HI Devs,
I am interested in the project to implement a RestConfig client for Geo server using the existing A.Since i am new to Geoserve i started from building the trunk and following the sample tutorials
to understand the project.I was able to test run with in the IDE and deploy in tomcat externally to test.I would like to get some help to move forward with the project.
I have started looking at Restlet [1] and the RestConfig api in the code base.I was able to find sample code for REST configuration which are in PHP .If you can help me with some ideas and some intial steps i should follow it would be a great help.
Thank you.
[1]http://www.restlet.org/
Shelan Perera
Blog : http://www.shelanlk.com
Twitter: shelan
skype :shelan.perera
gtalk :shelanrc
I am the master of my fate:
I am the captain of my soul.
invictus
There’s actually already a Java client for RESTConfig in the community modules section of the source repository - so a good first step would be to read over that code and try to use it for a few tasks. If you don’t find any bugs while doing that, perhaps you could start working on a section of the manual explaining how to use the API.
The project I am talking about is at http://svn.codehaus.org/geoserver/trunk/src/community/restconfig-java/
Hope this helps.
David Winslow
OpenGeo - http://opengeo.org/
On Thu, Jan 27, 2011 at 5:24 AM, shelan Perera <shelanrc@anonymised.com> wrote:
HI Devs,
Thank you.
Shelan Perera
Twitter: shelan
gtalk :shelanrc
invictus
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
Geoserver-devel mailing list
Hi David
Thank You very much.I will have look and test the implementation.
On Thu, Jan 27, 2011 at 6:54 PM, David Winslow <dwinslow@anonymised.com> wrote:
Hope this helps.
David Winslow
HI Devs,
Thank you.
Shelan Perera
Twitter: shelan
gtalk :shelanrc
invictus
Shelan Perera
Twitter: shelan
gtalk :shelanrc
invictus
