[Geoserver-devel] scala version dependency management
We have a number of extensions/community modules using different versions of scala.
In reviewing https://github.com/geoserver/geoserver/pull/973 I would like to ask if we need a root pom.xml entry for this under dependency management?
community/geomesa uses version 2.10.4
extension/css 2.7.7
community/script … transitive dependency?
Jody Garnett
The css module does not depend on scala anymore… outdated checkout maybe?
Here is the full set of dependencies:
[INFO] Scanning for projects…
[INFO]
[INFO] Building GeoServer CSS Styling 2.8-SNAPSHOT
[INFO]
[INFO] — maven-dependency-plugin:2.8:tree (default-cli) @ gs-css —
[INFO] org.geoserver.extension:gs-css:jar:2.8-SNAPSHOT
[INFO] ± org.geoserver.web:gs-web-core:jar:2.8-SNAPSHOT:compile
[INFO] | ± org.apache.wicket:wicket:jar:1.4.12:compile
[INFO] | ± org.apache.wicket:wicket-spring:jar:1.4.12:compile
[INFO] | | - org.apache.wicket:wicket-ioc:jar:1.4.12:compile
[INFO] | | - cglib:cglib-nodep:jar:2.2:compile
[INFO] | ± org.wicketstuff:htmlvalidator:jar:1.2:compile
[INFO] | ± org.slf4j:slf4j-log4j12:jar:1.4.2:compile
[INFO] | ± log4j:log4j:jar:1.2.14:compile
[INFO] | ± org.geoserver:gs-main:jar:2.8-SNAPSHOT:compile
[INFO] | ± org.geotools:gt-coverage:jar:14-SNAPSHOT:compile
[INFO] | | ± it.geosolutions.imageio-ext:imageio-ext-tiff:jar:1.1.10:compile
[INFO] | | | - it.geosolutions.imageio-ext:imageio-ext-utilities:jar:1.1.10:compile
[INFO] | | ± org.jaitools:jt-zonalstats:jar:1.3.1:compile
[INFO] | | - org.jaitools:jt-utils:jar:1.3.1:compile
[INFO] | ± org.geotools:gt-data:jar:14-SNAPSHOT:compile
[INFO] | ± org.geotools:gt-shapefile:jar:14-SNAPSHOT:compile
[INFO] | ± org.geotools.jdbc:gt-jdbc-postgis:jar:14-SNAPSHOT:compile
[INFO] | | - postgresql:postgresql:jar:8.4-701.jdbc3:compile
[INFO] | ± org.geotools:gt-wfs-ng:jar:14-SNAPSHOT:compile
[INFO] | | ± org.geotools:gt-xml:jar:14-SNAPSHOT:compile
[INFO] | | | - org.apache.xml:xml-commons-resolver:jar:1.2:compile
[INFO] | | ± org.geotools.xsd:gt-xsd-wfs:jar:14-SNAPSHOT:compile
[INFO] | | | - org.geotools.xsd:gt-xsd-fes:jar:14-SNAPSHOT:compile
[INFO] | | ± org.geotools.ogc:net.opengis.wfs:jar:14-SNAPSHOT:compile
[INFO] | | | ± org.geotools.ogc:org.w3.xlink:jar:14-SNAPSHOT:compile
[INFO] | | | ± org.geotools.ogc:net.opengis.fes:jar:14-SNAPSHOT:compile
[INFO] | | | ± org.eclipse.emf:common:jar:2.6.0:compile
[INFO] | | | - org.eclipse.emf:ecore:jar:2.6.1:compile
[INFO] | | - xpp3:xpp3:jar:1.1.3.4.O:compile
[INFO] | ± org.geotools:gt-jdbc:jar:14-SNAPSHOT:compile
[INFO] | | ± commons-dbcp:commons-dbcp:jar:1.4:compile
[INFO] | | - commons-collections:commons-collections:jar:3.1:compile
[INFO] | ± org.geotools:gt-metadata:jar:14-SNAPSHOT:compile
[INFO] | | - org.geotools:gt-opengis:jar:14-SNAPSHOT:compile
[INFO] | ± org.geotools:gt-arcgrid:jar:14-SNAPSHOT:compile
[INFO] | | - it.geosolutions.imageio-ext:imageio-ext-arcgrid:jar:1.1.10:compile
[INFO] | ± org.geotools:gt-geotiff:jar:14-SNAPSHOT:compile
[INFO] | ± org.geotools:gt-gtopo30:jar:14-SNAPSHOT:compile
[INFO] | ± org.geotools:gt-image:jar:14-SNAPSHOT:compile
[INFO] | ± org.springframework.security:spring-security-web:jar:3.1.0.RELEASE:compile
[INFO] | | ± org.springframework:spring-tx:jar:3.1.4.RELEASE:compile
[INFO] | | - aopalliance:aopalliance:jar:1.0:compile
[INFO] | - org.bouncycastle:bcprov-jdk14:jar:1.46:compile
[INFO] ± org.apache.wicket:wicket-extensions:jar:1.4.12:compile
[INFO] | - org.slf4j:slf4j-api:jar:1.5.8:compile
[INFO] ± org.geotools:gt-css:jar:14-SNAPSHOT:compile
[INFO] | ± org.geotools:gt-cql:jar:14-SNAPSHOT:compile
[INFO] | ± commons-io:commons-io:jar:2.1:compile
[INFO] | ± org.geotools:gt-brewer:jar:14-SNAPSHOT:compile
[INFO] | ± org.parboiled:parboiled-java:jar:1.1.6:compile
[INFO] | | ± org.parboiled:parboiled-core:jar:1.1.6:compile
[INFO] | | ± org.ow2.asm:asm:jar:4.1:compile
[INFO] | | ± org.ow2.asm:asm-tree:jar:4.1:compile
[INFO] | | ± org.ow2.asm:asm-analysis:jar:4.1:compile
[INFO] | | - org.ow2.asm:asm-util:jar:4.1:compile
[INFO] | ± org.geotools.xsd:gt-xsd-sld:jar:14-SNAPSHOT:compile
[INFO] | | ± org.geotools.xsd:gt-xsd-core:jar:14-SNAPSHOT:compile
[INFO] | | | ± org.geotools:gt-graph:jar:14-SNAPSHOT:compile
[INFO] | | | ± picocontainer:picocontainer:jar:1.2:compile
[INFO] | | | | - xml-apis:xml-apis:jar:1.0.b2:compile
[INFO] | | | ± commons-jxpath:commons-jxpath:jar:1.3:compile
[INFO] | | | - org.eclipse.xsd:xsd:jar:2.6.0:compile
[INFO] | | - org.geotools.xsd:gt-xsd-filter:jar:14-SNAPSHOT:compile
[INFO] | | ± org.geotools.xsd:gt-xsd-gml2:jar:14-SNAPSHOT:compile
[INFO] | | - org.geotools.xsd:gt-xsd-gml3:jar:14-SNAPSHOT:compile
[INFO] | - javax.media:jai_core:jar:1.1.3:compile
[INFO] ± org.geoserver:gs-main:jar:tests:2.8-SNAPSHOT:test
[INFO] | ± org.geoserver:gs-ows:jar:2.8-SNAPSHOT:compile
[INFO] | | ± org.geotools.ogc:net.opengis.ows:jar:14-SNAPSHOT:compile
[INFO] | | - org.geotools.xsd:gt-xsd-ows:jar:14-SNAPSHOT:compile
[INFO] | ± javax.servlet:servlet-api:jar:2.5:compile
[INFO] | ± net.sf.json-lib:json-lib:jar:jdk15:2.2.3:compile
[INFO] | | - net.sf.ezmorph:ezmorph:jar:1.0.6:compile
[INFO] | ± commons-beanutils:commons-beanutils:jar:1.7.0:compile
[INFO] | ± commons-fileupload:commons-fileupload:jar:1.2.1:compile
[INFO] | ± commons-httpclient:commons-httpclient:jar:3.1:compile
[INFO] | ± org.freemarker:freemarker:jar:2.3.18:compile
[INFO] | ± org.geotools:gt-property:jar:14-SNAPSHOT:compile
[INFO] | ± org.geotools:gt-epsg-hsql:jar:14-SNAPSHOT:compile
[INFO] | | - org.hsqldb:hsqldb:jar:2.2.8:compile
[INFO] | ± org.geotools:gt-wms:jar:14-SNAPSHOT:compile
[INFO] | | - org.geotools:gt-render:jar:14-SNAPSHOT:compile
[INFO] | ± org.springframework:spring-aop:jar:3.1.4.RELEASE:compile
[INFO] | ± org.springframework:spring-jdbc:jar:3.1.4.RELEASE:compile
[INFO] | ± com.thoughtworks.xstream:xstream:jar:1.4.7:compile
[INFO] | | ± xmlpull:xmlpull:jar:1.1.3.1:compile
[INFO] | | - xpp3:xpp3_min:jar:1.1.4c:compile
[INFO] | ± com.google.guava:guava:jar:17.0:compile
[INFO] | ± com.google.code.findbugs:jsr305:jar:2.0.3:compile
[INFO] | ± org.geotools:gt-imagemosaic:jar:14-SNAPSHOT:compile
[INFO] | | ± net.java.dev.jsr-275:jsr-275:jar:1.0-beta-2:compile
[INFO] | | ± java3d:vecmath:jar:1.3.2:compile
[INFO] | | ± org.geotools:gt-transform:jar:14-SNAPSHOT:compile
[INFO] | | ± it.geosolutions.imageio-ext:imageio-ext-streams:jar:1.1.10:compile
[INFO] | | ± it.geosolutions.imageio-ext:imageio-ext-geocore:jar:1.1.10:compile
[INFO] | | ± org.jaitools:jt-vectorbinarize:jar:1.3.1:compile
[INFO] | | - net.sf.ehcache:ehcache:jar:1.6.2:compile
[INFO] | ± org.springframework.security:spring-security-core:jar:3.1.0.RELEASE:compile
[INFO] | | - org.springframework.security:spring-security-crypto:jar:3.1.0.RELEASE:compile
[INFO] | ± org.springframework.security:spring-security-config:jar:3.1.0.RELEASE:compile
[INFO] | - org.jasypt:jasypt:jar:1.8:compile
[INFO] ± org.geoserver.web:gs-web-core:jar:tests:2.8-SNAPSHOT:test
[INFO] ± com.mockrunner:mockrunner:jar:0.3.6:test
[INFO] ± org.geoserver:gs-platform:jar:2.8-SNAPSHOT:compile
[INFO] | ± commons-lang:commons-lang:jar:2.6:compile
[INFO] | ± commons-codec:commons-codec:jar:1.9:compile
[INFO] | ± javax.media:jai_codec:jar:1.1.3:compile
[INFO] | - javax.media:jai_imageio:jar:1.1:compile
[INFO] ± org.springframework:spring-beans:jar:3.1.4.RELEASE:compile
[INFO] ± org.springframework:spring-core:jar:3.1.4.RELEASE:compile
[INFO] | ± org.springframework:spring-asm:jar:3.1.4.RELEASE:compile
[INFO] | - commons-logging:commons-logging:jar:1.1.1:compile
[INFO] ± org.springframework:spring-context:jar:3.1.4.RELEASE:compile
[INFO] | - org.springframework:spring-expression:jar:3.1.4.RELEASE:compile
[INFO] ± org.springframework:spring-webmvc:jar:3.1.4.RELEASE:compile
[INFO] | ± org.springframework:spring-context-support:jar:3.1.4.RELEASE:compile
[INFO] | - org.springframework:spring-web:jar:3.1.4.RELEASE:compile
[INFO] ± org.geotools:gt-api:jar:14-SNAPSHOT:compile
[INFO] | ± com.vividsolutions:jts:jar:1.13:compile
[INFO] | - org.geotools:gt-referencing:jar:14-SNAPSHOT:compile
[INFO] | ± commons-pool:commons-pool:jar:1.5.3:compile
[INFO] | - jgridshift:jgridshift:jar:1.0:compile
[INFO] ± org.geotools:gt-main:jar:14-SNAPSHOT:compile
[INFO] | - org.jdom:jdom:jar:1.1.3:compile
[INFO] - junit:junit:jar:4.11:test
[INFO] - org.hamcrest:hamcrest-core:jar:1.3:test
[INFO] BUILD SUCCESS
[INFO] Total time: 3.003 s
[INFO] Finished at: 2015-03-13T21:20:58+01:00
[INFO] Final Memory: 18M/224M
On Fri, Mar 13, 2015 at 9:07 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
extension/css 2.7.7
Jody Garnett
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea, Jody,
My mistake. I saw this file: https://github.com/geoserver/geoserver/blob/master/src/extension/css/project/build.properties
Is it still used? If not, the GeoMesa community module may be the only thing wanting Scala.
Jim
[INFO]
[INFO]
extension/css 2.7.7
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
conversation now. [http://goparallel.sourceforge.net/](http://goparallel.sourceforge.net/)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
On Fri, Mar 13, 2015 at 9:54 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Andrea, Jody,
Gone now, thanks for pointing it out
Ing. Andrea Aime
@geowolf
Technical Lead
