support also search through:
Here is a first commit to take a look:
https://github.com/ccancellieri/geoserver/compare/master-REST-manifest-version
Note:
probably you don’t like Hudson keys into the pom? :slight_smile:
Example 1:
http://cio174:8080/geoserver/rest/about.xml?value=extension&key=GeoServerModule
04-Dec-2012 18:00
Web Processing Service parent
c:/Program Files/Java/jdk1.6.0_31
cancellieri
The Open Planning Project
org.geoserver.extension
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
extension
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
Example 2:
http://cio174:8080/geoserver/rest/about.xml?value=core&key=GeoServerModule
04-Dec-2012 18:00
GeoWebCache (GWC) Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Main Module
cancellieri
org.geoserver
Main Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Open Web Service Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Core Platform Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
REST Support Module
cancellieri
org.geoserver
REST Support Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
REST Configuration Service Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
GeoServer JDBC Security Module
cancellieri
org.geoserver.security
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
GeoServer LDAP Security Module
cancellieri
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Web Coverage Service Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Web Coverage Service 1.0 Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Web Coverage Service 1.1 Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Core UI Module
cancellieri
org.geoserver.web
Core UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Demoes Module
cancellieri
org.geoserver.web
Demoes Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
GWC UI Module
cancellieri
org.geoserver.web
GWC UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Security UI Module
cancellieri
org.geoserver.web
Security UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WCS UI Module
cancellieri
org.geoserver.web
WCS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WFS UI Module
cancellieri
org.geoserver.web
WFS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WMS UI Module
cancellieri
org.geoserver.web
WMS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Web Feature Service Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Web Map Service Module
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
To: jdeolive@anonymised.com; andrea.aime@anonymised.com
Date: Thu, 29 Nov 2012 17:27:41 +0000
CC: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] REST Extensible and customizable versions report
Hy,
CC: geoserver-devel@anonymised.comrceforge.net
Justin,
so: (inline)
ok
-Justin
… release (version)
… monitoring
… control flow
Ref.:
Justin Deoliveira
------------------------------------------------------------------------------ Keep yourself connected to Go Parallel: VERIFY Test and improve your parallel project with help from experts and peers. http://goparallel.sourceforge.net
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Hey Carlo,
Excited to see this work coming about. I am not sure how others feel but i imagine this is probably worthy of a gsip. Some questions/comments inline.
On Tue, Dec 4, 2012 at 10:31 AM, Carlo Cancellieri <ccancellieri@anonymised.com…> wrote:
Sorry, don’t quite understand this one, what does fromName / toName significy?
So the semantics is that any jar with a manifest entry named “core” would be matched. And similarly for value any jar with a manfifest entry whose value is “extension” would be matched?
Makes sense.
Anyways, looking quite nice. I think it would be good to sketch out the syntax/semantics of the rest api in a proposal so we can use that as a center for discussion around tweaking the api. A couple of things off the top of my head:
  • rename “regex” to “resource”, since it is matching soley on the resource name correct?
  • we may want to break out a separate collection for specifically the resources, in case we want to add other information as well, for example:
  • /rest/about/resources.xml → what you include below
  • /rest/about/version.xml → just the primary version info, what is currently included on the about page
That would leave it a bit more open ended in case we want to add more info under “about”.
Anyways, great stuff.
Note:
Example 1:
04-Dec-2012 18:00
cancellieri
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
extension
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
Example 2:
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Main Module
cancellieri
org.geoserver
Main Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
REST Support Module
cancellieri
org.geoserver
REST Support Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Core UI Module
cancellieri
org.geoserver.web
Core UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Demoes Module
cancellieri
org.geoserver.web
Demoes Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
GWC UI Module
cancellieri
org.geoserver.web
GWC UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Security UI Module
cancellieri
org.geoserver.web
Security UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WCS UI Module
cancellieri
org.geoserver.web
WCS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WFS UI Module
cancellieri
org.geoserver.web
WFS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WMS UI Module
cancellieri
org.geoserver.web
WMS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
To: jdeolive@anonymised.com; andrea.aime@…1268…
CC: geoserver-devel@anonymised.comrge.net
Hy,
CC: geoserver-devel@anonymised.comorge.net
Justin,
so: (inline)
ok
-Justin
… release (version)
… monitoring
… control flow
Ref.:
Justin Deoliveira
Justin Deoliveira
Justin,
We can have many resources loaded into the class loader so I decided to add minimal filtering capabilities to the request.
If you want, you can paginate the request using Alphabetical order (from resource named ‘a’ to resource named ‘b’ … and so on)
Right, so when I add my set of extensions with mine specific key, I’ll be able to filter all but mine resources.
OK
no prob
To do so, I’m thinking to use the same model having something like:
04-Dec-2012 18:00
2.3-SNAPSHOT
core
04-Dec-2012 18:00
8.x-SNAPSHOT
Is this acceptable for you?
Example 2:
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Main Module
cancellieri
org.geoserver
Main Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
REST Support Module
cancellieri
org.geoserver
REST Support Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Core UI Module
cancellieri
org.geoserver.web
Core UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Demoes Module
cancellieri
org.geoserver.web
Demoes Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
GWC UI Module
cancellieri
org.geoserver.web
GWC UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
Security UI Module
cancellieri
org.geoserver.web
Security UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WCS UI Module
cancellieri
org.geoserver.web
WCS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WFS UI Module
cancellieri
org.geoserver.web
WFS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
WMS UI Module
cancellieri
org.geoserver.web
WMS UI Module
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
04-Dec-2012 18:00
cancellieri
org.geoserver
2.3-SNAPSHOT
2.3-SNAPSHOT
1.0
core
Apache Maven
1.6.0_31
2.3-SNAPSHOT
Plexus Archiver
Hy,
Justin,
so: (inline)
ok
-Justin
On Thu, Nov 29, 2012 at 7:12 AM, Carlo Cancellieri <ccancellieri@anonymised.com…> wrote:
… release (version)
… monitoring
… control flow
Ref.:
Justin Deoliveira
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@anonymised.comsts.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Justin Deoliveira
On Wed, Dec 5, 2012 at 11:11 AM, Carlo Cancellieri <ccancellieri@anonymised.com
wrote:
Justin,
- resource name (from-to
http://cio174:8080/geoserver/rest/about.xml?fromName=&lt;http://cio174:8080/geoserver/rest/about.xml?value=extension&gt;a&amp;toName=b
>Sorry, don't quite understand this one, what does fromName / toName
significy?
resource named 'a' to resource named 'b' ... and so on)
Ahh ok, that makes more sense.
- resource name regex http://cio174:8080/geoserver/rest/about.xml?value=extension&gt;regex=gt\.\*
- key (http://cio174:8080/geoserver/rest/about.xml?key=c&lt;http://cio174:8080/geoserver/rest/about.xml?value=extension&gt;ore
- value (http://cio174:8080/geoserver/rest/about.xml?value=extension )
> So the semantics is that any jar with a manifest entry named "core"
whose value is "extension" would be matched?
Right, so when I add my set of extensions with mine specific key, I'll be
tweaking the api.
OK
> * rename "regex" to "resource", since it is matching soley on the
> * we may want to break out a separate collection for specifically the
> - /rest/about/resources.xml -> what you include below
no prob
> - /rest/about/version.xml -> just the primary version info, what is
info under "about".
To do so, I'm thinking to use the same model having something like:
<about>
<resource name="main-2.3-SNAPSHOT">
<Build-Time>04-Dec-2012 18:00</Build-Time>
<Implementation-Vendor>The Open Planning Project</Implementation-Vendor>
<Application-Version>2.3-SNAPSHOT</Application-Version>
<GeoServerModule>core</GeoServerModule>
</resource>
<resource name="gt-8.x-SNAPSHOT">
<Implementation-Vendor>...</Implementation-Vendor>
<Application-Version>8.x-SNAPSHOT</Application-Version>
</resource>
</about>
Is this acceptable for you?'
Hmmm... so the idea is that to provide the basic version info we just
provide the resource representation for the geoserver main, geotools main,
and gwc core jars or something like that? That would indeed do it but i
guess i was thinking about something more direct like:
GET /rest/about/version.xml
<version>
  <GeoServer>
     <Version></Version>
     <BuildRevision></BuildRevision>
     <BuildTime></BuildTime>
  </GeoServer>
  <GeoTools>
  </GeoTools>
  <GeoWebCache>
  </GeoWebCache>
</version>
Basically the equivalent of what the current about page does.
Example 2:
<about>
<resource name="gwc-2.3-SNAPSHOT">
<Implementation-Title>GeoWebCache (GWC) Module</Implementation-Title>
<HudsonJavaHome>c:/Program Files/Java/jdk1.6.0_31</HudsonJavaHome>
<Built-By>cancellieri</Built-By>
<HudsonJobName/>
<Iteration-Name/>
<Implementation-Vendor-Id>org.geoserver</Implementation-Vendor-Id>
<HudsonWorkspace/>
<Specification-Title>GeoWebCache (GWC) Module</Specification-Title>
<HudsonSvnRevision/>
<HudsonSvnTag/>
<Implementation-Version>2.3-SNAPSHOT</Implementation-Version>
<Application-Name/>
<Specification-Vendor>The Open Planning Project</Specification-Vendor>
<Manifest-Version>1.0</Manifest-Version>
<Created-By>Apache Maven</Created-By>
<HudsonBuildNumber/>
<HudsonUrl/>
<Build-Jdk>1.6.0_31</Build-Jdk>
<HudsonBuildId/>
<Specification-Version>2.3-SNAPSHOT</Specification-Version>
<HudsonExecutorNumber/>
<Archiver-Version>Plexus Archiver</Archiver-Version>
<HudsonBuildTag/>
</resource>
<Implementation-Title>Main Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Main Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="ows-2.3-SNAPSHOT">
<Implementation-Title>Open Web Service Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Open Web Service Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="platform-2.3-SNAPSHOT">
<Implementation-Title>Core Platform Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Core Platform Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="rest-2.3-SNAPSHOT">
<Implementation-Title>REST Support Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>REST Support Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="restconfig-2.3-SNAPSHOT">
<Implementation-Title>REST Configuration Service Module
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>REST Configuration Service Module
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="sec-jdbc-2.3-SNAPSHOT">
<Implementation-Title>GeoServer JDBC Security Module
<HudsonJobName/>
<Iteration-Name/>
<Implementation-Vendor-Id>org.geoserver.security
<HudsonWorkspace/>
<Specification-Title>GeoServer JDBC Security Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="sec-ldap-2.3-SNAPSHOT">
<Implementation-Title>GeoServer LDAP Security Module
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>GeoServer LDAP Security Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="wcs-2.3-SNAPSHOT">
<Implementation-Title>Web Coverage Service Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Web Coverage Service Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="wcs1_0-2.3-SNAPSHOT">
<Implementation-Title>Web Coverage Service 1.0 Module
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Web Coverage Service 1.0 Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="wcs1_1-2.3-SNAPSHOT">
<Implementation-Title>Web Coverage Service 1.1 Module
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Web Coverage Service 1.1 Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="web-core-2.3-SNAPSHOT">
<Implementation-Title>Core UI Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<Implementation-Vendor-Id>org.geoserver.web</Implementation-Vendor-Id>
<HudsonWorkspace/>
<Specification-Title>Core UI Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="web-demo-2.3-SNAPSHOT">
<Implementation-Title>Demoes Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Demoes Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="web-gwc-2.3-SNAPSHOT">
<Implementation-Title>GWC UI Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>GWC UI Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="web-security-2.3-SNAPSHOT">
<Implementation-Title>Security UI Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Security UI Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="web-wcs-2.3-SNAPSHOT">
<Implementation-Title>WCS UI Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>WCS UI Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="web-wfs-2.3-SNAPSHOT">
<Implementation-Title>WFS UI Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>WFS UI Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="web-wms-2.3-SNAPSHOT">
<Implementation-Title>WMS UI Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>WMS UI Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="wfs-2.3-SNAPSHOT">
<Implementation-Title>Web Feature Service Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Web Feature Service Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
<resource name="wms-2.3-SNAPSHOT">
<Implementation-Title>Web Map Service Module</Implementation-Title>
<HudsonJobName/>
<Iteration-Name/>
<HudsonWorkspace/>
<Specification-Title>Web Map Service Module</Specification-Title>
<HudsonSvnTag/>
<Application-Name/>
<HudsonUrl/>
<HudsonBuildId/>
<HudsonBuildTag/>
</resource>
</about>
report
Hy,
I'll start a new branch soon introducing the pom changes and the core
report
Justin,
so: (inline)
I don't like to force users to add a specific package dependency only to
- I chose the Manifest class as type to use for the lookup (but I don't
really like this, I'm still looking for a way to collect all the manifests
files from the loaded jars... it should be possible from the spring
context).
- loading the manifest file for the core (GeoServer, GeoTools) can be
new class).
their pom.
plugin?
ok
Also agree for the core|community|... type marker into the parents pom
modules.
-Justin
.. release (version)
.. revision (svn tag or git hash)
.. build date (optional)
.. monitoring
.. control flow
1. Each project or extension may register it's Manifest bean into the
spring context
'.format' format will be returned listing all of the registered Manifest
I'll setup for my custom plugin manifest entries adding hudson environment
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-jar-plugin</artifactId>
<configuration>
<archive>
<manifest>
  <addDefaultImplementationEntries>true</addDefaultImplementationEntries>
  <addDefaultSpecificationEntries>true</addDefaultSpecificationEntries>
</manifest>
<manifestEntries>
<Application-Name>${project.build.finalname}</Application-Name>
<Application-Version>${project.version}</Application-Version>
<Iteration-Name>${iteration}</Iteration-Name>
<Build-Time>${maven.build.timestamp}</Build-Time>
<HudsonBuildNumber>${BUILD_NUMBER}</HudsonBuildNumber>
<HudsonBuildId>${BUILD_ID}</HudsonBuildId>
<HudsonJobName>${JOB_NAME}</HudsonJobName>
<HudsonBuildTag>${BUILD_TAG}</HudsonBuildTag>
<HudsonExecutorNumber>${EXECUTOR_NUMBER}</HudsonExecutorNumber>
<HudsonJavaHome>${JAVA_HOME}</HudsonJavaHome>
<HudsonWorkspace>${WORKSPACE}</HudsonWorkspace>
<HudsonUrl>${HUDSON_URL}</HudsonUrl>
<HudsonSvnRevision>${SVN_REVISION}</HudsonSvnRevision>
<HudsonSvnTag>${SVN_TAG}</HudsonSvnTag>
</manifestEntries>
</archive>
</configuration>
</plugin>
2. A simple example for geoserver with monitoring plugin installed into
the lib dir:
password)
<about>
<GeoServer>
<Project-version>..--SNAPSHOT</Project-version>
<Build-Jdk>....--rc<</<Build-Jdk>
<Project-revision>daabbfaafbbfddbbbeffabbbb674bbbb1361ddd<</Project-revision>
</GeoServer>
<GeoTools>
<Project-version>--SNAPSHOT</Project-version>
<Project-revision>fff8aaaf435477737fff915bbbc3862cccb145<<</Project-revision>
</GeoTools>
<Monitoring>
<Project-revision>fff8aaaf435477737fff915bbbc3862cccb146<<</Project-revision>
</Monitoring>
</about>
3. A simple example for geoserver with monitoring and my custom plugin
<about>
<GeoServer>
</GeoServer>
<GeoTools>
</GeoTools>
<Monitoring>
</Monitoring>
<MyCustom>
<Project-version>1.0.--SNAPSHOT</Project-version>
  <Application-Name>MyCustom</Application-Name>
  <Application-Version>..--SNAPSHOT</Application-Version>
  <Build-Time>...</Build-Time>
  <HudsonBuildNumber>9<<</HudsonBuildNumber>
  <HudsonBuildId><</HudsonBuildId>
  <HudsonJobName>GEO_TS_GEOSERVER_MyCustom_BUILD</HudsonJobName>
  <HudsonBuildTag>2<<</HudsonBuildTag>
  <HudsonExecutorNumber><</HudsonExecutorNumber>
  <HudsonJavaHome>..</HudsonJavaHome>
  <HudsonWorkspace>...</HudsonWorkspace>
  <HudsonUrl>http://…</HudsonUrl>
  <HudsonSvnRevision>r093<<</HudsonSvnRevision>
  <HudsonSvnTag>REL_79<<</HudsonSvnTag>
</MyCustom>
</about>
Ref.:
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
On Wed, Dec 5, 2012 at 7:11 PM, Carlo Cancellieri <ccancellieri@anonymised.com…> wrote:
Justin,
Hmm… I know we’re talking about small amounts of information here, but wouldn’t it be better
to separate filtering and paging?
Regexp and other means for filtering, paging though the usual startIndex and maxItems constructs?
(assuming there is even a need to page stuff, we’re in the ballpark of 100 items today, right?)
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Dec 6, 2012 at 1:36 AM, Andrea Aime <andrea.aime@anonymised.com>wrote:
Justin,
significy?
Hmm.. I know we're talking about small amounts of information here, but
wouldn't it be better
(assuming there is even a need to page stuff, we're in the ballpark of 100
Agreed. Actually paging is something i have been looking at adding to the
catalog portion of the rest api as well.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
Proposal:
http://geoserver.org/pages/viewpage.action?pageId=55574531
Date: Thu, 6 Dec 2012 08:11:36 -0700
To: andrea.aime@anonymised.com
CC: ccancellieri@anonymised.com; geoserver-devel@lists.sourceforge.net
On Thu, Dec 6, 2012 at 1:36 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Dec 5, 2012 at 7:11 PM, Carlo Cancellieri <ccancellieri@anonymised.com> wrote:
Justin,
Agreed. Actually paging is something i have been looking at adding to the catalog portion of the rest api as well.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
