David or other RESTful API enthusiasts,
I’m trying to DELETE a shapfile which I’ve successfully PUT with:
curl -Tbundle.zip http://localhost:8080/geoserver/rest/folders/foo/file.shp
Since delete seems to be implemented:
(http://geoserver.org/display/GEOSDOC/RESTful+Configuration+API)
I was hoping I could do an HTTP delete at the same URL but that doesn’t work.
Looking at DataStoreFileResource: ( http://fisheye.codehaus.org/browse/geoserver/trunk/geoserver/community/RESTConfig/src/main/java/org/geoserver/restconfig/DataStoreFileResource.java?r=8750)
It doesn’t have an allowDelete() method.
Is it possible to delete a shapefile via the RESTful API?
Sam
I’m trying to do a RESTful DELETE of a shapefile which I’ve successfully PUT with:
Sam
Hi Sam,
I think this is a failing of the documentation rather than the code. Deleting shapefiles is not implemented; however, you can hide a shapefile by DELETE'ing its configuration. Something like:
curl -XDELETE http://localhost:8080/geoserver/rest/folders/foo
This leaves the shapefile on disk, but removes it from the GeoServer configuration so that it isn't served. I don't think excluding DELETE was an explicit design decision, so adding that in should be fine. I'll take a look sometime soon, but if you want to try and put together a patch I'm happy to advise ('soon' may be relative in this particular case).
Hope this helps,
David Winslow
Sam Brodkin wrote:
I'm trying to do a RESTful DELETE of a shapefile which I've successfully PUT with:
I was hoping I could do an HTTP delete at the same URL but that doesn't work.
It doesn't have an allowDelete() method.
Sam
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-devel mailing list
