[Geoserver-devel] Rest Swagger Doc QA - Unimplemented parameters
I am doing a QA pass on the current swagger docs for the rest API.
I have ran into a parameter that is documented, but does not appear to be implemented:
For /workspaces/{workspace}/coveragestores/{store}/{method}.{format} POST (coverage store file upload / granule harvest), the filename parameter appears in the docs, but does not show up anywhere in the code.
Looking at the old docs, this parameter is also documented there. Did this functionality get lost during the REST API upgrade? (Andrea - looks like you converted this endpoint?)
Torben
Similarly, the granule delete endpoint (/workspaces/{workspace}/coveragestores/{store}/granules/{granuleId:.+}/{format}) has an optional format path variable that is declared in the code but never appears to be used, and is largely undocumented.
Torben
On Fri, Sep 15, 2017 at 3:24 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Found another parameter that is declared in the code, but never actually used: The “purge” parameter for datastore delete.
David - looks like you converted this endpoint, any comment?
Torben
On Fri, Sep 15, 2017 at 5:06 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Torben
appears in the docs
<http://docs.geoserver.org/api/#/1.0.0/coveragestores.yaml&gt;, but does not
<Coverage stores — GeoServer 2.25.x User Manual,
endpoint?)
I located the handling of this parameter in
"AbstractStoreUploadController". Looks like the parameter was getting
manually pulled from the request. Modifying implementation to pass the
filename parameter in after retrieving it as a @RequestParam for
transparency.
Torben
As far as i can determine, this structure is used to determine the output
format, and is included solely for compatibility with gsconfig.
used: The "purge" parameter for datastore delete.
As far as I can tell, this was blindly copied from the coveragestore
delete code, as I can find no purge parameter for datastore delete in the
old rest api.
For coveragestore, purge is used to delete the underlying files in addition
to the store; is this something that could be useful for datastore? I feel
like databases might make this a bit more complicated.
Torben
If the datastore is JDBC, I think the purge makes sense to remove the underlying tables. I know we thought of a process for user defined layers, where users get to upload shapefiles that are ingested into the database as tables to specific schemas (PostgreSQL/PostGIS tables). When the layer is no longer required, removing them requires the GeoServer layer entries to be deleted, then a DB admin is required to manually drop the tables in the database. Having the PURGE on the REST call would make things, in our case, easier.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, A Polaris Alpha Company
Description: Description: Description: cid:image001.png@...3926...
(attachments)
As far as I can tell, this was blindly copied from the coveragestore delete code, as I can find no purge parameter for datastore delete in the old rest api.
For coveragestore, purge is used to delete the underlying files in addition to the store; is this something that could be useful for datastore? I feel like databases might make this a bit more complicated.
Torben
Typically, individual tables become featureTypes, while the store represents the database (or schema) as a whole.
Since the purge parameter is currently only associated with stores, that would result in deleting the whole database, not just a table.
However, this suggests that adding a purge parameter to featureType delete may be useful in the case of database stores.
Torben
(attachments)
On Mon, Sep 18, 2017 at 3:48 PM, Chris Snider <chris.snider@anonymised.com> wrote:
Chris Snider
Description: Description: Description: cid:image001.png@anonymised.com
From: Torben Barsballe [mailto:tbarsballe@boundlessgeo.com]
Sent: Monday, September 18, 2017 4:01 PM
To: geoserver-devel <geoserver-devel@anonymised.comsourceforge.net>
Subject: Re: [Geoserver-devel] Rest Swagger Doc QA - Unimplemented parameters
Torben
Torben,
I think the purge might be useful at both database, or more likely the schema level, as well as featureType levels. Definitely something that a GeoServer administrator would want to have locked down though J. Don’t want random removal of entire schemas from the database.
Chris Snider
(attachments)
Torben
On Mon, Sep 18, 2017 at 3:48 PM, Chris Snider <chris.snider@…4594…> wrote:
Chris Snider
To: geoserver-devel <geoserver-devel@lists.sourceforge.net>
Torben
Added the results of this discussion as a new JIRA issue here: https://osgeo-org.atlassian.net/browse/GEOS-8296
As for the docs, for now I’ll remove the unimplemented parameters.
Torben
(attachments)
On Mon, Sep 18, 2017 at 4:03 PM, Chris Snider <chris.snider@anonymised.com> wrote:
Torben,
Chris Snider
Sent: Monday, September 18, 2017 4:58 PM
To: Chris Snider <chris.snider@anonymised.com>
Cc: geoserver-devel <geoserver-devel@anonymised.comsourceforge.net>
Torben
On Mon, Sep 18, 2017 at 3:48 PM, Chris Snider <chris.snider@anonymised.com4594…> wrote:
Chris Snider
Description: Description: Description: cid:image001.png@anonymised.com.
Torben
