[Geoserver-devel] Securing WPS processes
as part of our batch of WPS improvements we also are proposing a way to
secure WPS processes on a user by user basis.
Basically, we want and equivalent of the data security, but for processes.
We can see two ways of handling this:
  • extending service security
  • handling it more like data security
The current service security subsystem is arguably not well developed,
it does what it can at the OWS generic level, applying security checks
just checking service, request and output format, which are the bits
we can identify without having a knowledge of the protocol itself.
At the WPS level we don’t care about securing the requests themselves,
but to secure the processes themselves, which in WPS view, are
the contents of the service.
When a process is not available for a user, it should not show up in the
capabilites document, and should not be usable in the other WPS calls.
Also, while now we are just looking at making the process visible or not,
just like in data security we might want to have customizable per user
process limits, something like limiting the amount of GML/WKT a certain classes
of users can send to a certain process.
This is why I see the data security a better fit, concept wise, for the
WPS security, and I’m proposing an interface that mimicks the ResourceAccessManager
one:
public interface ProcessAccessManager {
  • Returns the access limits for a whole process namespace
ProcessAccessLimits getAccessLimits(Authentication user, String namespace);
  • Returns the access limits for a single process
ProcessAccessLimits getAccessLimits(Authentication user, Name process);
where ProcessAccessLimits would be, for the moment at least:
public class ProcessAccessLimits extents AccessLimits {
private boolean allowed;
public ProcessAccessLimits(CatalogMode mode, boolean allowed) {
super(mode);
this.allowed = allowed;
public boolean isAllowed() {
return allowed;
But in the future could be extended to add more limitations.
The default implementation of the ProcessAccessManager would be based on property files just like data access, using rules such as:
mode=CHALLENGE
geo.*=role1,role2
gs.import=ROLE_ADMINISTRATOR
The application of the rules would then use a new ProcessFilter implementation will be registered in the application context, that scans the application context for a ProcessAccessManager implementation, and if not found, builds a DefaultProcessAccessManager instance based on the property files described above.
In case the request is a GetCapabilities one, and a process/factory is in CHALLENGE mode, the code would list the processes anyways, but it would trigger a authentication request in case the current user is not authorized, and any other call is made to the WPS.
HIDE would simply hide the processes and pretend they are not there, MIXED will hide them from the capabilities, but would allow their usage in other calls if the caller has enough rights, triggering the authentication request otherwise.
The proposed approach keeps external security systems on a level playing field, allowing to build custom WPS security, and should give us space to grow in the future.
Now, this has some overlap with our current ability to turn on and off processes in WPS.
Here we have two possible approaches:
  • Keep both in line, as one is geared towards what you make available, and the other to whom
  • Migrate the old on/off approach to a security one, and when the old metadata is found, turn it into a security rule, by creating a file looking something ilke:
    geo.buffer=*
    geo.intersects=ROLE_UNAUTHORIZED
    And then change the current user interface to work against the property files, and allow the specification or role lists on a per process basis, instead of a simple on/off checkbox.
    I’m leaning towards the second, what do you think?
Also, WPS is a extension module, do you think this is worth a proposal?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Thu, Oct 23, 2014 at 11:08 AM, Andrea Aime <andrea.aime@anonymised.com>
I'm leaning towards the second, what do you think?
As a possible interesting alternative, we can forget about the property
file, and work off the existing on/off process configuration,
which is based on the following interface:
public interface ProcessGroupInfo extends Info, Cloneable {
     * The process factory class (only means to identify it)
    public Class<? extends ProcessFactory> getFactoryClass();
     * Sets the process factory class
     * @param factoryClass
    public void setFactoryClass(Class<? extends ProcessFactory>
factoryClass);
     * True if the factory is enabled, false otherwise
     * @return
    public boolean isEnabled();
     * Enables/disables the factory
     * @param enabled
    public void setEnabled(boolean enabled);
     * The list of processes generated by this factory that needs to be
filtered out (disabled)
     * @return
    public List<Name> getFilteredProcesses();
     * The metadata map, can contain any sort of information that non core
plugins might use to
     * handle information related to this factory
     * @return
    MetadataMap getMetadata();
     * Creares a copy of this class
     * @return
    ProcessGroupInfo clone();
In order to maintain backwards compatibility we could extend it so that: t
has a list of roles that can access it (when enabled).
And then the list of process names being filtered could be replaced by a
list of ProcessInfo beans (something that Justin
was pushing for when we discussed the ability to turn on and off processes)
that do contain, for the time being,
a on/off flag, and a list of roles that can access them, but could be
expanded later to also contain process limits.
It builds on what we have, and keeps this configuration integrated with the
main WPS config, making it
also readily available for REST usage.
Ing. Andrea Aime
@geowolf
Technical Lead
I do remember bringing up the idea of making processes a first class citizen in the catalog. Basically come up with a ProcessInfo and extends ResourceInfo and then be able to use data security to apply access rules to them. Is that what you’re talking about here? I am thinking maybe not?
On Thu, Oct 23, 2014 at 3:53 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
On Thu, Oct 23, 2014 at 11:08 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
As a possible interesting alternative, we can forget about the property file, and work off the existing on/off process configuration,
  • The process factory class (only means to identify it)
  • Sets the process factory class
  • @param factoryClass
    public void setFactoryClass(Class<? extends ProcessFactory> factoryClass);
  • True if the factory is enabled, false otherwise
  • @return
  • Enables/disables the factory
  • @param enabled
  • The list of processes generated by this factory that needs to be filtered out (disabled)
  • @return
    public List getFilteredProcesses();
  • The metadata map, can contain any sort of information that non core plugins might use to
  • handle information related to this factory
  • @return
  • Creares a copy of this class
  • @return
In order to maintain backwards compatibility we could extend it so that: t has a list of roles that can access it (when enabled).
And then the list of process names being filtered could be replaced by a list of ProcessInfo beans (something that Justin
was pushing for when we discussed the ability to turn on and off processes) that do contain, for the time being,
a on/off flag, and a list of roles that can access them, but could be expanded later to also contain process limits.
It builds on what we have, and keeps this configuration integrated with the main WPS config, making it
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Oct 24, 2014 at 3:47 PM, Justin Deoliveira <
them. Is that what you're talking about here? I am thinking maybe not?
Oh no, not going to those extent, that would require a major amount of
extra work.
Just want to store these ProcessInfo objects, that contain information
about how to limit access to the process and its inputs,
inside WPSInfo (well, inside ProcessFactoryInfo, that is already in the
metadata map)
Ing. Andrea Aime
@geowolf
Technical Lead
Yep, I view extensions as managed as part of GeoServer (they are optional
in the sense that they are not required as part of every install, but they
are critical for much a portion of our user base).
Jody
