[Geoserver-devel] Save private... Jenkins! (and the release)
Jenkins seems to be in real trouble, takes a lot of time to respond, and the first build node
has gone down repeatedly and/or the tasks on it are taking a lot of time (well, the builds take a lot more than normal
and then the node goes down).
This is preventing progress with the release… can anyone have a look?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Sorry that I didn’t get a chance to look at this yesterday. I’ve taken a look at the instance today, and it looks like there may have somehow been two jenkins agents running on the first node. I’ve restarted jenkins on that node, and things appear to be running more smoothly.
Also, the issue with the cite wcs-1.0 job running for a ~11 hours still hasn’t been resolved, so that is likely causing jobs to back up, which in turn is likely causing jenkins to be a little overloaded. I’ve temporarily disabled 2.15-cite-wcs-1.0 and cite-wcs-1.0, so that should at least stop large backlogs from forming.
If the problem comes up again, please let me know.
Torben
On Mon, Mar 18, 2019 at 8:23 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
