Hy guys,
I tried to follow the the Running Geoserver with IntelliJ IDEA tutorial in Geoserver Developer docs http://docs.geoserver.org/stable/en/developer/quickstart/intellij.html
Running the Project fails with the following logs;
---------------------------BEGIN LOgs-----------------
9:33 AM Compilation completed with 7 errors and 498 warnings in 3m 12s 873ms
C:.…\Projects\Geoserver\geoserver\src\wcs2_0\src\test\java\org\geoserver\wcs2_0\kvp\WCSKVPTestSupport.java
Error:(29, 29) java: package org.geoserver.wcs.kvp does not exist
Error:(44, 5) java: cannot find symbol
symbol: class GetCoverageRequestReader
location: class org.geoserver.wcs2_0.kvp.WCSKVPTestSupport
Error:(95, 22) java: cannot find symbol
C:.…\Projects\Geoserver\geoserver\src\wcs2_0\src\test\java\org\geoserver\wcs2_0\xml\GetCoverageTest.java
Error:(28, 28) java: cannot find symbol
symbol: class DefaultWebCoverageService20
Error:(871, 9) java: cannot find symbol
location: class org.geoserver.wcs2_0.xml.GetCoverageTest
Error:(871, 68) java: cannot find symbol
C:.…\Projects\Geoserver\geoserver\src\wcs2_0\src\test\java\org\geoserver\wcs2_0\kvp\GetCapabilitiesTest.java
Warning:(3, 30) java: junit.framework.Assert in junit.framework has been deprecated
Error:(8, 28) java: cannot find symbol
symbol: class GetCapabilities
---------------------End Logs------------------------------
Plus there are several Warning of deprecated frameworks and libraries.
As far as I can tell, IntelliJ makes noise in this class
This import
import org.geoserver.wcs.kvp.GetCoverageRequestReader;
Here
Kind regards,
Steve Omondi
