[Geoserver-devel] Schema not created under Oracle
I am running Geoserver 1.1.0 with Oracle Spatial and no Schema.xml --
only info.xml . When running DescribeFeatureType I am getting errors on
every one of these layers (see below). I have tested bc_roads from the
shape file and it works fine. Thanks.
javax.xml.transform.TransformerException: Encoding Error at
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.jav
a:120) at
a:102) at
org.vfny.geoserver.responses.wfs.DescribeResponse.generateFromSchema(Des
cribeResponse.java:372) at
org.vfny.geoserver.responses.wfs.DescribeResponse.generateSpecifiedTypes
(DescribeResponse.java:329) at
org.vfny.geoserver.responses.wfs.DescribeResponse.generateTypes(Describe
Response.java:201) at
org.vfny.geoserver.responses.wfs.DescribeResponse.execute(DescribeRespon
se.java:110) at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.ja
va:295) at
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:2
02) at javax.servlet.http.HttpServlet.service(HttpServlet.java:740) at
javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at
org.vfny.geoserver.servlets.wfs.WfsDispatcher.doResponse(WfsDispatcher.j
ava:172) at
org.vfny.geoserver.servlets.wfs.WfsDispatcher.doGet(WfsDispatcher.java:1
23) at javax.servlet.http.HttpServlet.service(HttpServlet.java:740) at
jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91) at
jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42) at
jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:252
) at
jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527
) at jrun.servlet.http.WebService.invokeRunnable(WebService.java:168) at
jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java
:451) at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66) Caused
by: java.lang.RuntimeException: Unsupported type:
com.vividsolutions.jts.geom.Geometry at
org.geotools.gml.producer.FeatureTypeTransformer$FeatureTypeTranslator.e
ncodeGeometry(FeatureTypeTransformer.java:415) at
ncode(FeatureTypeTransformer.java:279) at
ncode(FeatureTypeTransformer.java:212) at
ncode(FeatureTypeTransformer.java:190) at
org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(Transf
ormerBase.java:469) at
org.apache.xalan.transformer.TransformerIdentityImpl.transform(Transform
erIdentityImpl.java:452) at
a:117) ... 20 more --------- java.lang.RuntimeException: Unsupported
type: com.vividsolutions.jts.geom.Geometry at
a:117) at
a:102) at
se.java:110) at
va:295) at
ava:172) at
) at
Hi
The problem seems to be that FeatureTypeTransformer does not recognize
your type of geometries (see inner RuntimeException). Can you tell me
the type of geometries you have?
Simon
Von: geoserver-devel-admin@lists.sourceforge.net
[mailto:geoserver-devel-
admin@lists.sourceforge.net] Im Auftrag von Kirk Mower
Gesendet: Freitag, 23. Januar 2004 02:57
An: geoserver-devel@lists.sourceforge.net
Betreff: [Geoserver-devel] Schema not created under Oracle
on
a:120) at
a:102) at
se.java:110) at
va:295) at
ava:172) at
) at
at
a:117) at
a:102) at
se.java:110) at
va:295) at
ava:172) at
) at
at
The SF.Net email is sponsored by EclipseCon 2004
Premiere Conference on Open Tools Development and Integration
See the breadth of Eclipse activity. February 3-5 in Anaheim, CA.
http://www.eclipsecon.org/osdn
Geoserver-devel mailing list
