[Geoserver-devel] retriving data from postgisDB with geoserver ?
Hi
I hope someone can help me out here. (sorry the long posting)
I have an postgisDB (postgis 0.7.3) running with an mapserver and ~10 layers
I wanted to try out to use geoserver (0.93) to retrive the data from the postgisDB, and
have made the info.xml & schema.xml files, but when trying to retrive data with
http://<hostname>:8080/geoserver/GetFeature?version=1.0.0&typeName=bjorneklo
I will get the attached http error:
it seems that the geoserv don't recive the selected data from postgis, when making the
sql "SELECT oid, gid, forekomst, comment, email, ip, dato, lokalitet, antal, areal, AsText(the_geom), objectid FROM
bjorneklo LIMIT 500;" mannualy the result for the testdata i 7 lines.
So what goes wrong ? did I do somthing wrong in the info/scema.xml file ?
regards
niels
-- (http error)
- <WFS_Exception>
  - <Exception>
      <Locator>Class FeatureResponse, in method getQuery</Locator>
  - <Message>
      While getting features from datasource: Error from the result set: null
    </Message>
  </Exception>
</WFS_Exception>
- the connection to the DB is ok, I can se several sql requests in the /usr/local/pgsql/data/serverlog like:
DEBUG: StartTransactionCommand
DEBUG: query: SELECT type FROM GEOMETRY_COLUMNS WHERE f_table_name='bjorneklo' AND f_geometry_column='the_geom';
DEBUG: ProcessQuery
DEBUG: CommitTransactionCommand
DEBUG: query: SELECT srid FROM GEOMETRY_COLUMNS WHERE f_table_name='bjorneklo';
DEBUG: ProcessQuery
DEBUG: query: SELECT '' as TABLE_CAT,'' AS TABLE_SCHEM,bc.relname AS TABLE_NAME,a.attname AS COLUMN_NAME,a.attnum as KEY_SEQ,ic.relname as PK_NAME FROM pg_class bc, pg_class ic, pg_index i, pg_attribute a WHERE bc.relkind = 'r' and upper(bc.relname) = upper('bjorneklo') and i.indrelid = bc.oid and i.indexrelid = ic.oid and ic.oid = a.attrelid and i.indisprimary='t' ORDER BY table_name, pk_name, key_seq
DEBUG: ProcessQuery
DEBUG: query: SELECT oid, gid, forekomst, comment, email, ip, dato, lokalitet, antal, areal, AsText(the_geom), objectid FROM
DEBUG: ProcessQuery
the log from /var/log/catalina.out says:
java.lang.NullPointerException
        at org.geotools.feature.FeatureFlat.createNew(FeatureFlat.java:115)
        at org.geotools.feature.FeatureFlat.<init>(FeatureFlat.java:70)
        at org.geotools.feature.FeatureFactory.create(FeatureFactory.java:94)
        at org.geotools.data.postgis.PostgisDataSource.getFeatures(PostgisDataSource.java:584)
        at org.geotools.data.postgis.PostgisDataSource.getFeatures(PostgisDataSource.java:512)
        at org.vfny.geoserver.responses.FeatureResponse.getQuery(Unknown Source)
        at org.vfny.geoserver.responses.FeatureResponse.getXmlResponse(Unknown Source)
        at org.vfny.geoserver.servlets.Feature.doGet(Unknown Source)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:247)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:260)
        at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643)
        at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480)
        at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2415)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:180)
        at org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.java:170)
        at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:641)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:172)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:174)
        at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:223)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:432)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:386)
        at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:534)
        at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:530)
        at java.lang.Thread.run(Thread.java:536)
the table bjorneklo is created as:
             Table "bjorneklo"
  Column | Type | Modifiers
gid | integer |
forekomst | character varying |
comment | character varying |
email | character varying |
ip | character varying |
dato | character varying |
lokalitet | character varying |
antal | character varying |
areal | character varying |
the_geom | geometry |
objectid | integer |
Check constraints: "$1" (srid(the_geom) = -1)
                   "$2" ((geometrytype(the_geom) = 'POINT'::text) OR (the_geom IS NULL))
info.xml:
<featureType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
  <Name>bjorneklo</Name>
  <Title>Forekomster af Bjorneklo</Title>
  <Abstract>Forekomster af bjorneklo i Viborg Amt</Abstract>
  <Keywords>Bjorneklo, Viborg Amt</Keywords>
  <SRS>EPSG:23032</SRS>
  <Operations/>
  <LatLonBoundingBox minx="-174.561" miny="-8.20422e+12" maxx="154.107" maxy="8.20422e+12" />
   <MetadataURL>
    <url>none</url>
    <format>XML</format>
    <type>TC211</type>
  </MetadataURL>
  <Host>localhost</Host>
  <Port>5432</Port>
  <DatabaseName>vibamt</DatabaseName>
  <User>gis</User>
  <Password></Password>
</featureType>
scema.xml :
<xs:complexType name="bjorneklo_Type">
    <xs:complexContent>
      <xs:extension base="gml:AbstractFeatureType">
        <xs:sequence>
          <xs:element name="bjorneklo.gid" nillable="true" minOccurs="0" maxOccurs="1">
          </xs:element>
          <xs:element name="bjorneklo.forekomst" nillable="true" minOccurs="0" maxOccurs="1">
            <xs:simpleType>
              <xs:restriction base="xs:string">
                <xs:maxLength value="100"/>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          <xs:element name="bjorneklo.comment" nillable="true" minOccurs="0" maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          <xs:element name="bjorneklo.email" nillable="true" minOccurs="0" maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          <xs:element name="bjorneklo.ip" nillable="true" minOccurs="0" maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          <xs:element name="bjorneklo.dato" nillable="true" minOccurs="0" maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          <xs:element name="bjorneklo.lokalitet" nillable="true" minOccurs="0" maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          <xs:element name="bjorneklo.antal" nillable="true" minOccurs="0" maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          <xs:element name="bjorneklo.areal" nillable="true" minOccurs="0" maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          <xs:element name="bjorneklo.the_geom" type="gml:PointPropertyType" nillable="false" minOccurs="1" maxOccurs="1"/>
          <xs:element name="bjorneklo.objectid" nillable="true" minOccurs="0" maxOccurs="1">
          </xs:element>
        </xs:sequence>
      </xs:extension>
    </xs:complexContent>
  </xs:complexType>
No, you're doing nothing wrong, and the info.xml and schema.xml files look
fine. And don't apologize for the long post...we much prefer the detailed
message you've provided, as it makes it far easier to figure out exactly
what's going wrong. You've run across a bug in the last release that
doesn't deal with null values from postgis. If you were to remove all
rows that have nulls for one or more of their columns then it should work.
This is because geotools, on top of which geoserver is built, initially
did not allow nulls in features, in order to simplify things. This bug is
fixed in CVS, and will be the next release. I should get the 0.94 release
out sometime friday the 11th (though it's probably going to be later in
the day US time, as I'm getting a bit behind this week, but you'll
definitely be able to download it on the 12th). So you can get rid of the
null rows, or just wait till next week and get the latest version
(which is recommended, as there are other bug fixes and improvements).
Chris
On Wed, 9 Apr 2003, Niels Svennekjær wrote:
Hi
postgisDB, and
data with
when making the
regards
niels
-- (http error)
- <WFS_Exception>
  - <Exception>
  - <Message>
null
    </Message>
  </Exception>
</WFS_Exception>
DEBUG: ProcessQuery
DEBUG: ProcessQuery
DEBUG: ProcessQuery
DEBUG: ProcessQuery
        at
        at
        at
Source)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
             Table "bjorneklo"
gid | integer |
(the_geom IS NULL))
info.xml:
  <Operations/>
   <MetadataURL>
    <url>none</url>
    <type>TC211</type>
  </MetadataURL>
  <Port>5432</Port>
  <User>gis</User>
</featureType>
scema.xml :
    <xs:complexContent>
        <xs:sequence>
maxOccurs="1">
          </xs:element>
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
          </xs:element>
        </xs:sequence>
      </xs:extension>
  </xs:complexType>
This sf.net email is sponsored by:ThinkGeek
Welcome to geek heaven.
http://thinkgeek.com/sf
Geoserver-devel mailing list
Hi
OK, I did take the CVS solution, and now I don't get any errors in any of the logfiles
but still no data comes, the result is:
request:
http://131.165.211.29:8080/geoserver/GetFeature?version=1.0.0&typeName=bjorneklo
response:
- <ServiceExceptionReport version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc ../wfs/1.0.0/OGC-exception.xsd">
- <ServiceException locator="Class FeatureResponse, in method getQuery">
         Could not find Feature Type named: bjorneklo, feature information is not in the data folder.
    </ServiceException>
</ServiceExceptionReport>
but it now seems that it never reachec the DB, are there extra infos to be adapted to the
xml files ? (config, build, info, schema)
the info & schema resides in /var/tomcat4/webapps/geoserver/data/featureTypes/bjorneklo
- niels
rows that have nulls for one or more of their columns then it should work. This is because geotools, on top of which geoserver is built, initially
Chris
<snip, please look at old posting :slight_smile: />
Hmmm... So cvs has a number of changes to properly handle namespaces, but
I thought I made everything backwards compatible. It might work if you
try it with the proper namespace prefix. To figure out what that is do a
GetCapabilities request, and look at the name of the feature, it should
probably be myns:bjorneklo (although the prefix may be different). So
your request should be
http://131.165.211.29:8080/geoserver/GetFeature?typeName=myns:bjorneklo
If that doesn't work than go to the source of
org.vfny.geoserver.servlets.FreefsLog and change line 34 to Level.FINER,
and send me the output from the log when you try the request. (Yes, I am
going to make it easier to change the logging, if not this release than
the one after).
Hope this helps,
Chris
Hi
of the logfiles
request:
response:
    </ServiceException>
be adapted to the
- niels
>Chris
Didn't work
the one after).
Ahh, there was the debuglevel controle, FINER didn't give so mutch info so I did use FINEST
(and now there was comming output)
The following 4 dir's is in data/featuretype: bjorneklo, rail, roads, topp:road
but 'roads' is empty in CVS
There have been made following 3 requests
http://131.165.211.29:8080/geoserver/GetFeature?typeName=bjorneklo
The first have been made 2 times because the first time if did return an Execption
java.lang.NullPointerException at java.util.Hashtable.put(Hashtable.java:389)
at java.util.Properties.setProperty(Properties.java:102)
at org.vfny.geoserver.config.FeatureType.getDataParams(Unknown Source)
at org.vfny.geoserver.config.FeatureType.getInstance(Unknown Source)
at org.vfny.geoserver.config.TypeInfo.readTypeInfo(Unknown Source)
at org.vfny.geoserver.config.TypeInfo.(Unknown Source)
The catalina.out log is attached (I don''t know if that will come trough sourceforge)
- niels
(attachments)
catalina.out (15.8 KB)
Ok, I got it. Thanks for the logs, and for taking the time to investigate
this bug, I definitely wouldn't have found it on my own for this release.
The problem was that the password tag had nothing in it, and in my
changing of the configuration, I accidentally was trying to put a null
instead of an empty string if I didn't find a value. So it's now fixed in
CVS, and should hopefully get things working for you. Just do an update,
and it should come in.
thanks,
  Chris
Didn't work
>the one after).
so I did use FINEST
topp:road
Execption
sourceforge)
- niels
Hi
Thanks, it works now, and I am getting the data now in XML as expected.
(though another challenge did occure, but I will create an new threat aboud that)
- niels
Ok, I got it. Thanks for the logs, and for taking the time to investigate this bug, I definitely wouldn't have found it on my own for this release. The problem was that the password tag had nothing in it, and in my changing of the configuration, I accidentally was trying to put a null instead of an empty string if I didn't find a value. So it's now fixed in CVS, and should hopefully get things working for you. Just do an update, and it should come in.
thanks,
Chris
