Justin Deoliveira ha scritto:
Ok, this list as is represents quite a bit of work so it would mean pushing back the release substantially.
Not necessarily. I'm finding out that working on benchmarking alone
is not a very productive use of my time, I usually need to mull
over perf issues a bit before getting a solution. In the meantime
I can squash some jira
I more meant the stuff that are not bug fixes. Like:
http://jira.codehaus.org/browse/GEOS-3294
Is not trivial. So my point was more to try to limit to bugs and regressions as much as possible or else the road to 2.0 will get drawn out and delayed imo.
Got it. So that will be fixed by 2.0.1? 2.1? I ask because it's not a trivial change, once we enter RC stage it will be more risky to fix.
And no offense but I don't think we should hinge release dates on a single developers time available to churn through a bunch of tasks.
Don't get me wrong, it is great that you have time to put toward these issues but I feel like the point of this process is to gather consensus for release dates that work for everybody. And to try and do so somewhat in advance.
Duh, I did not mean I would fix all of them, sorry, put down
the sentence in the wrong way. I was thinking about these only:
http://jira.codehaus.org/browse/GEOS-3302 (regression)
http://jira.codehaus.org/browse/GEOS-3295 (regression)
http://jira.codehaus.org/browse/GEOS-3259 (in progress)
The others are assigned to someone else.
RC should also mean "feature complete" so I'm not sure we can go there
without fixing the status of the home page (the "white hole" issue).
Another thing is that if everyone agrees we should try to file all regressions as high priority or blocker, as issues coming up shortly before the release that are blockers but not filed as so keep coming up. And it turns out to be a surprise for those who did not file or were not assigned the issue.
Yup, sorry about that, I upgraded the priority of each regression to
critical status.
At this point I would prefer we keep things to regressions only (and maybe low hanging fruit) or I fear we will go down a feature creep path of improvements that might not end.
I guess I can fix most of those by mid of next week, maybe earlier.
Is that going to be ok?
Sure, I would be fine with pushing back by a week. How do others feel?
I will also point out there are other developers available to take on some of the issues as well (such as myself), so unless you really want to take them all on we can split up the work.
No no, as I said above I did not express myself properly, I wanted
to take only on the ones assigned to me.
And then there is the issue of the home page, which is expressed
in two differen jiras and should require a bit of work for sure...
Andrea Aime
OpenGeo - http://opengeo.org
