Downloaded javadoc package. Unzipped OK. Opened in Firefox, version number
correct. Poked around a bit, links appeared OK, no problems noted.
Downloaded html package. Unzipped OK. Opened in Firefox, version number
correct. Poked around a bit in user manual. Links appeared OK (including x-ref
to JIRA and github for edit). No problems noted.
Same for developer manual (although the release testing checklist was noted as
being a bit out-of-date, that isn't a new issue).
REST API is documented as Version 1.0.0, but no problems noted.
Top level README, license and version OK (although it would be nice if the
build date was more specific).
Downloaded the war package. Unzipped OK. Booted it on a Tomcat 9 install on
ubuntu (9.0.58-1ubuntu0.1) with openjdk (11.0.17) - distro packages.
Log in OK, poked around with layer preview. Checked a couple of capabilities.
No problems noted. The new data and styling is nice improvement.
a security vulnerability statement, including the CVE numbers etc…
filled in the jira placeholders with a title, and a description linking to the security vulnerabilities
the vulnerabilities remain in draft so the jira links are broken until they are published
If any additional releases are being made they can be added to the vulnerability statement above. I can see Andrea backporting the geotools fix to several branches here: https://osgeo-org.atlassian.net/browse/GEOT-7302
