[Geoserver-devel] Reverting a change making our user life difficult with GDAL
Well, I think that most of us know Geoerver does work with GDAL 2.x, at least some of the formats do.
Maybe add the bindings back so people don’t get hard errors, and then add a note saying Geoserver should work with GDAL 2.x however once you build GDAL you should replace the bindings manually?
That note will be intended for more advanced users, so instructions on how to do so shouldn’t be included.
I mean, technically. if you built the latest gdal against the same swig version the 1.9.2 bindings were built against, the bindings will still “work” without having to replace the jar.
Just my my 2¢.
On Thu, Sep 7, 2017 at 10:29 AM, <geoserver-devel-request@lists.sourceforge.net> wrote:
Send Geoserver-devel mailing list submissions to
geoserver-devel@anonymised.comsourceforge.net
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
geoserver-devel-request@anonymised.comsourceforge.net
You can reach the person managing the list at
geoserver-devel-owner@anonymised.comsourceforge.net
When replying, please edit your Subject line so it is more specific
than “Re: Contents of Geoserver-devel digest…”
Today’s Topics:
  1. Re: Reverting a change making our user life difficult with
    GDAL (Rahkonen Jukka (MML))
Message: 1
Date: Thu, 7 Sep 2017 14:29:32 +0000
From: “Rahkonen Jukka (MML)” <jukka.rahkonen@maanmittauslaitos.fi>
To: Andrea Aime <andrea.aime@anonymised.com…1268…>, Torben Barsballe
<tbarsballe@anonymised.com>
Cc: Geoserver-devel <geoserver-devel@anonymised.comsourceforge.net>
Subject: Re: [Geoserver-devel] Reverting a change making our user life
difficult with GDAL
Message-ID:
<3c8bcf4abb754905aeeca506ebbc7f1c@…4679…local>
Content-Type: text/plain; charset=“utf-8”
In addition it seems to be difficult to compile 1.9.2 and GDAL folks are kidding? https://lists.osgeo.org/pipermail/gdal-dev/2017-September/047095.html
-Jukka-
L?hett?j?: Andrea Aime [mailto:andrea.aime@anonymised.comsolutions.it]
L?hetetty: 7. syyskuuta 2017 12:15
Vastaanottaja: Torben Barsballe <tbarsballe@anonymised.com>
Kopio: Geoserver-devel <geoserver-devel@anonymised.comsourceforge.net>
Aihe: Re: [Geoserver-devel] Reverting a change making our user life difficult with GDAL
We just got a ticket opened about this:
https://osgeo-org.atlassian.net/browse/GEOS-8276
On Wed, Jun 28, 2017 at 9:58 PM, Torben Barsballe <tbarsballe@anonymised.commailto:[tbarsballe@boundlessgeo.com](mailto:tbarsballe@anonymised.com)> wrote:
On Wed, Jun 28, 2017 at 12:01 PM, Andrea Aime <andrea.aime@anonymised.commailto:[andrea.aime@anonymised.comsolutions.it](mailto:andrea.aime@anonymised.com)> wrote:
On Tue, Jun 27, 2017 at 7:20 PM, Torben Barsballe <tbarsballe@anonymised.commailto:[tbarsballe@boundlessgeo.com](mailto:tbarsballe@anonymised.com)> wrote:
In reference to point (a), I think we should consider it a separate task, since I’m not sure how long creating new binaries will take (we should also evaluate moving to a 2.x GDAL version).
I agree that we should consider moving to GDAL 2.x, since that seems to be what most people are actually using these days, and I think some people have already had success using it with the current GeoServer.
I believe a line must be drawn between aspiration and reality. The idea is certainly good, but what if a year passes before
we can dedicate resources to do this upgrade? Should the users be left in a limbo since then, unable to get a supported
module to favor one that is not even packaged?
To be clear: As long as you follow the current install instructions<http://docs.geoserver.org/latest/en/user/data/raster/gdal.html#installing-gdal-extension>, the current GDAL module works fine. The bindings are included in the gdal zip linked<http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.16/native/gdal> from that page, and the instructions explicitly tell you to copy the bindings into your WEB-INF/lib.
The main issue is that most users are missing this step in the instructions, so including the bindings jar with the gs-gdal plugin (as was done before) would make things a bit easier.
Changing the packaging to include this jar again is relatively trivial, and can be done independently of upgrading the binding jar.
That said, if someone is using a newer version of GDAL with newer bindings, including the binding jar by default could cause other conflicts (I would expect to see issues with GDAL 2.0 and higher).
Given that, if we start including the binding jar again, and don’t upgrade it, we should make this clear in the GDAL install instructions (although that didn’t seem to help much in this case).
Torben
Torben
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
phone: +39 0584 962313tel:+39%200584%20962313
fax: +39 0584 1660272tel:+39%200584%20166%200272
mob: +39 339 8844549tel:+39%20339%20884%204549
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo ? consentito esclusivamente al destinatario del messaggio, per le finalit? indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalit? diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
An HTML attachment was scrubbed…
Subject: Digest Footer
Geoserver-devel@anonymised.com.366…sourceforge.net
End of Geoserver-devel Digest, Vol 136, Issue 26
On Thu, Sep 7, 2017 at 5:00 PM, Amiram Rahav <arahav@anonymised.com>
I've just checked, GeoSolutions has exactly zero deploys on GDAL 2.x, so
no, we don't know if it works with some or any format, with light load or
high load, in any shape or form.
If we did, GeoServer would likely be using 2.x by now (after some load
testing, a single hiccup in GDAL will take down the entire GeoServer
process,
so upgrading is not a matter to be taken lightly).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
