[Geoserver-devel] Rows below the legend
I’m using GeoServer 2.0.2 and I need to delete the three rows below the legend?
The rows are:
Band selection is 1
ColorMap type is RAMP
ColorMap is not extended
To show the legend I use this call:
http://localhost:8082/geoserver/wms?REQUEST=GetLegendGraphic&VERSION=1.0.0&LAYER=layer_name&FORMAT=image/png&WIDTH=30&LEGEND_OPTIONS=fontSize:22;bandInfo:false
Thanks
Simone
Simone Lella
Istituto per il Rilevamento Elettromagnetico dell'Ambiente
IREA - CNR ([http://www.irea.cnr.it](http://www.irea.cnr.it))
Via Bassini, 15
Tel. +39 02-23699299
Milano
Ciao Simone,
can you try to use a 2.0.x nightly?
http://gridlock.opengeo.org/geoserver/2.0.x/
This problem should have been fixed already on the stable branch. Btw,
you should not need to
specify bandInfo to false, since that should be the default.
Ciao,
Simone.
Ing. Simone Giannecchini
Founder
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
On Fri, Dec 10, 2010 at 3:38 PM, Simone Lella <lella.s@anonymised.com> wrote:
