[Geoserver-devel] Restconfig: putting resources with rest: which response's entity should be set when resource is created?
Hi list,
I’m doing some work on improving restconfig.
When putting some resource via rest in geoserver, in case everything goes ok, you will receive a response with a return code = 201 → handlePut does this: getResponse().setStatus( Status.SUCCESS_CREATED );
From 1 I see that the response should contain some info about the newly created resource.
This can be achieved by properly setting an Entity in the response, before setting Status.SUCCESS_CREATED.
Actually, geoserver simply set CREATED in the response without any additional info. Therefore, there isn’t any information about the just added layer.
Which type of information should we provide within the response?
Any feedback is welcome.
Daniele
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
I'd say at least the layer name so that I can query it right away.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Fri, May 8, 2009 at 10:05 AM, Daniele Romagnoli
<daniele.romagnoli@anonymised.com> wrote:
Hi list,
I'm doing some work on improving restconfig.
ok, you will receive a response with a return code = 201 --> handlePut does
>From [1] I see that the response should contain some info about the newly
created resource.
additional info. Therefore, there isn't any information about the just added
layer.
Daniele
[1]: http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-devel mailing list
hi Daniele,
Where exaclty is a 201 being set as the response code for a PUT. The semantic we are following for restconfig is to have PUT only be used to modify existing resources, therefore only returning a 200.
POST being used to create new resources on the other hand does return a 201.. And it sets the Location header in the response, pointing at the newly created resource. If you look at ReflectiveResource.handlePost() you will see what I mean.
That said, we could use PUT to allow for creation of resoures, it is perfectly valid with regard to HTTP. What is your use case here?
-Justin
Daniele Romagnoli wrote:
Hi list,
When putting some resource via rest in geoserver, in case everything goes ok, you will receive a response with a return code = 201 --> handlePut does this: getResponse().setStatus( Status.SUCCESS_CREATED );
>From [1] I see that the response should contain some info about the newly created resource.
Actually, geoserver simply set CREATED in the response without any additional info. Therefore, there isn't any information about the just added layer.
Daniele
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
I’m talking about the CoverageStoreFileResource which allows to add a new coverage using the following syntax with PUT:
/workspaces/<ws>/coveragestores/<cs>/file[.<extension>]
I have noticed that when done, it returns a STATUS_CREATED in the response.
Daniele
On Fri, May 8, 2009 at 3:55 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
hi Daniele,
POST being used to create new resources on the other hand does return a 201… And it sets the Location header in the response, pointing at the newly created resource. If you look at ReflectiveResource.handlePost() you will see what I mean.
-Justin
Hi list,
Daniele
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Kodak, there’s a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you’ll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Right, after looking at the commits I noticed this was the case, which is sort of a special case.
As per your comment:
  >From [1] I see that the response should contain some info
  > about the newly created resource.
Where exactly is this. I read the specification of the PUT method and did not see such a reference.
-Justin
Hi Justin,
I'm talking about the CoverageStoreFileResource which allows to add a new coverage using the following syntax with PUT:
Daniele
On Fri, May 8, 2009 at 3:55 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    hi Daniele,
    -Justin
        Hi list,
        Daniele
        Software Engineer
        Via Carignoni 51
        55041 Camaiore (LU)
        fax: +39 0584983027
        circumstances! Your
        thanks to
        NEW KODAK i700
        <mailto:Geoserver-devel@lists.sourceforge.net>
    -- Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
On Fri, May 8, 2009 at 5:01 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Is the paragraph 10.2.2 - 201 Created
Daniele
-Justin
Hi Justin,
/workspaces//coveragestores//file[.]
Daniele
On Fri, May 8, 2009 at 3:55 PM, Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:
hi Daniele,
-Justin
Hi list,
Daniele
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
circumstances! Your
thanks to
NEW KODAK i700
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comrge.net)
– Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Thanks, so the paragraph states:
"The newly created resource can be referenced by the URI(s) returned in the entity of the response, with the most specific URI for the resource given by a Location header field. The response SHOULD include an entity containing a list of resource characteristics and location(s) from which the user or user agent can choose the one most appropriate"
So, we need to do a couple of things:
1) Set the 'Location' header. I am not sure exactly what it should be in this case. This operation is not technically RESTful for a couple of reasons:
   a) There is information built directly into the URI (the file.format) part
   b) It results in resources be created elsewhere, ie under "...coverages/<coverage>", i am pretty sure this violates the semantics of PUT
2) Set the entity to something
I suggest we should do the following:
Set the returned entity should be the serialized coverages stores. The serialized store contains links to the coverages inside of it, so a client can proceed to get at the coverage (if it was created) as it sees fit.
We also set the Location header to be the uri of the coverage store.
What do you think?
On Fri, May 8, 2009 at 5:01 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
Daniele
    -Justin
        Hi Justin,
        the response.
        Daniele
           hi Daniele,
        PUT. The
        be used
        resoures, it is
           -Justin
               Hi list,
        without
        response?
               Daniele
               Software Engineer
               Via Carignoni 51
               55041 Camaiore (LU)
               fax: +39 0584983027
               circumstances! Your
        world - but
               thanks to
        With the
               NEW KODAK i700
        <mailto:Geoserver-devel@lists.sourceforge.net>>
        Software Engineer
        Via Carignoni 51
        55041 Camaiore (LU)
        fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
