as some of you may know, one of the major annoyances I have with the struts
UI is having to copy by hand the file system paths pointing to file based
data... I always wanted a browser that could behave sort of like the
file/open dialog.
Well, I made a simple one, which I've attached to this mail
http://www.nabble.com/file/p18797184/fsbrowser.zip fsbrowser.zip
It's full blown sample application, use the Start class in the
src/test/jav/org/geoserver folder.
Still have some rough edges, but better than nothing.
I'm eager to get some feedback.
Ideally I would like to integrate it into the new UI, and have a sort of a
dialog allowing one to browse the data dir contents, as well as the whole
file system, and pick up a file or their choice.
View this message in context: http://www.nabble.com/Sample-server-file-system-browser-compontent-tp18797184p18797184.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
