[Geoserver-devel] RFC: Parametric SQL View Enhancement Proposal (and patch)
Hello GeoServer Developers,
We have been assessing the use of GeoServer for some projects and have found it to be very promising – so far it has addressed the majority of our functional requirements. Thank you for the great work that you have done.
Our system tracks a reasonably large number of layers which are stored in a database and serves a reasonably large number of real-time daily image rendering requests which are ad-hoc in nature. Individual layers are rendered many times and are joined to a wide range of non-spatial data that is determined at runtime. As such, we are very interested in the Parametric SQL View Feature of the GeoServer 2.1 release. For the sake of efficiency and scaling we are hoping to avoid the creation of many on-demand database tables, database views or GeoServer Feature Type and Layer Definitions. The one problem that we are encountering is that our image requests will often reference the same layer multiple times (but joined to different data sets). Because the current capabilities of the Parametric SQL View Feature of GeoServer scopes the incoming SQL parameters to the request instead of individual layers, we have not been able to emulate this behavior with GeoServer.
After some review of the GeoServer trunk code I was able to put together a proof-of-concept that would allow WMS requests using the Parametric SQL View Feature to take advantage of positionally-specified parameters (just as styles are positionally specified). For example, the layer gisws:filter_pg_layer_19 is defined using parameterized SQL (the parameters are rdid and sid). The changes that I describe allow WMS to render an image that includes two copies of the layer joined to different data sets through the specification of view parameters by layer. The syntax that I use is compatible with the current syntax – if there is only one layer in use, the syntax is unchanged. An example WMS request using this syntax is:
http://localhost:8080/geoserver/wms?
VERSION=1.1.0&
SERVICE=wms&
REQUEST=getmap&
WIDTH=600&
HEIGHT=400&
SRS=EPSG:4326&
BBOX=-24.542,51.297,-0.018,66.565&
FORMAT=image/png&
STYLES=red,blue&
LAYERS=gisws:filter_pg_layer_19,gisws:filter_pg_layer_19&
VIEWPARAMS=rdid:1;sid:2,rdid:1;sid:1
or via the reflector:
http://localhost:8080/geoserver/wms/reflect?
WIDTH=800&
FORMAT=image/png&
STYLES=red,blue&
The only scenarios that I can think of where these changes could cause behavioral incompatibilities with the current methodology are:
  1. Multiple layers are being used and the view parameters apply to several of them. In this case, the request form would need to replicate the parameters for each layer in the VIEWPARAMS (e.g. VIEWPARAMS=a:1;b:2 would need to be changed to VIEWPARAMS=a:1;b:2,a:1;b:2[, …]).
  2. Multiple layers are being used, one of which is a parameterized SQL view but is not listed first in the sequence (e.g. LAYERS=static,parameterized&VIEWPARAMS=a:1;b:2). In this case the VIEWPARAMS would need to be left-padded so that the parameters were in the same position as the parametrized layer (LAYERS=static,parameterized&VIEWPARAMS=,a:1;b:2) or, if viable, the layer sequence could instead be changed (LAYERS=parameterized,static&VIEWPARAMS=a:1;b:2).
I have assessed support for other WMS request types given these changes. Everything works as expected for GetFeatureInfo:
VERSION=1.1.0&
REQUEST=GetFeatureInfo&
SERVICE=wms&
WIDTH=600&
HEIGHT=400&
SRS=EPSG:4326&
VIEWPARAMS=rdid:1;sid:2,rdid:1;sid:1&
QUERY_LAYERS=gisws:filter_pg_layer_19,gisws:filter_pg_layer_19&
X=100&
Y=50&
INFO_FORMAT=application/vnd.ogc.gml
As best I can tell these changes do not seem to be relevant to the DescribeLayer or GetLegendGraphic request types.
The proof-of-concept changes that I made were limited to OWS and WMS and include the following:
  1. The view params object was switched from Map to List.
  2. A new WMS ViewParamsKvpParser was created (which delegates its tokens to the FormatOptionsKvpParser).
  3. References to view params now index into the list based on layer sequencing.
  4. The GetMapKvpRequestReaderTest was expanded to include appropriate new tests.
I specifically avoided making any changes in WFS, as it seems like the approach is not as well defined but I would be happy to work on integrating these changes into WFS if anyone thinks it would be worthwhile and they would be willing to provide some guidance. On first glance it seems like positional referencing may not be the best approach for WFS.
While testing things I noticed a couple of issues that I’d be happy to elaborate on via JIRA if appropriate:
  1. The FormatOptionsKvpParser does not provide any escaping mechanism (I’m thinking along the lines of the comment in WFS 1.1.0 14.2.2). I don’t know that this section of the specification is directly relevant but it does seem like VIEWPARAMS should allow any values to be specified (particularly if character-based SQL parameters are being used). I have included an alternate implementation of FormatOptionsKvpParser that allows for values from KVPs to support backslash as an escape character and added supporting test cases.
14.2.2 Parameter lists
Parameters consisting of lists shall use the comma (“,”) as the delimiter between items in
the list. In addition, multiple lists can be specified as the value of a parameter by
enclosing each list in parentheses; “(”, “)”. The characters “,”, “(“ and “)” may be
escaped using the “\” character.
  1. The output for GetFeatureInfo is incomplete if INFO_FORMAT is not specified (only the first feature is output).
  2. GetLegendGraphic is not properly handling the FORMAT parameter – it seems to require specification of both OUTPUTFORMAT and FORMAT (and it uses OUTPUTFORMAT to determine the Response instance(s) to use). I assume that this is a regression or is due to work-in-progress.
I hope that there is interest in these enhancements (and it would be great if there was a chance of them getting into the 2.1 release). I would be happy to assist with this in any manner that I can.
Best regards,
Eli Miller
The information contained in this e-mail message
is intended only for the use of the recipient(s)
named above and may contain information that is
privileged, confidential, and/or proprietary.
If you are not the intended recipient, you may not
review, copy or distribute this message. If you have
received this communication in error, please notify
the sender immediately by e-mail, and delete the original message.
(attachments)
geoserver.patch (19 KB)
Hi Eli,
this is great work, nicely described. Please attach the patch to a
JIRA task, and create those other JIRA tasks.
Previously I've done the same sort of thing using SLDs - each SLD can
have a filter and I stored a parameterised SLD - and parameterised WFS
templates for the same purpose, instead of semantically
non-descriptive service endpoints in a service catalog.
The other option is dimensions - often parameters are really
dimensions of a phenomena - can you comment on whether these standard
mechanisms would work and if not, why not?
Rob
it to be very promising -- so far it has addressed the majority of our
GeoServer.
compatible with the current syntax -- if there is only one layer in use, the
VERSION=1\.1\.0&amp;
SERVICE=wms&amp;
REQUEST=getmap&amp;
WIDTH=600&amp;
HEIGHT=400&amp;
SRS=EPSG:4326&amp;
BBOX=\-24\.542,51\.297,\-0\.018,66\.565&amp;
FORMAT=image/png&amp;
STYLES=red,blue&amp;
LAYERS=gisws:filter\_pg\_layer\_19,gisws:filter\_pg\_layer\_19&amp;
WIDTH=800&amp;
1\. Multiple layers are being used and the view parameters apply to
need to be changed to VIEWPARAMS=a:1;b:2,a:1;b:2[, ...]).
REQUEST=GetFeatureInfo&amp;
SERVICE=wms&amp;
WIDTH=600&amp;
HEIGHT=400&amp;
SRS=EPSG:4326&amp;
VIEWPARAMS=rdid:1;sid:2,rdid:1;sid:1&amp;
QUERY\_LAYERS=gisws:filter\_pg\_layer\_19,gisws:filter\_pg\_layer\_19&amp;
X=100&amp;
Y=50&amp;
INFO\_FORMAT=application/vnd\.ogc\.gml
1\. The view params object was switched from Map to List&lt;Map&gt;\.
2\. A new WMS ViewParamsKvpParser was created \(which delegates its tokens
sequencing.
new tests.
While testing things I noticed a couple of issues that I'd be happy to
1\. The FormatOptionsKvpParser does not provide any escaping mechanism
(I'm thinking along the lines of the comment in WFS 1.1.0 14.2.2). I don't
test cases.
    14\.2\.2   Parameter lists
    Parameters consisting of lists shall use the comma \(&quot;,&quot;\) as the
of a parameter by
enclosing each list in parentheses; "(", ")". The characters “,”,
“(“ and “)” may be
2\. The output for GetFeatureInfo is incomplete if INFO\_FORMAT is not
3. GetLegendGraphic is not properly handling the FORMAT parameter -- it
Best regards,
Eli Miller
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today.
http://p.sf.net/sfu/beautyoftheweb
Geoserver-devel mailing list
Sounds really interesting. I’m curious to hear Andrea’s feedback, as he authored the parametric SQL view stuff. The one thing we really need for that feature is documentation - I just looked and couldn’t find any outside the GSIP. Mike, cced, is tasked with doing some documentation of it. It’d be great to get feedback on real world examples for him, and to also help him document this stuff if it passes review. But it looks like it’s driven by a real requirement, so should have a good chance if the code is clean.
VERSION=1.1.0&
SERVICE=wms&
REQUEST=getmap&
WIDTH=600&
HEIGHT=400&
SRS=EPSG:4326&
FORMAT=image/png&
STYLES=red,blue&
WIDTH=800&
FORMAT=image/png&
STYLES=red,blue&
VERSION=1.1.0&
SERVICE=wms&
WIDTH=600&
HEIGHT=400&
SRS=EPSG:4326&
X=100&
Y=50&
Best regards,
Eli Miller
Thanks :slight_smile:
GeoServer.
Same layer, but joined with different data sets. Oh, you actually want it
to perform SQL injection so that the different joins are part of the request?
If so, beware of malicious use of the same.
SERVICE=wms&amp;
REQUEST=getmap&amp;
WIDTH=600&amp;
HEIGHT=400&amp;
SRS=EPSG:4326&amp;
WIDTH=800&amp;
So basically, if there is a single set of params they are applied to all layers,
but if there is more, then you apply each of them to a different layer?
This is compatible with how we treat filters (another GeoServer
specific extension to WMS),
if there is just one it is replicated to all layers, if there are
multiple the user is supposed
to provide as many as the layers that are around, otherwise an
exception will be thrown.
Cool
2\. Multiple layers are being used, one of which is a parameterized SQL
If we want consistent behavior with the other replicated layers the syntax would
have to be:
LAYERS=parameterized,static&VIEWPARAMS=a:1;b:2,
I mean, what you proposed would work as well but it would have a
different meaning,
it would result in passing the params to the second layer as well
(which is not parametrized
so it would not take them, but here I want to make sure we agree on
the meaning of
the syntax).
In general it would be good to have everything consistent, so have
this extension
behave exactly like filters do (replicate if just one, apply one by
one if the number
of param groups match the number of layers, bomb out with an exception in case
they don't match).
SERVICE=wms&amp;
WIDTH=600&amp;
HEIGHT=400&amp;
SRS=EPSG:4326&amp;
X=100&amp;
Y=50&amp;
sequencing.
new tests.
Humm.... in WFS you can also make a request that will return multiple
layers, something
like:
http://demo.opengeo.org/geoserver/ows?request=getfeature&version=1.0.0&service=wfs&typename=og:archsites,og:streams
As you can see the relationship is positional as well
test cases.
of a parameter by
“(“ and “)” may be
Sounds good
I did not get this one. The default behavior is to return just one
feature unless
you manually specify a different number (by spec).
If there is any interaction with INFO_FORMAT that is a bug indeed.
3\. GetLegendGraphic is not properly handling the FORMAT parameter \-\- it
May be, we recently had a large refactor in WMS,
I did not have time to look into your patch so far, but you mention separate
things above: the changes related to the extensions you're proposing, and
a couple of bug fixes. It would help to have each bug fis sit in their own patch
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Hi Rob,
Thanks for the quick response and suggestion regarding parametrized SLDs. Our current GIS platform is not OGC compliant so I am familiarizing myself with all the concepts and had overlooked the SLD-based filtering technique that you describe. On first review, it seems like this approach could meet our needs. With some experimentation I was able to achieve comparable results by posting an SLD to WMS using NamedLayers with UserStyle Rules (I didn’t have as much luck with LayerFeatureConstraints but I am continuing to research that). From a system resource efficiency perspective should it be better to use LayerFeatureConstraints instead of excluding features from rendering via Rules?
I agree with you that the Parametrized SQL View approach encourages use of a non-descriptive endpoint which has implications. It also seems like GeoServer might have less of an opportunity for caching (or cache re-use) when SQL View parameters are in use. Nonetheless I would be curious if anyone has tested or can vouch for the possible performance differences between filtering data in a spatial database before it gets to GeoServer versus filtering in GeoServer (which I assume is what happens when the filter criteria are posted in a request-scoped SLD). Performance seemed reasonable during my cursory testing but I do need to better assess this from an overall resource consumption perspective – I will be sure to share any results.
Although the data we are presenting is dimensional in nature it is related to many different, and frequently updated, data sets which makes it impractical to incorporate as layer attributes.
I will add the issues and patches to JIRA.
Best regards,
Eli
On Wed, Oct 13, 2010 at 7:49 PM, Rob Atkinson <robatkinson101@anonymised.com> wrote:
Hi Eli,
Previously I’ve done the same sort of thing using SLDs - each SLD can
Rob
GeoServer.
VERSION=1.1.0&
SERVICE=wms&
REQUEST=getmap&
WIDTH=600&
HEIGHT=400&
SRS=EPSG:4326&
FORMAT=image/png&
STYLES=red,blue&
WIDTH=800&
FORMAT=image/png&
STYLES=red,blue&
VERSION=1.1.0&
SERVICE=wms&
WIDTH=600&
HEIGHT=400&
SRS=EPSG:4326&
X=100&
Y=50&
    sequencing.
    new tests.
    test cases.
of a parameter by
“(“ and “)” may be
Best regards,
Eli Miller
On Fri, Oct 15, 2010 at 4:45 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
GeoServer.
Agreed, but it doesn’t seem like it creates too much more exposure than the current Parametric SQL Views (except that it exposes multiple layers with independent parameters).
VERSION=1.1.0&
SERVICE=wms&
REQUEST=getmap&
WIDTH=600&
HEIGHT=400&
SRS=EPSG:4326&
FORMAT=image/png&
STYLES=red,blue&
WIDTH=800&
FORMAT=image/png&
STYLES=red,blue&
Actually, the logic that I implemented applies the parameters to a layer if and only if the parameters were specified in the same position as that of the layer – if there is only a single set of parameters it is not applying it to all layers. This would be easy to change and seems to make sense in terms of consistency with other features.
Cool
If we changed the handling when a single set of parameters was specified as noted above, this would no longer be an issue.
  1. Multiple layers are being used, one of which is a parameterized SQL
have to be:
different meaning,
the meaning of
the syntax).
this extension
one if the number
they don’t match).
Good point, the implementation that I included is lenient in that it allows for any number of sets of parameters to be specified but should enforce 0,1 or N where N is the number of layers.
VERSION=1.1.0&
SERVICE=wms&
WIDTH=600&
HEIGHT=400&
SRS=EPSG:4326&
X=100&
Y=50&
    sequencing.
    new tests.
Humm… in WFS you can also make a request that will return multiple
layers, something
like:
I will take a closer look at this.
    test cases.
of a parameter by
“(“ and “)” may be
Sounds good
feature unless
This may just be my misunderstanding. I was surprised that I got one feature back when INFO_FORMAT was not specified, and multiple features when it was specified.
  1. GetLegendGraphic is not properly handling the FORMAT parameter – it
things above: the changes related to the extensions you’re proposing, and
I will separate out the matters that I discussed as best as I can and enter them in JIRA.
Ing. Andrea Aime
fax: +39 0584962313
request?
Agreed, but it doesn't seem like it creates too much more exposure than the
Exposure is a matter of how you configure the regular expressions that do
the validation. If you know the parameter is a number or a plain string you
can make a strong regular expression that should prevent all attempts to
inject sql.
If you actually need to inject sql of your own it might be quite hard to avoid
the malicious ones.
this extension
one if the number
case
they don't match).
Yeah, at least we have to explain this behaviour only once in the guide.
Consistency helps making the software easier to use.
feature unless
it was specified.
If this is what you see then there is a bug at work indeed. The
parameter that controls
how many features are returned from the GetFeatureInfo is called
FEATURE_COUNT
them in JIRA.
Cool, thanks!
Ing. Andrea Aime
fax: +39 0584962313
