I add you, boundless runs that wordpress site.
On 31 August 2015 at 09:45, Stefano Costa <stefano.costa@anonymised.com> wrote:
Looks like I don’t… ERROR: There is no user registered with that email address
How do I get credentials?
Jody Garnett
On Mon, Aug 31, 2015 at 6:13 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Certainly, do you have the ability to edit blog posts Stefano?
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Jody Garnett
On 31 August 2015 at 09:11, Stefano Costa <stefano.costa@anonymised.com> wrote:
Hi Jody,
perhaps you should also mention the possibility to upload app-schema mapping configurations via the REST API?
https://osgeo-org.atlassian.net/browse/GEOS-7087
There are also docs for it:
https://osgeo-org.atlassian.net/browse/GEOS-7132
It is marked as an improvement in JIRA.
Thanks!
On Mon, Aug 31, 2015 at 5:04 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Much appreciated Andrea - thanks for rounding up the features I missed.
Blog post is now published: http://blog.geoserver.org/2015/08/31/geoserver-2-8-beta-release/
I will write up the geotools blog and publish tomorrow,
Geoserver-devel mailing list
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Jody Garnett
On 31 August 2015 at 00:28, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Aug 31, 2015 at 7:37 AM, Jody Garnett <jody.garnett@…403…> wrote:
Having a bit of fun finding good documentation links for features announced in beta:
- GEOS-3922 Expose feature type filtering option (this sounds good are there docs? how to do it …)
http://docs.geoserver.org/latest/en/user/webadmin/data/layers.html#restricting-features-showing-up-in-the-layer
- Does for shape symbols not cover recent addition of extshape://arrow
Nope, it was documented in GeoTools:
http://docs.geotools.org/latest/userguide/library/render/wkt.html#weather-symbols
We need to find a better way to document stuff only once, having to keep two sets of
doc in synch with the same contents is madness
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
