Hi Ben,
I don’t have much guidance there, I guess Justin removed his fork of teamengine from github?
I’ve been trying to get an update of the CITE tests for a long while now (months) but unfortunately
everything is stuck on Ares not having the new stuff working (and waiting for the new box apparently).
Unfortunatley I no longer have a working checkout of the old cite tools, but I still have a tomcat
with the teamengine deployed, that hopefully will get you going (it’s late, I haven’t tried it out).
I’m going to send it over via private mail
On Mon, Nov 16, 2015 at 9:40 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Andrea,
I am trying to run CITE tests from the command line (not via Jenkins). The documented procedure references jdeolive/geoserver-cite-tools but there is a fork geoserver/geoserver-cite-tools. Both have a broken git submodule for “engine” (jdeolive/teamengine moved to jdeolive/teamengine-old). I started with geoserver/geoserver-cite-tools and removed the broken “engine” submodule and replaced it with a new submodule geoserver/teamengine, but build failed during “mvn install”:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (compile) on project cite: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] java.io.FileNotFoundException: /home/ben/geoserver/cite/geoserver-cite-tools/engine/build.xml (No such file or directory)
[ERROR] around Ant part …… @ 4:68 in /home/ben/geoserver/cite/geoserver-cite-tools/target/antrun/build-main.xml
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
