Currently the default is AbstractFeatureType, I am not sure if this is correct?
I am starting to suspect that NullType will be a more suitable base as a default, and for generated describe feature type information.
DataTransferObjectFactory defines:
public static Map schemaBaseMap = new HashMap();
static {
schemaBaseMap.put("AbstractFeatureType",
new String {"description","name","boundedBy"} );
schemaBaseMap.put("AbstractFeatureCollectionBaseType",
schemaBaseMap.put("GeometryPropertyType",
new String {"geometry"} );
schemaBaseMap.put("FeatureAssociationType",
new String {"feature"} );
schemaBaseMap.put("BoundingShapeType",
new String {"box"} );
schemaBaseMap.put("PointPropertyType",
new String {"point"} );
schemaBaseMap.put("PolygonPropertyType",
new String {"polygon"} );
schemaBaseMap.put("LineStringPropertyType",
new String {"lineString"} );
schemaBaseMap.put("MultiPointPropertyType",
new String {"multiPoint"} );
schemaBaseMap.put("MultiLineStringPropertyType",
new String {"multiLineString"} );
schemaBaseMap.put("MultiPolygonPropertyType",
new String {"multiPolygonString"} );
schemaBaseMap.put("MultiGeometryPropertyType",
new String {"multiGeometry"} );
schemaBaseMap.put("NullType", new String {} );
